Home » Archived » M2M (model-to-model transformation) » [ATL] Set a mixed attribute (EFeatureMapEntry)(How to set a mixed attribute in an ecore created from XSD in ATL 3.1.0?)
[ATL] Set a mixed attribute (EFeatureMapEntry) [message #547282] Fri, 16 July 2010 04:10 Go to next message
I have read this article:
http://atlanmod.emn.fr/www/atl_discussion_archive/1729.html
and this bug:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=156094
Is there any solution for ATL 3.1.0 to set mixed attributes in ecore files that are created from XSD files? The patch available in the bug description is not applicable to ATL 3.1.0. Please correct me, if I'm wrong.
Thanks a lot in advance!
Christian
Solved: [ATL] Set a mixed attribute (EFeatureMapEntry) [message #547366 is a reply to message #547282] Fri, 16 July 2010 09:26 Go to previous message
Problem solved!
It is important to generate the XMLTypeDocumentRoot before it should be assigned to the mixed type. The given example transformation in the bug description works fine if you keep the order of the generated model elements in mind.
Christian
Previous Topic:[Xtend] Couldn't find extension 'transform(null::Specifications)'
Next Topic:[ATL] How does ATL handle XMI?
Current Time: Thu Nov 06 18:54:17 EST 2025
Powered by FUDForum. Page generated in 0.04839 seconds
