Home » Eclipse Projects » Plugin Development Environment (PDE) » Problem with headless build on Eclipse 3.4.2
Problem with headless build on Eclipse 3.4.2 [message #54958] |
Tue, 14 April 2009 17:48 |
Patrick Schoenbach Messages: 110 Registered: July 2009 |
I am running a headless build of a product, based on Eclipse 3.4.2.
However, I have two problems:
- The finished archive contains no "dropins" folder, and if I create it
manually after unpacking, it is ignored.
- The default Ganymede update site is missing.
What could be wrong?
Patrick
Patrick Schönbach
Software Architect
PGP public key available. Key ID: 0B7DDE39
Or email to pgp@robustsoft.de with subject 'pschoenb'.
Fingerprint: BE80 0E7E B68E CE99 623C 902D 62A6 806A 0B7D DE39
web: http://www.itemis.de
mail: schoenbach@itemis.de
xing: https://www.xing.com/profile/Patrick_Schoenbach
itemis AG
Schauenburgerstraße 116
24118 Kiel
Germany
Rechtlicher Hinweis:
Amtsgericht Dortmund, HRB 20621
Vorstand: Wolfgang Neuhaus, Jens Wagener, Dr. Georg Pietrek
Aufsichtsrat: Dr. Burkhard Igel(Vors.), Stephan Grollmann, Michael
Neuhaus
Re: Problem with headless build on Eclipse 3.4.2 [message #55230 is a reply to message #54958] |
Wed, 15 April 2009 09:16 |
On Tue, 14 Apr 2009 19:48:57 +0200, Patrick Schönbach wrote:
No idea, anyone?
Patrick Schönbach
Software Architect
itemis AG
24118 Kiel
Germany
Neuhaus
Re: Problem with headless build on Eclipse 3.4.2 [message #56611 is a reply to message #55748] |
Fri, 17 April 2009 10:16 |
On Thu, 16 Apr 2009 13:29:03 +0000 (UTC), msacarny wrote:
> Sounds like Bugzilla 252284.
> We do this:
> (From Chris Williams) Our "workaround" is to just run a couple extra ant
> tasks after the director runs (and before we zip up the results). We
> basically just do a mkdir on the dropins folder so it gets created if it's
> not already there. And we do a replaceregexp on the bundles.info file and
> force the dropins plugin listing to end with "true" rather than "false".
> Hope it helps,
> Mike
Could you maybe post a snippet please, how exactly you do it?
And what about the missing default update site?
Patrick
Patrick Schönbach
Software Architect
itemis AG
24118 Kiel
Germany
Neuhaus
Re: Problem with headless build on Eclipse 3.4.2 [message #56908 is a reply to message #56638] |
Sat, 18 April 2009 08:30 |
On Fri, 17 Apr 2009 12:42:40 +0000 (UTC), msacarny wrote:
> Here is some code once you've determined the dropins folder is missing:
> <target name="makeDropins" unless="isDropins">
> <echo message="Fixing missing dropins folder!"/>
> <mkdir dir="${buildDirectory}/result/tmp/eclipse/dropins" />
> <replaceregexp
> file=" ${buildDirectory}/result/tmp/eclipse/configuration/org.eclip se.equinox.simpleconfigurator/bundles.info "
> match="(org.eclipse.equinox.p2.reconciler.dropins,.+,4,)false "
> replace="\1true"
> flags = "i"/>
> </target>
> On 3.4.1, as I recall, when this is done, the update site reappears.
I am not yet sure, at which place to call this code. Any hints?
Patrick
Patrick Schönbach
Software Architect
itemis AG
24118 Kiel
Germany
Neuhaus
Re: Problem with headless build on Eclipse 3.4.2 [message #56935 is a reply to message #56908] |
Sat, 18 April 2009 14:31 |
Solved.
Patrick
Patrick Schönbach
Software Architect
itemis AG
24118 Kiel
Germany
Neuhaus
Re: Problem with headless build on Eclipse 3.4.2 [message #595212 is a reply to message #54958] |
No idea, anyone?
Patrick Schönbach
Software Architect
itemis AG
24118 Kiel
Germany
Neuhaus
Re: Problem with headless build on Eclipse 3.4.2 [message #595704 is a reply to message #55748] |
> We do this:
> Hope it helps,
> Mike
Patrick
Patrick Schönbach
Software Architect
itemis AG
24118 Kiel
Germany
Neuhaus
Re: Problem with headless build on Eclipse 3.4.2 [message #595822 is a reply to message #56638] |
> <replaceregexp
> replace="\1true"
> flags = "i"/>
> </target>
Patrick
Patrick Schönbach
Software Architect
itemis AG
24118 Kiel
Germany
Neuhaus
Re: Problem with headless build on Eclipse 3.4.2 [message #595830 is a reply to message #56908] |
Solved.
Patrick
Patrick Schönbach
Software Architect
itemis AG
24118 Kiel
Germany
Neuhaus
Current Time: Wed Apr 24 15:05:23 GMT 2024
Powered by FUDForum. Page generated in 0.05414 seconds
