Home » Archived » XML Schema Definition (XSD) » Analysing Complex Types derived by extension
Analysing Complex Types derived by extension [message #54850] |
Fri, 19 November 2004 14:55 |
Originally posted by: none.nonet.com
Hi there,
I'm having a problem analysing a complex type hierarchy using the API -
below are the complex type definitions I'm using. As you can see,
USAddress derives from Address, and NYAddress derives from USAddress.
The problem I'm encountering is when analysing a derived complex type. In
the attribute uses, I get all the attributes from the subtype and its base
type(s). However, as far as element declarations go, I only get the ones
from this particular type - which in the case of the NY address is none.
To get these I have to look at the base type definitions.
This seems fair enough in some ways, but the fact that the attributes do
appear in the attribute uses list seems to contradict this approach. Does
anyone have any ideas why this approach has been taken, or is it a flaw?
<xs:complexType name="Address">
<xs:sequence>
<xs:element name="name" type="xs:string"/>
<xs:element name="street" type="xs:string"/>
<xs:element name="city" type="xs:string"/>
</xs:sequence>
<xs:attribute name="Person" type="xs:string"/>
</xs:complexType>
<xs:complexType name="USAddress">
<xs:complexContent>
<xs:extension base="Address">
<xs:sequence>
<xs:element name="state" type="xs:string"/>
<xs:element name="zip" type="xs:string"/>
</xs:sequence>
<xs:attribute name="Surname" type="xs:string"/>
</xs:extension>
</xs:complexContent>
</xs:complexType>
<xs:complexType name="NYAddress">
<xs:complexContent>
<xs:extension base="USAddress">
<xs:attribute name="RentControlled" type="xs:boolean"/>
</xs:extension>
</xs:complexType>
Many thanks for your help,
Ray
Re: Analysing Complex Types derived by extension [message #54904 is a reply to message #54850] |
Fri, 19 November 2004 15:23 |
Ray,
Given an XSDComplexTypeDefinition x (with complex content),
x.getContentType() will give you the complete content particle,
including anything inherited from the base type, whereas x.getContent()
will give you only the physically contained particle with only the
locally declared content. Similarly, x.getAttributeUses() returns all
the inherited and local attributes, but x.getAttributeContents() returns
only the locally declared ones. I.e., you can view the model either
abstractly or concretely and abstract properties will say something like
"This represents the ... infoset property" whereas concrete properties
will say something like "This concrete reference represents ...". Be
sure to choose the one appropriate for what you are trying to do...
Ray wrote:
> Hi there,
> - below are the complex type definitions I'm using. As you can see,
> In the attribute uses, I get all the attributes from the subtype and
> its base type(s). However, as far as element declarations go, I only
> get the ones from this particular type - which in the case of the NY
> address is none. To get these I have to look at the base type
> definitions.
> do appear in the attribute uses list seems to contradict this
> approach. Does anyone have any ideas why this approach has been taken,
> or is it a flaw?
> <xs:sequence>
> </xs:sequence>
> </xs:complexType>
> <xs:complexContent>
> <xs:sequence>
> </xs:sequence>
> </xs:extension>
> </xs:complexType>
> <xs:complexContent>
> </xs:extension>
> </xs:complexType>
> Ray
Re: Analysing Complex Types derived by extension [message #54930 is a reply to message #54904] |
Fri, 19 November 2004 17:02 |
Ed Merks wrote:
> Ray,
Thanks for your help both of you. Unfortunately while what you say holds
true for attributes (AttributeUses returns all, AttributeContents only
local), i find that for elements, while x.GetContent does contain the the
local ones, x.GetContentType is empty - it doesn't even contain the local
declarations.
I'm using XSD 2.0.1 if thats of any help....
Thanks again for your help - you've helped me understand the API better
certainly.
Ray
Re: Analysing Complex Types derived by extension [message #54961 is a reply to message #54930] |
Fri, 19 November 2004 18:08 |
--------------020404030308060305090703
Ray,
For this schema:
<xsd:schema
xmlns:ecore="http://www.eclipse.org/emf/2002/Ecore"
xmlns:exa="http://www.example.com/ExampleA"
xmlns:xsd="http://www.w3.org/2001/XMLSchema"
targetNamespace="http://www.example.com/ExampleA">
<xsd:element name="a" type="exa:A"/>
<xsd:complexType name="A">
<xsd:sequence>
<xsd:element name="ae" type="xsd:string"/>
</xsd:sequence>
<xsd:attribute name="aa" type="xsd:string"/>
</xsd:complexType>
<xsd:complexType name="B">
<xsd:complexContent>
<xsd:extension base="exa:A">
<xsd:sequence>
<xsd:element name="be" type="xsd:string"/>
</xsd:sequence>
<xsd:attribute name="ba" type="xsd:string"/>
</xsd:extension>
</xsd:complexContent>
</xsd:complexType>
</xsd:schema>
I'd expect to see results like this in the Sample XML Schema Editor:
Note the content type is not null and the Semantics view shows how it's
a sequence that combines the local sequence and that of the base type.
