Home » Modeling » GMF (Graphical Modeling Framework) » Property Sheet title
Property Sheet title [message #548716] Thu, 22 July 2010 17:35 Go to next message
I have a gmf project.
when I click on an element then I do show properties that will show the property sheet with title1.
I'm trying to find the code where the title was set but no success.
Can you point me to that ?
Re: Property Sheet title [message #548803 is a reply to message #548716] Fri, 23 July 2010 06:27 Go to previous messageGo to next message
Originally posted by: marius.groeger.googlemail.com
Am 22.07.2010 19:35, wrote bachra04:
It's in TabbedPropertySheetPage#refreshTitleBar(). Actually it's the
PropertiesBrowserPage which extends TabbedPropertySheetPage.
In cases like this I find it helpful to use the Plug-In Spy: active the
GUI element in question and press Shift-Alt-F1 to view the implementing
class.
Marius
Re: Property Sheet title [message #548824 is a reply to message #548716] Fri, 23 July 2010 08:11 Go to previous messageGo to next message
When generating your diagram plugin, the generated plugin contains a org.eclipse.ui.views.proerties,propertyContributor extension.
You can replace the labelProvider on this extension. It is used to display the title.
HTH,
Mickael Istria -- BonitaSoft S.A.
http://www.bonitasoft.com/products/downloads.php
Re: Property Sheet title [message #548922 is a reply to message #548716] Fri, 23 July 2010 13:31 Go to previous message
You can also edit "yourmodel".gmfgen by selecting the node
"Gen Editor Generator ....." >> "Gen Diagram ...EditPart" >> "Gen Child Node title1" >> "Metamodel Type title1"
and change the value of "Display Name" in the property sheet.
Next you have to regenerate the Diagram Project (delete its plugin.xml before because generation doesnt' override this file)
Olivier
Previous Topic:Can GMF support RAP?
Next Topic:PopUp Bar on nested child elements
Current Time: Thu Feb 13 14:01:50 GMT 2025
Powered by FUDForum. Page generated in 0.43153 seconds
