Home » Modeling » EMF » New Ecore container-reference validation rule in Helios: Bug?
New Ecore container-reference validation rule in Helios: Bug? [message #548347] Wed, 21 July 2010 14:00 Go to next message
Christian Damus is currently offline Christian DamusFriend
Today was my first time re-generating a model with the Helios final
build since the last time I re-generated, with Helios M6. In opening my
genmodel, I got this error reported:
A containment reference of a type with a container feature
platform:/resource/com.qnx.tools.ide.systembuilder.model/mod el/System.ecore#//Condition/constraint
that requires instances to be contained elsewhere cannot be populated.
In my case, I think this validation problem is erroneous.
I have two questions:
(a) Container references are derived by being the opposites of
containments, so it is not possible that an object can
have a value for the container that is inconsistent with
its containment. Doesn't the generated code for the
container reference check the actual eContainmentFeature()
and, if it's not the container's opposite, return null?
(b) Container references don't have to have non-null values,
right? I can have many container references, with
zero or one of them having a value, but not more?
My situation is like this:
Class Super {
contains x[*] : X
Class X {
references super[0..1] : Super opposite-of contains
Class Sub -> Super {
contains otherRoleForX[1..*] : X
So, X::super is a container reference because it's the opposite of a
containment.
The validation rule complains that Sub::otherRoleForX is not a valid
containment because X::super is of type Super, but that's OK because
X::super doesn't have a value *unless* the object is contained via Super::x.
I don't see how this validation rule makes sense. Can I turn it off,
somehow?
Christian
Re: New Ecore container-reference validation rule in Helios: Bug? [message #548349 is a reply to message #548347] Wed, 21 July 2010 14:35 Go to previous messageGo to next message
Christian,
Comments below.
Christian W. Damus wrote:
> my genmodel, I got this error reported:
That looks familiar.
Hmmm...
> its containment.
Indeed.
Yes.
Yes.
> Class Super {
> contains x[*] : X
> Class X {
> containment.
> Super::x.
It's complaining about the multiplicities of the container references so
I doubt your example is accurate. I don't see any required containers.
Consider the implementation:
public boolean validateEReference_ConsistentContainer(EReference
eReference, DiagnosticChain diagnostics, Map<Object, Object> context)
if (eReference.isContainment() && eReference.getEContainingClass()
!= null)
EClass eClass = eReference.getEReferenceType();
if (eClass != null)
for (EReference otherEReference : eClass.getEAllReferences())
if (otherEReference.isRequired() &&
otherEReference.isContainer() && otherEReference.getEOpposite() !=
eReference)
The point is supposed to be that you can't be contained by more than one
container, so you can't have a container references that's required as
well as any other containment reference that's not the opposite of that
required container. I.e., a required container prevents other
containment references from ever being populated.
> somehow?
No, but I can fix it if it's broken. It seems sound though...
> Christian
Ed Merks
Re: New Ecore container-reference validation rule in Helios: Bug? [message #548362 is a reply to message #548349] Wed, 21 July 2010 14:51 Go to previous messageGo to next message
Hi, Ed,
You are so right! Dang, will I *never* find a bug in EMF? ;-)
I hadn't paid the multiplicity any attention because it never really did
matter for containers (at least, not for codegen). But, this new
validation rule pointed out the erroneous 1 lower-bound in my model that
I didn't know was there ... I had assumed it was what I expected.
Great rule! Keep them coming!
Christian
On 21/07/10 10:35 AM, Ed Merks wrote:
-------->8--------
>> Super::x.
--------8<--------
Re: New Ecore container-reference validation rule in Helios: Bug? [message #548370 is a reply to message #548362] Wed, 21 July 2010 15:08 Go to previous messageGo to next message
Christian,
I had the same experience with the GenModel itself. A GenPackage was
required to be contained by a GenModel, which overlooked the fact that
it can be contained by a GenPackage instead.
> Hi, Ed,
> did matter for containers (at least, not for codegen). But, this new
> that I didn't know was there ... I had assumed it was what I expected.
> Christian
> -------->8--------
>>> Super::x.
> --------8<--------
Ed Merks
Re: New Ecore container-reference validation rule in Helios: Bug? [message #663515 is a reply to message #548370] Tue, 05 April 2011 13:22 Go to previous messageGo to next message
Mario Winterer is currently offline Mario WintererFriend
Hi!
Shouldn't container references always be nullable anyway?
Objects can sometimes get a container that they aren't aware of.
E.g. ChangeDescription#objectstoAttach contains all objects that were removed from its model, so an object with non-nullable container references will never be valid once inside a ChangeDescription.
I mean for the sake of (re)usability an object's container can and should never be restricted by the model designer, and the same should be true for its container references.
Mario
Re: New Ecore container-reference validation rule in Helios: Bug? [message #663573 is a reply to message #663515] Tue, 05 April 2011 16:12 Go to previous message
Mario,
Comments below.
Mario Winterer wrote:
> Hi!
No, why?
That's true.
That's certainly true. But consider something like an EClass instance.
It really needs to be in an EPackage to be valid. Floating around in a
ChangeDescription isn't good enough...
I don't think that's a good assertion. I think it's often the case for
something to be semantically complete that it needs to exist in a
complete context.
Your example about being in a change description is a good one though.
But even here, a new object might exist in a form that leaves it
incomplete but the change description includes feature changes that when
applied will move the object to a complete context and will set all the
features to make it valid. So in general, it will often be the case
that an object contained in a change description will not be valid in
that state...
> Mario
Ed Merks
Previous Topic:TreeViewer setInput error
Next Topic:Separating API from Implementation in Model
Current Time: Tue Mar 21 18:54:45 GMT 2023
Powered by FUDForum. Page generated in 0.02210 seconds