I'm not sure what you've tried to do...
Ray wrote:
> Ed Merks wrote:
>> Ray,
>> x.getContent() will give you only the physically contained particle
>> with only the locally declared content. Similarly,
>> x.getAttributeUses() returns all the inherited and local attributes,
>> but x.getAttributeContents() returns only the locally declared ones.
>> I.e., you can view the model either abstractly or concretely and
>> abstract properties will say something like "This represents the ...
>> infoset property" whereas concrete properties will say something like
>> "This concrete reference represents ...". Be sure to choose the one
> holds true for attributes (AttributeUses returns all,
> AttributeContents only local), i find that for elements, while
> x.GetContent does contain the the local ones, x.GetContentType is
> empty - it doesn't even contain the local declarations.
> better certainly.
> Ray
Content-Type: multipart/related;
boundary="------------080603050704010309070905"
--------------080603050704010309070905
<html>
<head>
http-equiv="Content-Type">
</head>
Ray,<br>
<br>
For this schema:<br>
<blockquote><tt><small><?xml version="1.0" encoding="UTF-8"?></small><br>
<small><xsd:schema </small><br>
<small>
Re: Analysing Complex Types derived by extension [message #55089 is a reply to message #54961] |
Tue, 23 November 2004 15:59 |
> Note the content type is not null and the Semantics view shows how it's a
> sequence that combines the local sequence and that of the base type. I'm
Sorry for delay in responding - Indeed I was looking in the wrong place to
begin with, but your comments have pointed me to the right direction. When
analysing the subsequent XSDModelGroupDefinition, I was getting its
contents, and not its 'particles'. Once i got this list, i was able to look
through and find all the elements required. Thanks very much for your help!
Ray
Re: Analysing Complex Types derived by extension [message #62340 is a reply to message #55089] |
Tue, 05 July 2005 16:06 |
Originally posted by: sa840.soi.city.ac.uk
Hi all,
I have read this post, and I think I have a similar problem. I'm trying to
analize some complexType like the following one:
<complexType name="ScaleMapDefinition">
<complexContent>
<extension base="tns1:MapDefinitionType">
<sequence>
<element name="centerPoint" nillable="true"
type="tns3:GeoCoordinates"/>
</sequence>
</extension>
</complexContent>
</complexType>
I was using this code ("targetComplexDefinition" variable contains the
complexType):
xsdModelGroup = (XSDModelGroup)
targetComplexDefinition.getComplexType().getContent();
listOfElements = xsdModelGroup.getContents();
Iterator elementsIterator = listOfElements.iterator();
while(elementsIterator.hasNext())
XSDParticle elementParticle = (XSDParticle) elementsIterator.next();
XSDElementDeclaration element =
(XSDElementDeclaration)elementParticle.getContent();
It works when my complexType doesn't have an "extension" tag, but it doesn't
works when I manage a complexType with an "extension" tag. Can someone
explain me way? There is any way to access to all the elements of the
complexType (including those coming from the "extension")?. Sorry if this
question is so simple. But I really don't find how to do it.
Thanks in advance,
Fran
"Ray" <none@nonet.com> escribi
Re: Analysing Complex Types derived by extension [message #62364 is a reply to message #62340] |
Tue, 05 July 2005 16:29 |
--------------060405030508050601030404
Fran,
The getContent method returns the particle (for the model group)
physically present in that type definition. The getContentType returns
the logical/synthetic particle (if the type has complex content) and
that logical particle has a model group (sequence) that will include a
particle for the base class's contents and a particle for the content
contributed locally.
