Home » Newcomers » Newcomers » "Computing Size" Error when installing plugins for Helios("Computing Size" Error when installing plugins for Helios)
"Computing Size" Error when installing plugins for Helios [message #546355] Mon, 12 July 2010 10:33 Go to next message
I am having trouble with Helios on CentOS5.3 (RHEL5.3) Linux x64. I am using JRE 1.6.0.14
I have Helios x64 installed on a central NFS server for access by a number of people. This setup works for Eclipse v3.5
After install, I ran up Helios as an admin, and was able to install the latest Subclipse plugin using the GUI "Install software" feature.
However if I try and install anything else using the GUI - Mylyn or Pydev for example, I get:
"Computing Size has encountered a problem. An internal error occurred during 'Computing Size'''
Under 'Details' the error is given as: 'The profile is currently in use'.
I tried a clean install of Helios again and installed Pydev first, which then worked, but then Subclipse gives the above error. The fact the first plugin installs, whether it be Pydev or Subclipse, and subsequent ones fail makes me think it isn't one particular plugin causing the issue
As an alternative I tried copying Pydev's 'features' and 'plugins' folders to the dropins folder as directed by the install guide, but the plugin only appears when the app is run as admin, which obviously our regular users can't do. I guess it's a permissions problem there.
So my questions are:
How can I get round the compute size error.
If not, how can I get the plugins read by all users if they are manually copied to dropins.
Nick
[Updated on: Mon, 12 July 2010 10:42] by Moderator
Re: "Computing Size" Error when installing plugins for Helios [message #546413 is a reply to message #546355] Mon, 12 July 2010 12:57 Go to previous messageGo to next message
Ok, it seems to be an issue with installing plugins to Eclipse on an NFS server. If I copy the install to my local hard disk I can then install plugins using the GUI.
Our NFS server is 9TB, I wonder if that is too big in some way? I'm not sure what 'Compute Size' actually refers to.
I will see if I can install all the plugins I need locally as root, then copy the whole lot back to the server.
Nick
[Updated on: Mon, 12 July 2010 12:57] by Moderator
Re: "Computing Size" Error when installing plugins for Helios [message #664174 is a reply to message #546355] Thu, 07 April 2011 13:48 Go to previous messageGo to next message
I have a similar problem and, after reading your post, I think it relates to running eclipse from an external hard drive. One time, I followed this advice and it worked, perfectly:
http://www.kelvinluck.com/2009/08/error-installing-plugins-i n-eclipse-on-osx/
But now, something else is wrong, I guess. If all else fails, I'll follow the suggestion here to move Eclipse off my external drive, update it, then move it back.
Re: "Computing Size" Error when installing plugins for Helios [message #1690618 is a reply to message #546355] Mon, 30 March 2015 01:43 Go to previous message
My issue was using shared network drive I was running Eclipse Luna from and used plugin archive to install from. Once I moved both Eclipse Luna and plugin archive to C: drive all went well. I guess this is the solution.
Previous Topic:Migrating from a customized eclipse version to Lunar
Next Topic:Eclipse Hangs on fetching children of branches
Current Time: Wed Jun 18 08:37:01 EDT 2025
Powered by FUDForum. Page generated in 0.09678 seconds
