Re: Memory options [message #55700 is a reply to message #55292] |
Tue, 28 February 2006 20:27 |
Originally posted by: Navid_Mehregani_nmehrega.ca.ibm.com
This is a multipart message in MIME format.
--=_alternative 0070654C85257123_=
Content-Type: text/plain; charset="US-ASCII"
Yes, there is. In your profile launch configuration -> Switch to the
profiling tab -> Select the 'Memory Analysis' profiling set -> Click on
Edit -> Next -> Select Basic Memory Analysis (Make sure this option is
checked) -> Click on 'Advanced' -> Check 'Collect instance level
information' -> Next -> Set your filter set -> profile.
Double click on 'Basic Memory Analysis' listed under your agent. Click on
the 'instance level information' button for this view. The button is
located in the top right hand corner of the view. It has a green and
purple circle on it. This view should show you all your classes and the
objects they've declared.
Navid Mehregani
Content-Type: text/html; charset="US-ASCII"
<br><font size=2 face="sans-serif">Yes, there is. In your profile
launch configuration -> Switch to the profiling tab -> Select the
'Memory Analysis' profiling set -> Click on Edit -> Next -> Select
Basic Memory Analysis (Make sure this option is checked) -> Click
on 'Advanced' -> Check 'Collect instance level information' -> Next
-> Set your filter set -> profile.</font>
<br>
<br><font size=2 face="sans-serif">Double click on 'Basic Memory Analysis'
listed under your agent. Click on the 'instance level information'
button for this view. The button is located in the top right hand
corner of the view. It has a green and purple circle on it. This
view should show you all your classes and the objects they've declared.</font>
<br><font size=2 face="sans-serif"><br>
Navid Mehregani</font>
--=_alternative 0070654C85257123_=--
FUDForum. Page generated in 0.05824 seconds
