Home » Eclipse Projects » Rich Client Platform (RCP) » RCP client for EJB, cannot lookup.
RCP client for EJB, cannot lookup. [message #547536] |
Sun, 18 July 2010 15:08 |
Hu Jin Messages: 1 Registered: July 2010 |
Hi there,
I am trying to build a RCP client for an ejb application. Thus, I need to access remote ejb from the rcp client.
I use the following code to do the lookup:
Properties prop=new Properties();
prop.putContext.INITIAL_CONTEXT_FACTORY, "org.apache.openejb.client.RemoteInitialContextFactory");
prop.put("java.naming.provider.url", "ejbd://127.0.0.1:4201");
Context context = new InitialContext(prop);
However, I always get the exception at "InitialContext", the exception is:
Caused by: java.lang.ClassNotFoundException: org.apache.openejb.client.RemoteInitialContextFactory
I have double checked and confirm openejb-client-3.1.2.jar is in Java Build Path and RemoteInitialContextFactory is included in this jar file. The server is Geronimo.
Is there any special way to specify the classpath in RCP application? I have run out of the ideas, please help
Jin
[Updated on: Sun, 18 July 2010 15:08] Report message to a moderator
Re: RCP client for EJB, cannot lookup. [message #547759 is a reply to message #547536] |
Mon, 19 July 2010 14:30 |
Martin Klinke Messages: 80 Registered: July 2009 |
Member |
Jin,
please note, that this is just a work-around, but it may help in your
case. You could try setting the context class loader to the class loader
of the current thread, i.e.
ClassLoader old = Thread.currentThread().getContextClassLoader();
try {
Thread.currentThread().setContextClassLoader(this.getClass() .getClassLoader);
//new InitialContext...
} finally {
Thread.currentThread().setContextClassLoader(old);
You may then experience further problems when loading/deserializing
instances that are returned from EJB methods. This may happen, if you
have a "generic" Geronimo bundle G and a custom bundle C with your
project-specific classes. As C depends on G, G cannot see C's classes by
default. So you have to specify a BuddyPolicy in G (dependent or
registered). See here for details on the BuddyPolicy
http://www.eclipsezone.com/articles/eclipse-vms/
HTH,
Martin Klinke
http://www.martinklinke.com
Am 18.07.2010 17:08, schrieb Hu Jin:
> Hi there,
> Cheers,
> Jin
Re: RCP client for EJB, cannot lookup. [message #547761 is a reply to message #547759] |
Mon, 19 July 2010 14:34 |
Member |
Thinking about it, another more trivial cause for the CNFE may be that
org.apache.openejb.client.RemoteInitialContextFactory has a further
dependency that is not contained in your class-path...
Martin
Am 19.07.2010 16:30, schrieb Martin Klinke:
> Jin,
> try {
> } finally {
> HTH,
> Martin Klinke
>> Hi there,
>> is:
>> Cheers,
>> Jin
Current Time: Thu Apr 25 07:09:38 GMT 2024
Powered by FUDForum. Page generated in 0.02937 seconds