Fran wrote:
>Hi all,
> <complexContent>
> <sequence>
> </sequence>
> </extension>
> </complexContent>
> </complexType>
>complexType):
>Thanks in advance,
>Fran
Re: Analysing Complex Types derived by extension [message #62388 is a reply to message #62364] |
Tue, 05 July 2005 17:44 |
------=_NextPart_000_0157_01C58191.962F2400
charset="iso-8859-1"
Content-Transfer-Encoding: quoted-printable
Hi Ed,
I have tried to do something like this:
=20
XSDParticle complexTypeContent =3D=20
(XSDParticle) targetComplexDefinition.getContentType();
XSDModelGroup xsdModelGroup =3D=20
(XSDModelGroup)complexTypeContent.getContent();
listOfElements =3D xsdModelGroup.getContents();
Iterator elementsIterator =3D listOfElements.iterator();
XSDParticle elementParticle =3D=20
XSDElementDeclaration element =3D=20
Now, I use "getContentType", and from the particle, I try to retrieve
the sequence, in order to access to the "base" particle and the
"local" particle. But I recover wrong information. Do you know what=20
am I doing wrong?
Thank you very mucho for your help,
Fran
=20
Fran,
The getContent method returns the particle (for the model group) =
physically present in that type definition. The getContentType returns =
the logical/synthetic particle (if the type has complex content) and =
that logical particle has a model group (sequence) that will include a =
particle for the base class's contents and a particle for the content =
Fran wrote:=20
Hi all,
I have read this post, and I think I have a similar problem. I'm trying =
to=20
<complexType name=3D"ScaleMapDefinition">
<complexContent>
<extension base=3D"tns1:MapDefinitionType">
<sequence>
<element name=3D"centerPoint" nillable=3D"true"=20
type=3D"tns3:GeoCoordinates"/>
</sequence>
</extension>
</complexContent>
</complexType>
I was using this code ("targetComplexDefinition" variable contains the=20
complexType):
xsdModelGroup =3D (XSDModelGroup)=20
XSDParticle elementParticle =3D (XSDParticle) =
It works when my complexType doesn't have an "extension" tag, but it =
doesn't=20
works when I manage a complexType with an "extension" tag. Can someone=20
explain me way? There is any way to access to all the elements of the=20
complexType (including those coming from the "extension")?. Sorry if =
this=20
Thanks in advance,
Fran
"Ray" <none@nonet.com> escribi=F3 en el mensaje=20
news:cnvmsa$kft$1@www.eclipse.org...
Note the content type is not null and the Semantics view shows how =
it's a=20
sequence that combines the local sequence and that of the base type. =
I'm=20
Sorry for delay in responding - Indeed I was looking in the wrong =
place to=20
begin with, but your comments have pointed me to the right direction. =
When=20
analysing the subsequent XSDModelGroupDefinition, I was getting its=20
contents, and not its 'particles'. Once i got this list, i was able to=20
look through and find all the elements required. Thanks very much for =
your=20
help!
Ray
=20
=20
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 Transitional//EN">
<HTML><HEAD>
<META http-equiv=3DContent-Type =
content=3Dtext/html;charset=3DISO-8859-1>
<META content=3D"MSHTML 6.00.2900.2668" name=3DGENERATOR>
<STYLE></STYLE>
</HEAD>
<BODY text=3D#000000 bgColor=3D#ffffff>
<DIV><FONT face=3DArial size=3D2>Hi Ed,</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>I have tried to do something like=20
this:</FONT></DIV>
<DIV><FONT face=3DArial size=3D2> </FONT></DIV>
<DIV><FONT face=3DArial size=3D2> XSDParticle =
</FONT></DIV>
<DIV><FONT face=3DArial =
size=3D2> =20
(XSDParticle)=20
targetComplexDefinition.getContentType();<BR> XSDModelGr=
oup=20
xsdModelGroup =3D </FONT></DIV>
size=3D2> =20
(XSDModelGroup)complexTypeContent.getContent();<BR> =
</FONT><FONT=20
face=3DArial size=3D2>listOfElements =3D=20
xsdModelGroup.getContents();</FONT></DIV><FONT face=3DArial size=3D2>
<DIV><BR> Iterator elementsIterator =3D=20
listOfElements.iterator();<BR> while(elementsIterator.hasNext(=
))<BR> {</DIV>
<DIV> XSDParticle elementParticle =3D </DIV>
<DIV> =
(XSDParticle)=20
elementsIterator.next();<BR> XSDElementDeclaratio n=
=20
element =3D </DIV>
<DIV> =20
(XSDElementDeclaration)elementParticle.getContent();</DIV>
<DIV> .............</DIV>
<DIV> </DIV>
<DIV> </DIV>
<DIV>Now, I use "getContentType", and from the particle, =
I try to=20
retrieve</DIV>
<DIV>the sequence, in order to access to the "base" =
particle and=20
the</DIV>
<DIV>"local" particle. But I recover wrong information. Do you know =
what=20
</DIV>
<DIV>am I doing wrong?</DIV>
<DIV>Thank you very mucho for your help,</DIV>
<DIV>Fran<BR> </FONT ></DIV>
<BLOCKQUOTE=20
style=3D"PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; =
BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">Fran,<BR><BR>The=20
physically=20
present in that type definition. The getContentType returns the=20
logical/synthetic particle (if the type has complex content) and that =
logical=20
particle has a model group (sequence) that will include a particle for =
the=20
base class's contents and a particle for the content contributed=20
locally.<BR><BR><BR>Fran wrote:=20
<BLOCKQUOTE cite=3Dmiddaeb7o$ovn$1@news.eclipse.org type=3D"cite"><PRE =
wrap=3D"">Hi all,
to=20
<complexContent>
<sequence>
</sequence>
</extension>
</complexContent>
</complexType>
complexType):
doesn't=20
this=20
Thanks in advance,
Fran
"Ray" <A class=3Dmoz-txt-link-rfc2396E =
href=3D"mailto:none@nonet.com"><none@nonet.com></A> escribi=F3 en =
el mensaje=20
<A class=3Dmoz-txt-link-freetext =
href=3D"news:cnvmsa$kft$1@www.eclipse.org">news:cnvmsa$kft$1@www.eclipse.=
org</A>...
