Unexpected layout of elements inside Component [message #548720] |
Thu, 22 July 2010 18:03 |
Originally posted by: harrisb.ociweb.com
I'm trying to use the UML2Tool's Component diagram element defined in
componentDiagram_classifiers.gmfgraph with my own mapping. When I do
this the elements inside the component stack on top of each other with
each element nearly the same width as the component. By contrast, when I
create a component using UML2Tools, I can place elements anywhere inside
the component with any size.
In other words, the layout for a Component using UML2Tools appears to be
using the GMF XY Layout. However, inspecting the graphical definition
model I looks like a custom border is used for the figure that
corresponds to the compartment holding the component elements.
I concluding this by looking in project org.eclipse.uml2.diagram.def
graphical definition model found in
structures/componentDiagram_classifiers.gmfgraph. For figure
ComponentFigure_Body used by the compartment the custom layout
org.eclipse.gmf.runtime.draw2d.ui.figures.OneLineBorder is used. Is this
the reason the elements I'm putting in the component just stack up? I
would have expected that XY Layout would be used.
Can someone help explain why I can't position my elements anywhere in
the component?
Byron Harris
Re: Unexpected layout of elements inside Component [message #551834 is a reply to message #551735] |
Mon, 09 August 2010 17:09 |
Hi Christian,
Yes, I eventually found out there was a setting for my compartment's
listlayout that was set to “true” in the .gmfgen file that was
overriding the layout setting in the graphic definition model. Once I
set listlayout to "false" I got the behavior I was expecting.
I wonder why listlayout is needed?
Byron
Christian Waniek wrote:
> Hello
> sometimes it helps to inspect the gmfgen-file (the generator model).
> Because here you also have the possibility to make some changes. You
> mustn't use it as it is. As long as you only overwrite the gmfgen all
> previously made manual changes remain in this file. So maybe you'll find
> here the answer to your question.
> Else I would look at the code: Maybe there's some custom code (besides
> the OneLineBorder) which does the job.
> Regards
> Christian Waniek
Re: Unexpected layout of elements inside Component [message #625959 is a reply to message #551735] |
Hi Christian,
Byron
> Hello
> Regards
> Christian Waniek
FUDForum. Page generated in 0.03891 seconds
