Home » Eclipse Projects » Eclipse 4 » Developing plug-ins
Re: Developing plug-ins [message #550501 is a reply to message #550482] |
Fri, 30 July 2010 14:30 |
Simon Chemouil Messages: 24 Registered: July 2009 |
Vlad Dumitrescu a écrit :
> Maybe I'm missing the obvious, but I'm still trying to get all my
> bearings right.
> The existing tutorials are targeting RCP applications. I can't find
> anything about developing plugins that will run in the IDE -- the PDE
> tooling targets 3.6 and less and generates old-style plugins...
As it is now, the plan is that IDE plugin developers should develop
their plugins just as they always did, and make sure they're only
consuming public API. The only difference is that they should test their
plugins against both 3.x and 4.0 if they want to be compatible with both
releases.
The "org.eclipse.e4" API is provisional and is used internally by the
compatibility layer which is a new implementation of the Eclipse
Workbench over the Eclipse 4 Application Platform. Adventurous RCP
developers can benefit from the provisional API because it offers new
and freer ways to develop apps, but there is not much to gain for plugin
developers as it is now.
By programming against the provisional API, a plugin developer loses
compatibility with the 3.x series (unless by using a 4->3 compatibility
layer), has no guarantee the model or the API won't change, and the gain
is minimal: the SDK/IDE look is not a problem for plugins, and plugins
themselves extend current bundles/features that are probably not
developed using the 4.0 API. If your plugin has dependencies which are
themselves dependent on 3.x, the interest is really limited. It can be
interesting when your plugin only depends on eclipse core/ui.
As of today, for a plugin developer, the only advantages I can see are:
* for fun, learning, etc.
* taking advantage of the new modeled UI, contexts, DI, etc, but
keeping in mind that you're forced to go back to the 3.x-style API
through compatibility for most of the integration with current
plugins/features (like JDT, Team, etc).
In the long run, of course, the plan is to have a stable 4.x API that
plugin developers code against, but some features are still missing now
so the 4.0 story for plugin developers is incomplete.
The early adopters release will allow the 4.0 team to improve the
compatibility layer by having plugin developers test their 3.6 compliant
plugins on the 4.0 SDK, and report their bugs.
If you still want to write plugins for 4.0 knowing that they'll likely
have to mix 3.x and 4.0, but still only be compatible with 4.0, with no
API stability guarantee... Well you should go for it, because the 4.x
programming model is much more pleasant imo, but keep in mind that by
doing so, you will be reaching less users today.
In this case, install model tooling, the E4 SDK and the EMF SDK from the
p2 update site already preconfigured in the 4.0 SDK ("E4 2010 updates")
and try to mix 3.x and 4.0 tutorials...
By the way, PDE doesn't "generate" for 3.6. It has a target platform,
and once you install the 4.0 bundles, you can use them and generate the
bundles using them from PDE.
Hope this helps,
Simon
Re: Developing plug-ins [message #550526 is a reply to message #550501] |
Fri, 30 July 2010 16:30 |
Vlad Dumitrescu Messages: 431 Registered: July 2009 Location: Gothenburg |
Hi Simon,
Thanks a lot for the detailed answer.
Simon Chemouil wrote on Fri, 30 July 2010 10:30 | As of today, for a plugin developer, the only advantages I can see are:
I'm definitely in the second camp I already have bothered Tom Schindl with questions about the e4 compatibility layer...
One of the main things I was after in my question, but didn't express it clearly, was about the modeled UI: I can't find out how to use that for a single view. I mean, I have a model fragment, but how do I plug it in?
I found a nice walkthrough at http://tomsondev.bestsolution.at/2010/07/09/e4-some-more-new s-from-the-modeltooling/, but the unanswered questions are:
- how do I get the "Find parent elements" dialog?
- how can I refer to (and possibly open in the workbenchmodel editor) the model for the IDE?
best regards,
Vlad
Re: Developing plug-ins [message #550543 is a reply to message #550542] |
Fri, 30 July 2010 18:28 |
Thomas Schindl Messages: 6651 Registered: July 2009 |
One more note. There's a demo application we are using to work out what
we need to make the new model story a first class concept.