</PRE>
<BLOCKQUOTE type=3D"cite">
<BLOCKQUOTE type=3D"cite"><PRE wrap=3D"">Note the content type is =
not null and the Semantics view shows how it's a=20
I'm=20
</PRE></BLOCKQUOTE><PRE wrap=3D"">Sorry for delay in responding - =
Indeed I was looking in the wrong place to=20
When=20
your=20
help!
Ray
</PRE></BLOCKQUOTE><PRE wrap=3D""><!---->
</PRE></BLOCKQUOTE><BR></BLOCKQUOTE></BODY></HTML>
------=_NextPart_000_0157_01C58191.962F2400--
Re: Analysing Complex Types derived by extension [message #62412 is a reply to message #62388] |
Tue, 05 July 2005 17:50 |
--------------040608040103060607030300
Fran,
I would imagine that you will get class cast exceptions because the
particles of the top level synthetic particle can refer to XSDModelGroup
(or XSDWildcard) not just XSDElementDeclaration. Only the top level
particle's content is guaranteed to be an XSDModelGroup; everywhere else
you'd better be prepared to deal with the more general cases. I think
you really need a recursive algorithm to do this properly.
Fran wrote:
> Hi Ed,
> am I doing wrong?
> Fran
> Fran,
> returns the logical/synthetic particle (if the type has complex
> content) and that logical particle has a model group (sequence)
> that will include a particle for the base class's contents and a
> particle for the content contributed locally.
> Fran wrote:
>>Hi all,
>> <complexContent>
>> <sequence>
>> </sequence>
>> </extension>
>> </complexContent>
>> </complexType>
>>complexType):
>>Thanks in advance,
>>Fran
Re: Analysing Complex Types derived by extension [message #62436 is a reply to message #62412] |
Tue, 05 July 2005 18:26 |
------=_NextPart_000_0164_01C58197.809943E0
Hi again Ed,
I will try to explain with more detail the results I obtain. I'm using =
this code in an recursive method and it works for all the <complexType> =
elements without problems, except for the ones including an <extension> =
tag.
Now, l will try to trace for you the execution of the program:
Step 1. As input, the complexType "targetComplexDefinition"=20
is the following:
<complexContent>
<sequence>
<element name=3D"centerPoint" type=3D"tns3:GeoCoord"/>
<element name=3D"pixelSize" type=3D"xsd:double"/>
</sequence>
</extension>
</complexContent>
</complexType>
Step 2. The program proceed without error until the arrow I have writen:
------> XSDParticle elementParticle =3D=20
Step 3. And then, and suddendly, the input of the method =
(targetComplexDefinition)
(you can see at step 1) changes to the following value:
<complexType name=3D"MapRequest">
<sequence>
<element name=3D"itiTrace" nillable=3D"true" =
type=3D"tns2:ItineraryTrace"/>
<element name=3D"mapDefinition" nillable=3D"true" =
type=3D"tns1:ScaleMapDefinition"/>
</sequence>
</complexType>
As you see, this complexType contains an element called =
"tns1:ScaleMapDefinition", which
is the original input.
Believe me. I really don't understand what's happen... I hope this post =
would be clear enough=20
so you could help me.
