Home » Archived » Test and Performance Tools Platform (TPTP) » Automated test
Automated test [message #55376] Tue, 28 February 2006 09:50 Go to next message
Originally posted by: ayesha.ltp.soft.net
Hi all,
I am having a problem setting up automated test.The problem is that the
eclipse classloader is unable to load junit/framework/TestListener class. I
am able to run the test from within the workbench successfully. All plugins
selected while running from workbench is also copied into the
test-application. Additionally, I have plugins, org.eclipse.test,
org.eclipse.ant_1.6.5 and org.junit_3.8.1.
I get the following stack trace:
[java] [java] Exception in thread "WorkbenchTestable"
org.eclipse.swt.SWTException: Failed to execute runnable
(java.lang.NoClassDefFoundError: junit/framework/TestListener)
[java] [java] !ENTRY org.eclipse.ui 4 4 2006-02-28 15:18:10.989
[java] [java] at org.eclipse.swt.SWT.error(SWT.java:3283)
[java] [java] !MESSAGE Unhandled event loop exception
[java] [java] at org.eclipse.swt.SWT.error(SWT.java:3206)
[java] [java] at
org.eclipse.swt.widgets.Synchronizer.syncExec(Synchronizer.j ava:178)
[java] [java] !ENTRY org.eclipse.ui 4 0 2006-02-28 15:18:10.989
[java] [java] !MESSAGE Failed to execute runnable
[java] [java] at
org.eclipse.ui.internal.UISynchronizer.syncExec(UISynchroniz er.java:28)
[java] [java] at
org.eclipse.swt.widgets.Display.syncExec(Display.java:3700)
[java] [java] at
org.eclipse.ui.internal.testing.WorkbenchTestable.runTest(Wo rkbenchTestable.
java:109)
[java] [java] at
org.eclipse.test.UITestApplication.runTests(UITestApplicatio n.java:185)
[java] [java] at
org.eclipse.ui.internal.testing.WorkbenchTestable$1.run(Work benchTestable.ja
va:68)
Ayesha
Re: Automated test [message #55646 is a reply to message #55376] Tue, 28 February 2006 20:12 Go to previous messageGo to next message
No real name is currently offline No real nameFriend
Is this an Automated GUI test that you are running or a JUnit plug-in test?
If it's a GUI test, then make sure that you have correctly defined the
dependecies of your plug-in under
the manifest file.
"Ayesha" <ayesha@ltp.soft.net> wrote in message
news:du15pf$l3q$1@utils.eclipse.org...
> Hi all,
the
I
plugins
> [java] [java] at
> [java] [java] at
> [java] [java] at
> [java] [java] at
> [java] [java] at
> [java] [java] at
> java:109)
> [java] [java] at
> [java] [java] at
> va:68)
> Ayesha
Re: Automated test [message #55753 is a reply to message #55646] Wed, 01 March 2006 05:21 Go to previous messageGo to next message
This an automated UI Test that I am running using build scripts written in
test.xml. I have added the dependencies in my manifest.mf. Running the
test from within workbench as a Junit-Plugin test works fine. The test fails
with the ClassDefNotFoundError for junit/framework/TestListener when run
using test.xml.
Ayesha
"Ali Mehregani" <amehrega@ca.ibm.com> wrote in message
news:du2as2$gqk$1@utils.eclipse.org...
test?
> the manifest file.
> > Hi all,
> the
class.
> I
> plugins
15:18:10.989
> > [java] [java] at
> > [java] [java] at
> > [java] [java] at
15:18:10.989
> > [java] [java] at
> > [java] [java] at
> > [java] [java] at
> > java:109)
> > [java] [java] at
> > [java] [java] at
> > va:68)
> > Ayesha
Re: Automated test [message #56110 is a reply to message #55753] Thu, 02 March 2006 16:21 Go to previous messageGo to next message
Hi Ayesha,
So here's what I gather from your post:
- You have an automated GUI test suite that you are attempting to launch via
an ANT script
- I'm assuming that the automated GUI test suite launches fine when you
launch it normally in your workbench
Now does the ANT script launch when you launch it using the ANT launch
configuration under "External Tools" in your workbench?
Your problem doesn't sound like there is any issue with the automated gui
recorder or the automatable service framework. It's seems like a classical
classpath problem.
news:du3aeg$eiq$1@utils.eclipse.org...
fails
> using test.xml.
> Ayesha
> test?
> > the manifest file.
> > > Hi all,
that
> > the
> class.
> > I
> > plugins
> 15:18:10.989
> > > [java] [java] at
> > > [java] [java] at
> > > [java] [java] at
> 15:18:10.989
> > > [java] [java] at
> > > [java] [java] at
> > > [java] [java] at
> > > java:109)
> > > [java] [java] at
> > > [java] [java] at
> > > va:68)
> > > Ayesha
Re: Automated test [message #56270 is a reply to message #56110] Fri, 03 March 2006 08:32 Go to previous message
Thanks for the help. I copied the fragment
org.eclipse.ant.optional.junit_2.1.0 and it started working.
Ayesha
news:du7633$vkl$1@utils.eclipse.org...
> Hi Ayesha,
via
> an ANT script
classical
> classpath problem.
in
> fails
> > using test.xml.
> > Ayesha
> > test?
> > > the manifest file.
> > > > Hi all,
> that
> > > the
> > class.
> > > I
> > > plugins
> > 15:18:10.989
> > > > [java] [java] at
> > > > [java] [java] at
> > > > [java] [java] at
> > 15:18:10.989
> > > > [java] [java] at
> > > > [java] [java] at
> > > > [java] [java] at
> > > > java:109)
> > > > [java] [java] at
> > > > [java] [java] at
> > > > va:68)
> > > > Ayesha
Previous Topic:JWizardDialog text input
Next Topic:TPTP 4.2 i1 / Callisto M5 Milestone Available
Current Time: Tue Sep 29 12:17:27 GMT 2020
Powered by FUDForum. Page generated in 0.01784 seconds
