Re: Does eclipse has a feature of auto usage finder on selecting a part of code ? [message #549481 is a reply to message #549463] |
Mon, 26 July 2010 19:04 |
On 7/26/2010 11:12 AM, venkat_walking@yahoo.co.in wrote:
> Hi all,
> I am new to eclipse shifted from netbeans. Does eclipse has a feature f
> Say I create a simple java file helloWorld.java.
> In that i create and use variable int abc 10 times.
> What I want is As soon I click or select the variable abc in the code it
> other multiple usages should be highlited by some fill color and it
> should also be shown in side column bar as it does for showing error
> messages
> I dont want to click CTLR+F for doing this.
> This feature is there in netbeans.
> I hope u understand what I am looking for
> Thanks
> Venkat
Something like this. Among other options, if you double-click an
identifier, all other occurrences of it are color-filled highlighted in
the editor and, if your contract/brightness/color settings are adequate
for your monitor, down the right-hand side there will be markers you can
click to go to occurrences.
FUDForum. Page generated in 0.02058 seconds