Thank you very much,
Fran
--=20
__________________________________________
Francisco Sanchez Cid, Research Assistant
Department of Computing
City University
Northampton Square, London, EC1V 0HB
e-mail: F.Sanchez-Cid@soi.city.ac.uk
T (+44) 020 7040 4042
F (+44) 020 7040 0244
"Ed Merks" <merks@ca.ibm.com> escribi=F3 en el mensaje =
news:daeha7$1cl$1@news.eclipse.org...
Fran,
I would imagine that you will get class cast exceptions because the =
particles of the top level synthetic particle can refer to XSDModelGroup =
(or XSDWildcard) not just XSDElementDeclaration. Only the top level =
particle's content is guaranteed to be an XSDModelGroup; everywhere else =
you'd better be prepared to deal with the more general cases. I think =
=20
Fran wrote:=20
Hi Ed,
=20
Now, I use "getContentType", and from the particle, I try to =
retrieve
am I doing wrong?
Fran
=20
Fran,
Fran wrote:=20
Hi all,
to=20
<complexContent>
<sequence>
</sequence>
</extension>
</complexContent>
</complexType>
complexType):
doesn't=20
this=20
Thanks in advance,
Fran
it's a=20
I'm=20
place to=20
When=20
your=20
help!
Ray
=20
=20
<HTML><HEAD>
<META content=3D"MSHTML 6.00.2900.2668" name=3DGENERATOR></HEAD>
<DIV><FONT face=3DArial size=3D2>Hi again Ed,</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>I will try to explain with more detail =
the results=20
I obtain. I'm using this code in an recursive method and it works for =
all the=20
<complexType> elements without problems, except for the ones =
including an=20
<extension> tag.</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Now, l will try to trace for you the =
execution of=20
the program:</FONT></DIV>
<DIV><FONT face=3DArial size=3D2></FONT> </DIV>
<DIV><FONT face=3DArial size=3D2>Step 1. As input, the complexType=20
"targetComplexDefinition" </FONT></DIV>
<DIV><FONT face=3DArial=20
size=3D2> is =
the=20
following:</FONT></DIV>
<DIV><FONT face=3DArial size=3D2> <complexType=20
name=3D"ScaleMapDefinition"><BR> </=
FONT><FONT=20
face=3DArial=20
size=3D2><complexContent><BR> &n=
bsp;=20
<extension=20
base=3D"tns1:MapDefinitionType"><BR> &nbs=
p; =20
<sequence><BR>  =
; =20
<element name=3D"centerPoint"=20
type=3D"tns3:GeoCoord"/><BR> =
=20
<element name=3D"pixelSize"=20
type=3D"xsd:double"/><BR> &nb=
sp; =20
</sequence><BR> =20
</extension><BR> =20
</complexContent><BR> =
</complexType></FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Step 2. The program proceed without =
error until the=20
arrow I have writen:</FONT></DIV>
</FONT></DIV>
size=3D2> =20
(XSDParticle)=20
oup=20
size=3D2> =20
</FONT><FONT=20
xsdModelGroup.getContents();</FONT></DIV><FONT face=3DArial =
size=3D2></FONT>
<DIV><FONT face=3DArial size=3D2><BR> Iterator =
))<BR> {</FONT></DIV>
<DIV><FONT face=3DArial size=3D2> ------> =
XSDParticle=20
elementParticle =3D </FONT></DIV>
<DIV><FONT face=3DArial size=3D2> =20
(XSDParticle)=20
elementsIterator.next();<BR> &nb=
sp; =20
XSDElementDeclaration element =3D </FONT></DIV>
size=3D2> &nbs=
p; =20
(XSDElementDeclaration)elementParticle.getContent();</FONT> </DIV></FONT><=
/DIV>
<DIV><FONT face=3DArial size=3D2></FONT><FONT face=3DArial =
<DIV><FONT face=3DArial size=3D2>Step 3. And then, and suddendly, the =
input of the=20
method (targetComplexDefinition)</FONT></DIV>
size=3D2> =
(you can see=20
at step 1) </FONT><FONT face=3DArial size=3D2>changes to the =
following=20
value:</FONT></DIV>
name=3D"MapRequest"><BR> <=
sequence><BR> =20
<element name=3D"itiTrace" nillable=3D"true"=20
type=3D"tns2:ItineraryTrace"/><BR> =
=20
<element name=3D"mapDefinition" nillable=3D"true"=20
type=3D"tns1:ScaleMapDefinition"/><BR> &n=
bsp;=20
</sequence><BR> =
<DIV><FONT face=3DArial size=3D2>As you see, this complexType contains =
an element=20
