Re: Uses constraint when adding org.springframework.spring [message #550405 is a reply to message #550336] |
Fri, 30 July 2010 09:40 |
Hi Anthony,
Sorry we didn't get to you sooner, the dev team for Virgo is based in England so there is a little time lag. Glad to hear your trying OSGi out, I have a few comments from what you've said.
Uses violations occur when the different dependencies of a bundle clash as they use different versions of the same package. I'm not surprised this happened when you put the spring.jar in. We ship with the Spring framework already provided and modularised in to about a dozen different jars. Unless you specifically need a different version I would just use the provided one as it's easier.
Regards, Chris.
Chris Frost, Twitter @cgfrost
Springsource, a divison of VMware.
Re: Uses constraint when adding org.springframework.spring [message #594330 is a reply to message #594323] |
Hi Anthony,
Regards, Chris.
FUDForum. Page generated in 0.03888 seconds
