Subclass of PolylineConnection instances are not visible [message #547758] |
Mon, 19 July 2010 14:49 |
Mike Swap Messages: 7 Registered: April 2010 |
I'm creating an application using GEF and I have a small problem with connections. On the editpart associated with the connection, I first tried to add a simple PolylineConnection, and it works perfectly well. But now, I would like to have a label that the user can modify. So I created a subclass of PolylineConnection which has a Label as an attribute. The probleme is, when I try to link two boxes, the connection is not visible (even if it exists, because I can't add the same connection twice).
If anyone has an idea of how to display these connections, I would be more than happy
Thanks in advance,
Mike.
FUDForum. Page generated in 0.03346 seconds
