Re: Signing and Packing [message #545135 is a reply to message #544955] |
Tue, 06 July 2010 18:04 |
Hi Alex,
I somehow doubt that your problems are related to packing. It seems to
be a signing problem only. Does it work it you just enable packing but
not signing?
Thomas Hallgren
On 07/06/2010 10:32 AM, Axel Guckelsberger wrote:
> Hi all,
> I got several problems with regards to signing and packing when trying to
> install something from my p2 repository.
> If I set both signing and packing to true I run into this one:
> http://dev.eclipse.org/mhonarc/lists/p2-dev/msg01532.html
> I found a few tipps about that in bug 275533, but I have no idea how to
> apply them (e.g. telling Buckminster to use the pack200 from Java 5
> specifically).
> After I set packing to false I get signing related errors when trying to
> install. For example for some locale-specific fragments I get:
>> java.security.SignatureException: An error occurred while processing the
> signatures for the file: /tmp/signatureFile7238243853455712790.jar
>> Caused by: java.security.SignatureException: Error occurs parsing the .SF
> file to find out the digest algorithm in this bundle:
> My guess is that this is related to missing normalisation, like stated in
> bug 312802.
> Probably both problems are even related to each other or have a common
> cause. How to proceed? At the moment I deactivated both packing and signing
> for further testing. Thanks for any ideas.
> My setup is the following: the main p2 repository is a composite artifact
> update site (created with b3 aggregator) redirecting to my own p2 site as
> well as the Helios site. The errors are caused by my own p2 site built with
> Buckminster p2.site action.
> Regards
> Axel
FUDForum. Page generated in 0.03474 seconds
