Home » Eclipse Projects » Rich Client Platform (RCP) » Problem with setting the classpath
Problem with setting the classpath [message #547441] Fri, 16 July 2010 20:03 Go to next message
Bahar Sateli is currently offline Bahar SateliFriend
Hi all,
I am developing a plug-in for eclipse in which I have to reference to a shared library in form of a .jar file - that is external to the project. In other words, the .jar file that I want to use is in my system file and not in the Eclipse workspace.
I tried to add the .jar file in the plugin.xml runtime classpath tab, that was also reflected in MANIFEST.MF file as the following:
Bundle-ClassPath: .,
/home/MY_USER/THE_PATH_TO_THE_FILE/myfile.jar
but still when I run the plug-in it cannot find the classes inside the jar file and gives me:
Exception in thread "Thread-4" java.lang.NoClassDefFoundError
Can anybody please help me with this?
Bahar
P.S. I am using Linux SuSe!
Re: Problem with setting the classpath [message #547748 is a reply to message #547441] Mon, 19 July 2010 14:13 Go to previous message
Paul Webster is currently offline Paul WebsterFriend
Bundles can only see classes in other bundles. Bundle-ClassPath is by
default relative to the base of the bundle.
But, there is a way to reference an external jar, using external:
http://dev.eclipse.org/newslists/news.eclipse.technology.equ inox/msg01146.html
But how will you deploy? How can you make sure that the external lib is
there for your plugin to consume? How will it be available on your
user's/customer's machines?
PW
Paul Webster
http://help.eclipse.org/galileo/index.jsp?topic=/org.eclipse .platform.doc.isv/guide/workbench.htm
Previous Topic:autosave snapshot
Next Topic:How to call Java RCP based application from Java Swing
Current Time: Tue Apr 16 12:33:18 GMT 2024
Powered by FUDForum. Page generated in 1.50832 seconds