called "tns1:ScaleMapDefinition", which</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>is the original input.</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Believe me. I really don't understand =
what's=20
happen... I hope this post would be clear enough </FONT></DIV>
<DIV><FONT face=3DArial size=3D2>so you could help me.</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Thank you very much,</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Fran</FONT><BR>--=20
<BR>__________________________________________</DIV>
<DIV> </DIV>
<DIV>Francisco Sanchez Cid, Research Assistant<BR>Department of=20
Computing<BR>City University<BR>Northampton Square, London, EC1V =
0HB<BR>e-mail:=20
<A=20
href=3D"mailto:F.Sanchez-Cid@soi.city.ac.uk">F.Sanchez-Cid@soi.city.ac.uk=
</A><BR>T=20
(+44) 020 7040 4042<BR>F (+44) 020 7040=20
0244<BR>__________________________________________</DIV>
<BLOCKQUOTE=20
<DIV>"Ed Merks" <<A =
href=3D"mailto:merks@ca.ibm.com">merks@ca.ibm.com</A>>=20
escribi=F3 en el mensaje <A=20
href=3D"news:daeha7$1cl$1@news.eclipse.org">news:daeha7$1cl$1@news.eclips=
e.org</A>...</DIV>Fran,<BR><BR>I=20
particles of=20
the top level synthetic particle can refer to XSDModelGroup (or =
XSDWildcard)=20
not just XSDElementDeclaration. Only the top level particle's =
content is=20
guaranteed to be an XSDModelGroup; everywhere else you'd better be =
prepared to=20
deal with the more general cases. I think you really need =
a=20
recursive algorithm to do this properly.<BR> <BR><BR>Fran wrote:=20
<BLOCKQUOTE cite=3Dmiddaegu4$rr$1@news.eclipse.org type=3D"cite">
<STYLE></STYLE>
this:</FONT></DIV>
</FONT></DIV>
size=3D2> =
(XSDParticle)=20
oup=20
size=3D2> =20
</FONT><FONT=20
size=3D2></FONT>
elementParticle=20
=3D </FONT></DIV>
size=3D2> =20
(XSDParticle)=20
=20
size=3D2> =20
size=3D2> .............</FONT ></DIV>
<DIV><FONT face=3DArial size=3D2>Now, =
I use "getContentType", and from=20
the particle, I try to retrieve</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>the sequence, in order =
to access to=20
the "base" particle and the</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>"local" particle. But I recover =
wrong=20
information. Do you know what </FONT></DIV>
<DIV><FONT face=3DArial size=3D2>am I doing wrong?</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Thank you very mucho for your=20
help,</FONT></DIV>
size=3D2>Fran<BR> </FONT></DIV>
<BLOCKQUOTE=20
BORDER-LEFT: rgb(0,0,0) 2px solid; MARGIN-RIGHT: 0px">Fran,<BR><BR>The=20
physically=20
the=20
that=20
particle=20
contributed=20
<BLOCKQUOTE cite=3Dmiddaeb7o$ovn$1@news.eclipse.org =
type=3D"cite"><PRE wrap=3D"">Hi all,
to=20
<complexContent>
<sequence>
</sequence>
</extension>
</complexContent>
</complexType>
complexType):
doesn't=20
this=20
Thanks in advance,
Fran
el mensaje=20
org</A>...
</PRE>
<BLOCKQUOTE type=3D"cite"><PRE wrap=3D"">Note the content type =
is not null and the Semantics view shows how it's a=20
I'm=20
When=20
your=20
help!
Ray
</PRE></BLOCKQUOTE><BR></BLOCKQUOTE></BLOCKQUOTE><BR></BLOCKQUOTE ></BODY>=
</HTML>
------=_NextPart_000_0164_01C58197.809943E0--
Re: Analysing Complex Types derived by extension [message #62461 is a reply to message #62436] |
Tue, 05 July 2005 18:37 |
--------------000505000002030500060606
Fran,
What you describe is exactly what I expect. That is, if you get
ScaleMapDefinitions's content type, look at that particle's model
group's first particle, that particle will be exactly the same particle
as you get for MapRequest's content type. In other words, the content
type of an extended complex type reuses (refers to) the content type of
the base type.
Fran wrote:
> Hi again Ed,
> <complexType> elements without problems, except for the ones including
> an <extension> tag.