The project is named Simple-IDE and it for example holds a descriptor
which is able to replace the editor-extension point. The current
PartDescriptor mentioned below is a replacement for the view-extension
point because for an editor more meta informations are needed (e.g.
which file-extensions it is used for, ...)
You can find the sources for the project in CVS:
e4/org.eclipse.e4.ui/examples/org.eclipse.e4.demo.simpleide* and
org.eclipse.e4.demo.tools.simpleide*.
Tom
Am 30.07.10 20:21, schrieb Tom Schindl:
> The problem with the find-parents dialog is that the initial
> Legacy-Application model is well fairly empty because in the current 4.0
> SDK 3.x informations coming through code (Advisors) and extension points
> are making up the model on the fly.
> Beside that I think what you really want to contribute is not a Part but
> a PartDescriptor (which is the equivalent of what you contribute through
> the editor/view extension point).
> The relationship between PartDescriptor and Part is similar to the Class
> and Object relation in Java itself. When you select a view entry in the
> "Show View"-Menu the "blueprint" information of PartDescriptor is used
> to the make up an Part-Instance which is inserted into the UI-Structure
> of the workbench. Does this description make sense to you else I'll try
> to rephrase?
> Writing up informations on how to write plug-ins using the
> model-fragment concept is on my TODO-List but there's simply too much
> I'll have to write up (I still want to code for Eclipse 4.1 :-)
> The list of up coming things are:
> * Tutorial on writing your own Theme (first blog post with informations
> is fairly ready)
> * Tutorial on contributing through Model-Fragments to the 4.0 workbench
> (as outlined above this is a bit tricky because of the implementation
> of the compat-layer) - event I myself need to find out test out
> things :-)
> * What ever people want to know about Eclipse 4.0 and the underlying
> technology
> Thanks for your interest into Eclipse 4.x we are trying to provide you
> as much informations and service we can with the given resources (as
> stated some of us are going to be on holiday in the next weeks :-)
> Tom
> Am 30.07.10 19:07, schrieb Vlad Dumitrescu:
>> Vlad Dumitrescu wrote on Fri, 30 July 2010 12:30
>> Ok, scratch that, I found it -- but it's empty...
>> regards,
>> Vlad
Re: Developing plug-ins [message #550554 is a reply to message #550543] |
Fri, 30 July 2010 19:04 |
Tom Schindl wrote on Fri, 30 July 2010 14:28 | Hi,
Thanks a lot for the answers, Tom! Maybe it's not a bad idea that you will go on vacation, it will force me to do better research before asking
I'm not sure why the SimpleIDE project went unnoticed... anyway, I just imported the sources and I get an exception when opening Application.e4xmi:
org.eclipse.emf.ecore.xmi.PackageNotFoundException: Package with uri 'http://www.eclipse.org/e4/demo/simpleide' not found. (file:/E:/Users/Vlad/workspace4/org.eclipse.e4.demo.simpleide.e4editor/xmi/fragment.e4xmi, 4, 315)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.getPackageForURI(XMLHandler.java:2591)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.getFactoryForPrefix(XMLHandler.java:2422)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.createObjectFromTypeName(XMLHandler.java:2072)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.createObject(XMLHandler.java:2031)
at org.eclipse.emf.ecore.xmi.impl.XMIHandler.createObject(XMIHandler.java:134)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.handleFeature(XMLHandler.java:1840)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.processElement(XMLHandler.java:1023)
at org.eclipse.emf.ecore.xmi.impl.XMIHandler.processElement(XMIHandler.java:87)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.startElement(XMLHandler.java:1001)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.startElement(XMLHandler.java:712)
at org.eclipse.emf.ecore.xmi.impl.XMIHandler.startElement(XMIHandler.java:169)
at com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser.startElement(Unknown Source)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl.scanStartElement(Unknown Source)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl$FragmentContentDriver.next(Unknown Source)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentScannerImpl.next(Unknown Source)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl.scanDocument(Unknown Source)
at com.sun.org.apache.xerces.internal.parsers.XML11Configuration.parse(Unknown Source)
at com.sun.org.apache.xerces.internal.parsers.XMLParser.parse(Unknown Source)
at com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser.parse(Unknown Source)
at com.sun.org.apache.xerces.internal.jaxp.SAXParserImpl$JAXPSAXParser.parse(Unknown Source)
at javax.xml.parsers.SAXParser.parse(Unknown Source)
at org.eclipse.emf.ecore.xmi.impl.XMLLoadImpl.load(XMLLoadImpl.java:181)
at org.eclipse.emf.ecore.xmi.impl.XMLResourceImpl.doLoad(XMLResourceImpl.java:180)
at org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(ResourceImpl.java:1494)
at org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(ResourceImpl.java:1282)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLoad(ResourceSetImpl.java:255)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLoadHelper(ResourceSetImpl.java:270)
regards,
Vlad
Re: Developing plug-ins [message #550583 is a reply to message #550554] |
Fri, 30 July 2010 21:50 |
The SimpleIDE uses an extended EMF-Model, so the problem you are facing
is that org.eclipse.e4.demo.simpleide.model is not in your OSGi-Runtime.
