Re: [QVTo] Query about in/out/inout and check/enforce or create/append/update execution mode [message #547097 is a reply to message #546518] |
Thu, 15 July 2010 12:11 |
Sergey Boyko Messages: 171 Registered: July 2009 |
Hi Ed,
This is definitely a bug. The [out] direction is enforced old objects to
be discarded. Could you please raise bugzilla for that?
Sergey
Ed Willink wrote:
> Hi
> I am not clear how the mode of transformation execution is controlled.
> Sometimes my transformations fail unless the output is seeded.
> Using the Helios Simpleuml_To_Rdb example, if run once it creates a
> Model in /SimpleUML to RDB/Simpleuml_To_Rdb.rdb as might be expected.
> If run again and again and again, it creates further Models (remember to
> refresh the file to see the multiples). This seems odd, but nowhere is
> there an explicit statement that the output is enforce.
> If RDB/Simpleuml_To_Rdb.rdb is changed to make RDB an inout model, the
> transformation fails if the output does not exist, but otherwise creates
> multiple copies again and again and again.
> In the absence of any control flags in the Run Configuration, I would
> expect in->out to be a create/overwrite, and in->inout to be a
> create/update. I would expect to need in,in->out to get create/append.
> Am I missing something?
> Regards
> Ed Willink
Re: [QVTo] Query about in/out/inout and check/enforce or create/append/update execution mode [message #550524 is a reply to message #547097] |
Fri, 30 July 2010 16:24 |
Ed Willink Messages: 7655 Registered: July 2009 |
Hi Sergey
(Bug 320010 raised for the rerun causing append.)
Now I want to execute in update mode. Is this supported?
(OMG QVT Issue raised on the very opaque and contradictory definitions
of "enforce", "checkonly" and MappingOperation.refinement.)
Ed Willink
On 15/07/2010 13:11, Sergey Boyko wrote:
> Hi Ed,
> Regards,
> Sergey
> Ed Willink wrote:
>> Hi
>> to refresh the file to see the multiples). This seems odd, but nowhere
>> is there an explicit statement that the output is enforce.
>> creates multiple copies again and again and again.
>> Regards
>> Ed Willink
FUDForum. Page generated in 0.02531 seconds
