Eclipse flags ALL XML tags as invalid. [message #550443] |
Fri, 30 July 2010 11:55 |
Paul Messages: 3 Registered: July 2010 |
Hi guys,
I have had this problem for a long while, but have a few minutes to actually try and fix it and I can't.
If I create the following file called test.jsp
<hello>
<world>Blah</world>
</hello>
Then Eclipse highlights "<hello>" and "<world>" with a warning, "Unknown Tag"
It also highlights </world> and </hello> red with the descriptive "Error" and no other information.
I have played about with JSP validation settings and XML validation settings, but nothing seems to say, "Eclipse, leave it alone, it's custom XML or an XML format you don't know about, just let me know about obvious XML structure errors, ignore the tags!"
This is Eclipse 3.4.2 but I have had the problem since Eclipse 3.2 or 3.3
The errors exist no matter what type of XML I am using.
I generally just ignore eclipse, but I'd still like to fix it someday
Paul
[Updated on: Fri, 30 July 2010 11:56] Report message to a moderator
FUDForum. Page generated in 0.04009 seconds