There are 2 possibilities:
a) Export
* org.eclipse.e4.demo.simpleide.model
* org.eclipse.e4.demo.tools.simpleide
and copy them to your dropins-Folder
b) Launch an inner Eclipse
* Checkout org.eclipse.e4.demo.tools.simpleide and
* Launch an Inner Eclipse
* Checkout the rest
Tom
Am 30.07.10 21:04, schrieb Vlad Dumitrescu:
>> Hi,
> asking :)
> (file:/E:/Users/Vlad/workspace4/org.eclipse.e4.demo.simpleid e.e4editor/xmi/fragment.e4xmi,
> 4, 315)
> at
> org.eclipse.emf.ecore.xmi.impl.XMLHandler.getPackageForURI(X MLHandler.java:2591)
> at
> org.eclipse.emf.ecore.xmi.impl.XMLHandler.getFactoryForPrefi x(XMLHandler.java:2422)
> at
> org.eclipse.emf.ecore.xmi.impl.XMLHandler.createObjectFromTy peName(XMLHandler.java:2072)
> at
> org.eclipse.emf.ecore.xmi.impl.XMLHandler.createObject(XMLHa ndler.java:2031)
> at
> org.eclipse.emf.ecore.xmi.impl.XMIHandler.createObject(XMIHa ndler.java:134)
> at
> org.eclipse.emf.ecore.xmi.impl.XMLHandler.handleFeature(XMLH andler.java:1840)
> at
> org.eclipse.emf.ecore.xmi.impl.XMLHandler.processElement(XML Handler.java:1023)
> at
> org.eclipse.emf.ecore.xmi.impl.XMIHandler.processElement(XMI Handler.java:87)
> at
> org.eclipse.emf.ecore.xmi.impl.XMLHandler.startElement(XMLHa ndler.java:1001)
> at
> org.eclipse.emf.ecore.xmi.impl.XMLHandler.startElement(XMLHa ndler.java:712)
> at
> org.eclipse.emf.ecore.xmi.impl.XMIHandler.startElement(XMIHa ndler.java:169)
> at
> com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser .startElement(Unknown
> Source)
> at
> com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentS cannerImpl.scanStartElement(Unknown
> Source)
> at
> com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentS cannerImpl$FragmentContentDriver.next(Unknown
> Source)
> at
> com.sun.org.apache.xerces.internal.impl.XMLDocumentScannerIm pl.next(Unknown
> Source)
> at
> com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentS cannerImpl.scanDocument(Unknown
> Source)
> at
> com.sun.org.apache.xerces.internal.parsers.XML11Configuratio n.parse(Unknown
> Source)
> at
> Source)
> at
> com.sun.org.apache.xerces.internal.parsers.XMLParser.parse(U nknown Source)
> at
> com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser .parse(Unknown
> Source)
> at
> com.sun.org.apache.xerces.internal.jaxp.SAXParserImpl$JAXPSA XParser.parse(Unknown
> Source)
> at
> org.eclipse.emf.ecore.xmi.impl.XMLLoadImpl.load(XMLLoadImpl. java:181)
> at
> org.eclipse.emf.ecore.xmi.impl.XMLResourceImpl.doLoad(XMLRes ourceImpl.java:180)
> at
> org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(Resour ceImpl.java:1494)
> at
> org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(Resour ceImpl.java:1282)
> at
> org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLo ad(ResourceSetImpl.java:255)
> at
> org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLo adHelper(ResourceSetImpl.java:270)
> regards,
> Vlad
Re: Developing plug-ins [message #579741 is a reply to message #550482] |
> bearings right.
