Re: Dependencies in Java EE Module Dependencies not recognized when starting servers [message #552655 is a reply to message #551274] |
Fri, 13 August 2010 05:04 |
I finally found the cause of the problem. I specified the 'Default output folder' in WebContent/WEB-INF/classes' and WTP wasn't happy about it, after I changed to 'build/classes', it finally recognizes all the dependency.
But now I'm having another problem which seems to be Glassfish specific, since it works OK in Tomcat.
The project depends on other project that uses 2 Spring context files & 1 properties file which is located in a folder named 'config'. I've added the 'config' folder to list of libraries then checked it in Java EE Module Dependencies. When I start Glassfish it says that it's unable to find those files hence the deployment fails. Those files does not seem to be automatically added to WEB-INF/classes.
But it works on Tomcat.
Is this a known problem on Glassfish ?
Best Regards,
Setya
FUDForum. Page generated in 0.03602 seconds
