Home » Modeling » GMF (Graphical Modeling Framework) » SVG rendering with GEF/GMF
SVG rendering with GEF/GMF [message #548243] Wed, 21 July 2010 04:49 Go to next message
I'm trying to use SVG images with GEF in an RCP app.
I was already using a dedicated plugin for image rendering, but only PNG and JPG.
I tried to adapt this plugin to be able to display SVG (as background images for a GEF graph).
I'm using a ScalableImageFigure for this background images, and regular imageFigure for the objects that will be drawn over these background images.
I did manage to get an "image" displayed, but it looks like a bunch of colored squares, and I don't understand why. The SVG images that I'm using are exported from DWG files using easy CAD to SVG converter, and it seems that there is transparency, don't know if that's important so I wanted to mention it.
As I can't find any example, any help would be appreciated (or even tutorials!)
Re: SVG rendering with GEF/GMF [message #548254 is a reply to message #548243] Wed, 21 July 2010 05:14 Go to previous messageGo to next message
The org.eclipse.gmf.runtime.lite.svg bundle may provide you what you want.
It is availalble in the GMF experimental SDK, from thyhe GMP update-site.
Mickael Istria -- BonitaSoft S.A.
http://www.bonitasoft.com/products/downloads.php
Re: SVG rendering with GEF/GMF [message #548272 is a reply to message #548254] Wed, 21 July 2010 06:18 Go to previous messageGo to next message
Thank you, I'll take a look at it.
I discovered something odd when trying to create a BIRT report using this image : it seems that the image has a really tiny size, which explains why i see it that way (I have a automatic "fit to page").
What I don't get right now, is that :
- The images are SVG, and yet it seems that they're converted to SWT to be displayed ? I was planning on using larger images since they're vector image, without having memory issues ....
- the image size was set to 16000*12000 (and when i open the XML I can see these values), why would GMF display them so small ? Missing a parameter maybe (I tried playing with the renderinfo, without success) ?
Aurélien
Re: SVG rendering with GEF/GMF [message #548392 is a reply to message #548272] Wed, 21 July 2010 12:33 Go to previous messageGo to next message
OK, I tried SVGFigure and everything works fine, but it seems that when I open a 5MB SVG file, memory usage is crazy (compared to the old PNG files).
The rest of the application remains unchanged, so I guess SVG isn't that light :/
Please let me know about any experience you've had with SVG redering.
Aurélien
Re: SVG rendering with GEF/GMF [message #550683 is a reply to message #548243] Wed, 04 August 2010 03:09 Go to previous message
Effectively it seems that SVG image takes a lot of memory and in GMF, each element takes a new SVG image even if it is the same image to display. It will be useful to used a registry perhaps but I didn't find the time for now to explore this way.
Previous Topic:GMF model to text transformation
Next Topic:CreateElementCommand - elements do not appear on diagram
Current Time: Mon Apr 28 02:48:24 EDT 2025
Powered by FUDForum. Page generated in 0.03429 seconds
