Home » Modeling » GMF (Graphical Modeling Framework) » Add a sub item in the menu Diagram
Add a sub item in the menu Diagram [message #547380] Fri, 16 July 2010 14:18
Vincent Lorenzo is currently offline Vincent LorenzoFriend
I'm trying add a sub menu in the Diagram menu using the extension point org.eclipse.ui.menus, but it doesn't work,
because I don't find the correct locationURI for that.
Any ideas?
I know add a sub-menu with the gmf extension point org.eclipse.gmf.runtime.common.ui.services.action.contributi onItemProvider, but I should prefer use the eclipse extension point.
Thanks.
Previous Topic:Need to Rightclick new menu Disable
Next Topic:About persistence problem
Current Time: Thu Jun 13 05:26:50 GMT 2024
Powered by FUDForum. Page generated in 0.03273 seconds