> is the following:
> <complexContent>
> <sequence>
> <element name="centerPoint" type="tns3:GeoCoord"/>
> <element name="pixelSize" type="xsd:double"/>
> </sequence>
> </extension>
> </complexContent>
> </complexType>
> <complexType name="MapRequest">
> <sequence>
> <element name="itiTrace" nillable="true"
> type="tns2:ItineraryTrace"/>
> <element name="mapDefinition" nillable="true"
> type="tns1:ScaleMapDefinition"/>
> </sequence>
> </complexType>
> Fran
> City University
> e-mail: F.Sanchez-Cid@soi.city.ac.uk <mailto:F.Sanchez-Cid@soi.city.ac.uk>
> "Ed Merks" <merks@ca.ibm.com <mailto:merks@ca.ibm.com>> escribi
Re: Analysing Complex Types derived by extension [message #62485 is a reply to message #62461] |
Wed, 06 July 2005 09:56 |
------=_NextPart_000_0017_01C58219.4D1B8690
Ed,
I thought the base type for "ScaleMapDefitinion" was =
"tns1:MapDefinitionType".......:
<complexContent>
----- > <extension base=3D"TNS1:MapDefinitionType">
<sequence>
</sequence>
</extension>
</complexContent>
</complexType>
.........And not "MapRequest". But reading your response, I see I was =
wrong.
Nevertheless, is there any way to obtain the elements in the sequence in =
"ScaleMapDefinition" complexType? In other words, I'm talking about =
obtaining a List, collection or whatever, containing:
=20
AND
<element name=3D"heightInPixels" type=3D"xsd:int"/>
<element name=3D"weightInPixels" type=3D"xsd:int"/>
(Obviously, the last two elements come from the base of the <extension> =
tag, that is:=20
<complexType name=3D"MapDefinitionType">
<sequence>
</sequence>
<complexType/>)
Thanks a lot for your help,
Fran
--=20
news:daek1p$4sb$1@news.eclipse.org...
Fran,
What you describe is exactly what I expect. That is, if you get =
ScaleMapDefinitions's content type, look at that particle's model =
group's first particle, that particle will be exactly the same particle =
as you get for MapRequest's content type. In other words, the content =
type of an extended complex type reuses (refers to) the content type of =
the base type.
Fran wrote:=20
Hi again Ed,
I will try to explain with more detail the results I obtain. I'm =
using this code in an recursive method and it works for all the =
<complexType> elements without problems, except for the ones including =
an <extension> tag.
is the following:
<complexContent>
<sequence>
</sequence>
</extension>
</complexContent>
</complexType>
Step 2. The program proceed without error until the arrow I have =
writen:
<sequence>
</sequence>
</complexType>
Believe me. I really don't understand what's happen... I hope this =
post would be clear enough=20
Fran
--=20
<HTML><HEAD>
<STYLE></STYLE>
</HEAD>
<DIV><FONT face=3DArial size=3D2>Ed,</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>I thought the base type for =
"ScaleMapDefitinion"=20
was "tns1:MapDefinitionType".......:</FONT></DIV>
<DIV><FONT face=3DArial size=3D2><complexType=20
FONT><FONT=20
face=3DArial size=3D2><complexContent><BR>----- > <extension =
base=3D"TNS1:MapDefinitionType"><BR> &nbs=
p; =20
<sequence><BR>  =
; =20
=20
sp; =20
</sequence><BR> =20
<DIV><FONT face=3DArial size=3D2>........And not "MapRequest". But =
reading your=20
response, I see I was wrong.</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Nevertheless, is there any way to =
obtain the=20
elements in the sequence in "ScaleMapDefinition" complexType? In other =
words,=20
I'm talking about obtaining a List, collection or whatever,=20
containing:</FONT></DIV>
size=3D2> &nbs=
p;=20
</FONT></DIV>
=20
<element name=3D"pixelSize" type=3D"xsd:double"/></FONT></DIV>
AND</FONT></DIV>
size=3D2> &nbs=
p; <element=20
name=3D"heightInPixels"=20
type=3D"xsd:int"/><BR> =
=20
<element name=3D"weightInPixels" type=3D"xsd:int"/></FONT></DIV>
<DIV><FONT face=3DArial size=3D2>(Obviously, the last two elements come =
from the=20
base of the <extension> tag, that is: </FONT></DIV>
name=3D"MapDefinitionType"></FONT><FONT face=3DArial=20
size=3D2><BR> =20
<sequence><BR>  =
; =20
<element name=3D"heightInPixels"=20
=20
size=3D2> =20
</sequence></FONT></DIV>
<DIV><FONT face=3DArial><FONT=20
size=3D2> <complexType/ >) </FONT></FONT></DIV=
<DIV><FONT face=3DArial size=3D2>Thanks a lot for your =
help,</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Fran</FONT></DIV>
<DIV><BR>-- <BR>"Ed Merks" <<A=20
