Home » Archived » M2M (model-to-model transformation) » [ATL] Put all lanes under one lane set
[ATL] Put all lanes under one lane set [message #549160] Sun, 25 July 2010 10:01 Go to next message
I have 3 lanes and all of them should be grouped under 1 lane set. The problem is, that I can just group 1 lane under 1 lane set, which is not what I want. It looks like the following:
<LaneSet name="ABC Bank">
<lane id="Consultant"/>
</LaneSet>
<lane id="credit clerk"/>
</LaneSet>
<lane id="Head of credit department"/>
</LaneSet>
The result I want to have is:
</LaneSet>
How is this possible to realize? Should I do something with iteration? Thank you and cheers
Roger
Re: [ATL] Put all lanes under one lane set [message #549229 is a reply to message #549160] Mon, 26 July 2010 04:23 Go to previous messageGo to next message
Is there no possibility to reach that goal?
Cheers Roger
Re: [ATL] Put all lanes under one lane set [message #549328 is a reply to message #549229] Mon, 26 July 2010 09:24 Go to previous messageGo to next message
Could you show the ATL code you use for this?
[Updated on: Mon, 26 July 2010 09:25] by Moderator
Re: [ATL] Put all lanes under one lane set [message #549340 is a reply to message #549328] Mon, 26 July 2010 09:41 Go to previous messageGo to next message
Of course. Smile
helper def: flattenLanes() : Collection(String) =
EPK!Participant.allInstances() ->collect(e | e.id)->asSet() ->collect(e | EPK!Participant.allInstances()->select(f | f.id = e)->first());
--Rule 4 Role2Lane
rule Role2Lane {
	from
		d : EPK!Participant (thisModule.flattenLanes()->includes(d))
	to
		a : BPMN!LaneSet
		name <- 'ABC Bank',
		--id <- d.name,
		lane <- lan
		lan : BPMN!LaneE (
		 id <- d.name
Do you have any clue how to solve it?
Thanks and cheers Roger
Re: [ATL] Put all lanes under one lane set [message #549345 is a reply to message #549160] Mon, 26 July 2010 09:46 Go to previous messageGo to next message
You want to group on ids or names ?
Once you group the elements, if you keep only one, you have to affect to this one, the elements of the others that are not transformed.
Re: [ATL] Put all lanes under one lane set [message #549360 is a reply to message #549345] Mon, 26 July 2010 10:07 Go to previous messageGo to next message
Its not so important, if it easier to do on id, I would do it on id's.
Cheers Roger
Re: [ATL] Put all lanes under one lane set [message #549409 is a reply to message #549345] Mon, 26 July 2010 11:14 Go to previous messageGo to next message
So, ok I will do on id, how can I do that then?
Re: [ATL] Put all lanes under one lane set [message #549433 is a reply to message #549345] Mon, 26 July 2010 11:45 Go to previous messageGo to next message
Ok, this is my last open point. What do you mean with:
You know that I have just 3 elements left
What do you mean with that, do I have to do some coding?
Thank you very much for your help.
Cheers Roger
Re: [ATL] Put all lanes under one lane set [message #549556 is a reply to message #549433] Tue, 27 July 2010 04:13 Go to previous messageGo to next message
Please, can you give me advice how to do. As I mentioned, this is my last problem and I have to hand in tommorrow.
Thank you very much!
Cheers Roger
Re: [ATL] Put all lanes under one lane set [message #549559 is a reply to message #549160] Tue, 27 July 2010 04:24 Go to previous messageGo to next message
I don't think we can always do your own work. Ask precise questions if you want answers.
Re: [ATL] Put all lanes under one lane set [message #549563 is a reply to message #549559] Tue, 27 July 2010 04:41 Go to previous messageGo to next message
Hello Sylvain
I understand you. Sorry.
Ok, then, what method do I have to use to realize the problem? I do even not now were to start.
Thank you.
Re: [ATL] Put all lanes under one lane set [message #549568 is a reply to message #549160] Tue, 27 July 2010 05:00 Go to previous messageGo to next message
Think about algorithm, that is totally technology independant so you can't ask about that.
Re: [ATL] Put all lanes under one lane set [message #549609 is a reply to message #549568] Tue, 27 July 2010 07:15 Go to previous message
Ok, I thought about it and I think it should work like the following.
Theoretical algorithm:
1) The algorithm has to check if a Lane Set is already available.
2) If this the LaneSet is available -> put Lane under LaneSet
3) If Lane Set is not available create LaneSet.
So, as the LaneSet can just be identified over the name I have to do this check over the name.
The problem I see and do not understand is, that the LaneSet is the target node and how should I check if a target node is available or not?
So, that is what I have so far. I am happy for further inputs. Thank you...
Cheers Roger
Previous Topic:[SOLVED] [ATL] Put root element on all other elements
Next Topic:[QVTO] How to generate a trace file
Current Time: Mon Jul 07 20:01:00 EDT 2025
Powered by FUDForum. Page generated in 0.05229 seconds
