Re: Eclipse Helios & BIRT 2.6 freezes [message #548167 is a reply to message #548072] |
Tue, 20 July 2010 21:46 |
Ernst,
What is the full name of the download file you used?
Jason
On 7/20/2010 11:11 AM, Ernst wrote:
> Hi BIRT Users
> Eclipse freezes every time I'm trying to do the following thing:
> 1. create a new Reporting project
> 2. create a new Report ==> Eclipse freezes and has to be shot down with
> the task manager.
> I tried this 2 times with a clean all in one 2.6 download. One time on a
> Win XP machine (32 bit version) an one time on Win 7 (64 bit version)
> machine. Both show the very same behaviour.
> Obviously this makes working with BIRT impossible.
> Any ideas about how to come around this problem?
> Best Regards
> Ernst
Re: Eclipse Helios & BIRT 2.6 freezes [message #548971 is a reply to message #548951] |
Fri, 23 July 2010 14:29 |
Are you getting any errors in the workspace/.metadata/.log file?
Jason
On 7/23/2010 10:21 AM, ivost wrote:
> I have the same problem - designer freezes during creation of data
> source. I tried both 32 and 64 bit installs and the link above. Tried
> with classiccars example and with mysql jdbc source. Tried increasing
> java memory to 768M in eclipse.ini. Eclipse either freezes or just shuts
> down. I'm on 64-bit Windows. I'll try on clean VM - any advise is
> appreciated.
Re: Eclipse Helios & BIRT 2.6 freezes [message #549004 is a reply to message #548992] |
Fri, 23 July 2010 15:59 |
Can you also open a bug for this?
Jason
On 7/23/2010 11:44 AM, ivost wrote:
> I tried on clean 32-bit VM - got same problem with both 2.5.2 and 2.6 -
> using latest JDK 1.6 - 22
> Decided to try with Java 5 - which is hard to get as it's EOL
> Lo an behold - 2.6 designer works fine.
> I'll stick with 1.5 JDK for now - but there should be some way/setting
> to make this work with Java 6.
> I'll look for any error logs...
Re: Eclipse Helios & BIRT 2.6 freezes [message #549423 is a reply to message #549093] |
Mon, 26 July 2010 15:07 |
Did you open a bug for this?
Jason
On 7/24/2010 5:22 AM, Ernst wrote:
> Hi
> I tried JDK 1.6 19,20 and 21. I tried with Eclipse Helios and Ganymed. I
> also tried the fixes for Eclipse and JDK 1.6 21 mentioned here
> http://lt-rider.blogspot.com/2010/07/oracle-jvm-6u21-and-ecl ipse.html
> (and in a lot of other places).
> No luck.
> It's not only BIRT that is crashing, also normal JSE developement
> crashes repeatedly after some minutes. Some times I found
> java.lang.OutOfMemoryError: PermGen space in the Eclipse log, sometimes
> nothing was written to the logs.
> After all I installed the latest JRockit VM and all of a sudden all
> problems disapeard.
> I did not have any problems running any other Java Applications. All of
> them work as expecd, except Eclipse.
> IMHO there's a genreal problem with Eclipse and the sun/oracle JVM.
FUDForum. Page generated in 0.04596 seconds