releases.
Hope this helps,
Simon
Re: Developing plug-ins [message #579754 is a reply to message #550501] |
Hi Simon,
I'm definitely in the second camp :) I already have bothered Tom Schindl with questions about the e4 compatibility layer...
best regards,
Vlad
Re: Developing plug-ins [message #579801 is a reply to message #550542] |
Tom
> to rephrase?
> is fairly ready)
> things :-)
> technology
> Tom
>> regards,
>> Vlad
Re: Developing plug-ins [message #579813 is a reply to message #550543] |
Thanks a lot for the answers, Tom! Maybe it's not a bad idea that you will go on vacation, it will force me to do better research before asking :)
org.eclipse.emf.ecore.xmi.PackageNotFoundException: Package with uri 'http://www.eclipse.org/e4/demo/simpleide' not found. (file:/E:/Users/Vlad/workspace4/org.eclipse.e4.demo.simpleid e.e4editor/xmi/fragment.e4xmi, 4, 315)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.getPackageForURI(X MLHandler.java:2591)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.getFactoryForPrefi x(XMLHandler.java:2422)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.createObjectFromTy peName(XMLHandler.java:2072)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.createObject(XMLHa ndler.java:2031)
at org.eclipse.emf.ecore.xmi.impl.XMIHandler.createObject(XMIHa ndler.java:134)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.handleFeature(XMLH andler.java:1840)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.processElement(XML Handler.java:1023)
at org.eclipse.emf.ecore.xmi.impl.XMIHandler.processElement(XMI Handler.java:87)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.startElement(XMLHa ndler.java:1001)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.startElement(XMLHa ndler.java:712)
at org.eclipse.emf.ecore.xmi.impl.XMIHandler.startElement(XMIHa ndler.java:169)
at com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser .startElement(Unknown Source)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentS cannerImpl.scanStartElement(Unknown Source)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentS cannerImpl$FragmentContentDriver.next(Unknown Source)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentScannerIm pl.next(Unknown Source)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentS cannerImpl.scanDocument(Unknown Source)
at com.sun.org.apache.xerces.internal.parsers.XML11Configuratio n.parse(Unknown Source)
at com.sun.org.apache.xerces.internal.parsers.XMLParser.parse(U nknown Source)
at com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser .parse(Unknown Source)
at com.sun.org.apache.xerces.internal.jaxp.SAXParserImpl$JAXPSA XParser.parse(Unknown Source)
at org.eclipse.emf.ecore.xmi.impl.XMLLoadImpl.load(XMLLoadImpl. java:181)
at org.eclipse.emf.ecore.xmi.impl.XMLResourceImpl.doLoad(XMLRes ourceImpl.java:180)
at org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(Resour ceImpl.java:1494)
at org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(Resour ceImpl.java:1282)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLo ad(ResourceSetImpl.java:255)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLo adHelper(ResourceSetImpl.java:270)
regards,
Vlad
Re: Developing plug-ins [message #579881 is a reply to message #550554] |
a) Export
* Checkout the rest
Tom
>> Hi,
> asking :)
> 4, 315)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> at
> Source)
> at
> Source)
> at
> at
> at
> at
> at
> at
> regards,
> Vlad
Current Time: Tue Apr 23 12:35:09 GMT 2024
Powered by FUDForum. Page generated in 0.05145 seconds
