Multiple product files within the same plugin [message #547399] |
Fri, 16 July 2010 15:41 |
Christian Kesselheim Messages: 59 Registered: June 2010 |
Member |
Hello everybody,
I recently found that Buckminster doesn't much appreciate if you put multiple product files (both pointing to the same product extension) into one and the same plugin project.
Project refresh on org.eclipse.riena.example.client failed: Attribute org.eclipse.riena.example.client.example_product is defined more then once in component org.eclipse.riena.example.client
Is that a deliberate limitation of Buckminster or how to best work my way around such a situation (apart from actually deleting one of the offending product files, which I find quite invasive)?
Thanks in advance,
Chris
PS: The corresponding source code can be found here.
[Updated on: Fri, 16 July 2010 15:42] Report message to a moderator
Re: Multiple product files within the same plugin [message #547403 is a reply to message #547399] |
Fri, 16 July 2010 15:53 |
Buckminster attempts to generate actions for the products declared in the product files. It should be possible to have
several files but they need to have unique product ids. In your case it seems you have several files that use the same
id, i.e. 'org.eclipse.riena.example.client.example'.
- thomas
On 07/16/2010 05:41 PM, Christian Kesselheim wrote:
> Hello everybody,
> Thanks in advance,
> Chris
> http://dev.eclipse.org/viewcvs/index.cgi/org.eclipse.riena/o rg.eclipse.riena.example.client/?root=RT_Project
Re: Multiple product files within the same plugin [message #547567 is a reply to message #547404] |
Sun, 18 July 2010 21:20 |
On 07/16/2010 06:02 PM, Christian Kesselheim wrote:
> True. The reason behind that lies with the fact that its currently only
> the command line arguments that differ for the two products in question.
> Any chance that I can somehow "force" Buckminster to ignore one of these
> product files without actually deleting it?
No, I'm sorry. There's no such option. Feel free to enter an enhancement
request.
- thomas
FUDForum. Page generated in 0.03082 seconds
