Re: [MWE2] Accessing the current workspace from a workflow component [message #551672 is a reply to message #549626] |
Mon, 09 August 2010 06:48 |
The reason why there are some *Standalone classes is that MWE(2) workflows are usually executed "outside" the Eclipse platform, i.e. as a standalone Java process. This is important to be able to run these processes within build systems or other IDEs without the need to run it as an Eclipse application. Most of the registrations should be done automatically when executed within a plugin. This means this would result into two different workflows when you still want to test your generator without the Eclipse runtime.
Kind regards,
~Karsten
Need professional support for Xtext, EMF, Eclipse IDE?
Go to: http://devhub.karakun.com
Twitter : @kthoms
Blog : www.karsten-thoms.de
FUDForum. Page generated in 0.02664 seconds
