Home » Modeling » GMF (Graphical Modeling Framework) » CreateElementCommand - elements do not appear on diagram
CreateElementCommand - elements do not appear on diagram [message #547579] Mon, 19 July 2010 02:47 Go to next message
Al is currently offline AlFriend
Hey,
I'm having some trouble creating elements programmatically. The problem is that the new element is not displayed on the diagram, no matter how many refreshes - it gets put in the model though. However, it starts to work after I place an element with the editor's palette.
Here's the gist of the code:
public void createElement(Object originalEditPart, DiagramCommandStack dcs, IProgressMonitor progressMonitor) {
		IGraphicalEditPart gEditPart = (IGraphicalEditPart)originalEditPart;
		final EObject originalImpl = gEditPart.getNotationView().getElement();
		TransactionalEditingDomain domain = gEditPart.getEditingDomain();
		GraphicalEditPart part = (GraphicalEditPart)originalEditPart;
		GraphicalEditPart container = (GraphicalEditPart)part.getParent();
		CreateElementRequest req = new CreateElementRequest(domain, originalImpl.eContainer(), Blah_modelElementTypes.SomeType_2005);
		CreateElementCommand create = new CreateElementCommand(req);
		dcs.execute(new ICommandProxy(create));
		refresh();
Again, this actually works perfectly fine after I place an element on the diagram with the editor palette, just not before. Has anyone else encountered this problem before?
Thank you!
Re: CreateElementCommand - elements do not appear on diagram [message #548587 is a reply to message #547579] Thu, 22 July 2010 11:59 Go to previous messageGo to next message
Originally posted by: marius.groeger.googlemail.com
Am 19.07.2010 04:47, schrieb Al:
I think you're only creating a semantic element with this code, but no
View (Edit Part) for it. You're probably getting the View with the next
"kick" of the CanonicalEditPolicy. So you can either:
* locate the responsible CanonicalEditPolicy and trigger a manual refresh
* use a CreateViewAndElementReques
Marius
Re: CreateElementCommand - elements do not appear on diagram [message #550684 is a reply to message #547579] Wed, 04 August 2010 07:10 Go to previous message
Aurélien Pupier is currently offline Aurélien PupierFriend
take a look at this tip: http://wiki.eclipse.org/GMF_Tips#Creating_New_Elements_And_C orresponding_Views
Aurélien Pupier - Red Hat
Senior Software Engineer in Fuse Tooling team
Previous Topic:SVG rendering with GEF/GMF
Next Topic:problem about duplication function
Current Time: Sat Jun 22 22:25:54 GMT 2024
Powered by FUDForum. Page generated in 0.03870 seconds
