Re: Transformation between UML profiles [message #548713 is a reply to message #548002] |
Thu, 22 July 2010 17:25   |
Stefan Mijatov Messages: 59 Registered: March 2010 Location: Vienna, Austria |
Member |
When I follow the above tutorial, I get *.ecore file of my profile, which is nice and good. However, it seems that the uml metamodel in ecore is referenced somehow by ecore metamodel of profile, thus I can not create dynamic instance of "package" or "model", for example, from the ecore metamodel of my profile. I only get the stereotypes in ecore file that I have defined in profile, and even if I make dynamic instance of those stereotypes it seems as if generalization of those stereotypes from uml concepts didn't work...
What I am trying to say is that if I make extension stereotype of uml:Class element, stereotype doesn't inherit attributes of uml:Class element...it has only the attributes and references and etc., that I have defined in profile...
Maybe I am doing something wrong, but I am kind a loosing my patience here...
Can someone provide example of making transformation between two models of UML profiles defined in Eclipse?
Re: Transformation between UML profiles [message #549586 is a reply to message #548002] |
Tue, 27 July 2010 09:44   |
Member |
I have been trying to execute this QVTO transformation that you posted, but I just can't get it working.
First of all, as I understood I have to make profile1.ecore and profile2.ecore files using the method described here. Then as input metamodels to transformation, I have to provide these two ecore files, as well as uml.ecore file that is metamodel of uml, to the transformation as input model types and than when I want to do the actual transformation I provide *.uml file that is model of first profile as input model and generate other *.uml file that is model of second uml profile. Is this correct?
Second, I am using Eclipse 3.4.2 and I am not sure which version of qvto does it have, but it seems there is no forEach() operation to use... I found only forAll() which could be the same thing?
[Updated on: Tue, 27 July 2010 09:47] Report message to a moderator
Re: Transformation between UML profiles [message #549663 is a reply to message #548002] |
Tue, 27 July 2010 13:51   |
Member |
I am unable to execute the above example transformation, since there is no implementation of forEach() operation in QVTO. However, I have defined this more simple QVTO operation but for some reason the only mapping that I have defined in it, is never called...
Here is the code:
modeltype jpa "strict" uses JPA('http:///JPA.ecore');
modeltype rel "strict" uses REL('http:///REL.ecore');
modeltype uml "strict" uses uml('http://www.eclipse.org/uml2/2.1.0/UML');
transformation jpa2rel(in jpaIn:jpa, in umlIn:uml, out relOut:rel);
main() {
-- copy root model(s)
log("main()...");
umlIn.rootObjects()[uml::Model] -> map toModel();
mapping uml::Model::toModel() : uml::Model{
name := self.name;
log("toModel()...");
I have defined two profiles, JPA (Hibernate) and REL(Relational) and created model of JPA profile called jpa.uml. I have provided it as input model, and also ecore metamodels of these two profiles as well as uml ecore metamodel as metamodels for transformation. However when I run this transformation mapping toModel() is never called...
jpaIn and umlIn are referencing to jpa.uml model...
What am I doing wrong?
[Updated on: Tue, 27 July 2010 13:52] Report message to a moderator
Re: Transformation between UML profiles [message #551950 is a reply to message #548002] |
Tue, 10 August 2010 09:25   |
Member |
So, I managed to generate, through qvto transformation, some UML elements in output model based on elements in input model. I managed to apply profile to output model by using next piece of code:
var models = umlIn.rootObjects()[uml::Model].clone();
models[uml::Model]->forEach(m){
m.profileApplication := profileIn.objects()[uml::ProfileApplication];
I tried to use "someClass.applyStereotype()" in transformation, in order to apply some stereotypes to certain elements, but I can not get it working. I can, however apply stereotypes to elements of output model, after transformation, using UML editor, so I guess output model is valid, and profile has been successfully applied upon transformation completition.
Please, can anyone provide valid piece of code for applying stereotypes in qvto transformation!?
FUDForum. Page generated in 0.02546 seconds
