Home » Modeling » TMF (Xtext) » Cross-references to external EMF models (revisited)
Cross-references to external EMF models (revisited) [message #550914] Wed, 04 August 2010 15:49 Go to next message
Joern is currently offline JoernFriend
I try to reference elements given in external EMF models as Andreas in http://www.eclipse.org/forums/index.php?t=msg&th=170756& amp;start=0&S=81127b7c17990f3eddb47e01037a6405.
Therefore I adapted the solution given in org.eclipse.xtext.ecore and org.eclipse.xtext.ui.ecore for "my" language (here: bpmn2 from the corresponding Eclipse project). Nevertheless if I „import" the (process) model in my DSL I cannot reference the elements (e.g. the auto completion does not show the elements given in the model). Referencing elements from plain Ecore models does work.
Debugging the DSL editor I found that the "resource" member in BpmnResourceDescription (cf. EcoreResourceDescription) does not contain elements and reports two errors: PackageNotFoundException and ClassNotFoundException for the imported (process) model and it's URI.
Do I have to register the metamodel somewhere within xText, e.g. in the MWE2 workflow (editing process models within the generated Ecore editor works)? Or something else?
Thank you in advance.
Re: Cross-references to external EMF models (revisited) [message #551084 is a reply to message #550914] Thu, 05 August 2010 07:26 Go to previous messageGo to next message
Sven Efftinge is currently offline Sven EfftingeFriend
You don't need to register the EPackage with Xtext. Xtext relies on
EMF's registry.
Make sure, the bundle containing the EPackage has a valid plugin.xml and
is activated successfully. (i.e. can you use the EPackage directly?)
Sven
Am 8/4/10 5:49 PM, schrieb Joern:
Need professional support for Xtext or other Eclipse Modeling technologies?
Go to: http://xtext.itemis.com
Twitter : @svenefftinge
Blog : http://blog.efftinge.de
Re: Cross-references to external EMF models (revisited) [message #551699 is a reply to message #551084] Mon, 09 August 2010 08:45 Go to previous message
Thanks, that helped: BPMN2 does only export the XMI-related namespace, not the one for the XSD serialization in the plugin.xml. I will add a comment in the corresponding forum.
Joern
Previous Topic:[MWE2] Accessing the current workspace from a workflow component
Next Topic:Combining two DSLs
Current Time: Thu Oct 01 05:26:34 GMT 2020
Powered by FUDForum. Page generated in 0.02105 seconds
