Home » Eclipse Projects » Remote Application Platform (RAP) » Set Custom Style of Group-Frame
Set Custom Style of Group-Frame [message #550956] |
Wed, 04 August 2010 12:17  |
the Group Widget has a themeable poperty, namely Group-Frame, to style the frame of a Group widget. It seems, that is is not possible to use custom style variants for this in the application.
In the theme.css i'm doing something like this:
Group-Frame.bla {
In the application i set the custom style variant on the Group widget:
group.setData(WidgetUtil.CUSTOM_VARIANT, "bla");
Unfortunately, the custom Group-Frame style is not respected in this case. The Group itself has the style property "border", but this styles a border around the widget and not the rounded Group-Frame.
Intuitively, i would expect, that the Group widget would also respect the custom variants of Group-Label and Group-Frame if there are variants with the same name. Is there a possibility to customly style the Group-Frames?
Thanks!
Greetings,
-Ben
Re: Set Custom Style of Group-Frame [message #551204 is a reply to message #550956] |
Thu, 05 August 2010 10:54   |
Hi Benjamin,
I agree that custom variants set on a control should be inherited by
sub-widgets like Group-Frame. We do that in a couple of places but
obviously missed it here. Would you mind opening a bug for this problem?
Best regards, Ralf
Benjamin Wolff wrote:
> Group-Frame.bla {
> Group-Frames?
> Thanks!
> Greetings,
> -Ben
Ralf Sternberg
Need professional support for RAP and RCP?
http://www.eclipsesource.com/support/
Twitter: http://twitter.com/eclipsesource
Blog: http://www.eclipsesource.com/blogs/
Re: Set Custom Style of Group-Frame [message #551210 is a reply to message #551204] |
Thu, 05 August 2010 11:39   |
No, i wouldn't mind at all ;))
https://bugs.eclipse.org/bugs/show_bug.cgi?id=321895
Greetings,
-Ben
Am 05.08.2010 16:54, schrieb Ralf Sternberg:
> Hi Benjamin,
> Best regards, Ralf
>> Hi,
>> Group-Frame.bla {
>> Group-Frames?
>> Thanks!
>> Greetings,
>> -Ben
Re: Set Custom Style of Group-Frame [message #551247 is a reply to message #551210] |
Thu, 05 August 2010 13:32   |
Works perfect! Thank you for the very fast bugix!!!
Am 05.08.2010 17:39, schrieb Benjamin Wolff:
> Greetings,
> -Ben
>> Hi Benjamin,
>> Best regards, Ralf
>>> Hi,
>>> Group-Frame.bla {
>>> Group-Frames?
>>> Thanks!
>>> Greetings,
>>> -Ben
Re: Set Custom Style of Group-Frame [message #551309 is a reply to message #551307] |
Thu, 05 August 2010 17:08  |
Paul Kendall wrote:
> Ralf Sternberg wrote:
>> Hi Benjamin,
>> Best regards, Ralf
> Hi Ralf,
> It seems that this same problem occurs for ExpandItem-Header
> Cheers,
> Paul
https://bugs.eclipse.org/bugs/show_bug.cgi?id=321924
with a patch attached.
Paul
Current Time: Mon Jul 14 00:02:38 EDT 2025
Powered by FUDForum. Page generated in 0.20807 seconds