href=3D"mailto:merks@ca.ibm.com">merks@ca.ibm.com</A>> escribi=F3 en =
el mensaje=20
<A=20
href=3D"news:daek1p$4sb$1@news.eclipse.org">news:daek1p$4sb$1@news.eclips=
e.org</A>...</DIV>
<BLOCKQUOTE=20
BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">Fran,<BR><BR>What=20
you describe is exactly what I expect. That is, if you get=20
group's=20
first particle, that particle will be exactly the same particle as you =
get for=20
MapRequest's content type. In other words, the content type of =
an=20
extended complex type reuses (refers to) the content type of the base=20
type.<BR><BR><BR>Fran wrote:=20
<BLOCKQUOTE cite=3Dmiddaejdh$3vt$1@news.eclipse.org type=3D"cite">
<DIV><FONT face=3DArial size=3D2>I will try to explain with more =
detail the=20
results I obtain. I'm using this code in an recursive method and it =
works=20
for all the <complexType> elements without problems, except =
for the=20
ones including an <extension> tag.</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Now, l will try to trace for you =
the execution=20
of the program:</FONT></DIV>
<DIV> </DIV>
size=3D2> is =
the=20
FONT><FONT=20
face=3DArial=20
bsp;=20
<extension=20
p; =20
<sequence><BR>  =
; =20
=20
sp; =20
</sequence><BR> =20
</complexContent><BR> =20
<DIV> </DIV>
error until=20
the arrow I have writen:</FONT></DIV>
<DIV> </DIV>
</FONT></DIV>
size=3D2> =
(XSDParticle)=20
oup=20
size=3D2> =20
</FONT><FONT=20
face=3DArial size=3D2>listOfElements =3D =
XSDParticle=20
size=3D2> =20
(XSDParticle)=20
sp; =20
size=3D2> &nbs=
p; =20
/DIV>
<DIV> </DIV>
<DIV><FONT face=3DArial size=3D2>Step 3. And then, and suddendly, =
the input of=20
the method (targetComplexDefinition)</FONT></DIV>
size=3D2> =
(you can=20
see at step 1) </FONT><FONT face=3DArial size=3D2>changes to =
the following=20
value:</FONT></DIV>
<DIV> </DIV>
sequence><BR> =20
=20
bsp;=20
</sequence><BR> =
<DIV> </DIV>
<DIV><FONT face=3DArial size=3D2>As you see, this complexType =
contains an=20
element called "tns1:ScaleMapDefinition", which</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Believe me. I really don't =
understand what's=20
<BR></DIV></BLOCKQUOTE></BLOCKQUOTE></BODY></HTML>
------=_NextPart_000_0017_01C58219.4D1B8690--
Re: Analysing Complex Types derived by extension [message #62522 is a reply to message #62485] |
Wed, 06 July 2005 10:54 |
--------------000702020309080105090901
Fran,
You are only showing me tiny little snips of your schemas (and of of
your code) so I just assumed when you showed me the second type that is
was the base of the first type. I see that it isn't. I think so far
you've essentially asked the same question three times and you've
asserted odd things like you've recovered wrong information and that
suddenly the input of the method changed, but none of that is really
helping clarify what you are actually doing and if anything serves to
confuse things further. I've told you that you can't blindly assume the
the content of the particle is an element, but you show the same code
again a second time without change. I don't get it...
I'm not a patient person and I don't want to repeat what I've already
said, so here goes one last attempt. The content model of a complex
type is a tree of particles, where the getContent() of each particle can
be an element declaration, a model group, a wildcard, or a model group
definition, and the getTerm() of each particle, which resolves element
references and model group definition references, can be an element
declaration, a model group, or a wildcard. If you want to walk the
concrete/physical structure as it appears in the source schema, you can
walk the complex type's getContent and the particle's getContent; if you
want to walk the abstract/logical structure as defined in the XML Schema
specification, you can walk the complex type's getContentType() and the
particle's getTerm(). That's all there is and those methods are
sufficient for all your purposes, so it's best to figure out how to make
those work and if you have a problem to show clearly and precisely all
the code you are executing and all the the schema constructs being
analyzed, not just snips and bits. The bottom line is that there is no
flat list of all the elements, there is only a tree and you must walk it
recursively.
Fran wrote:
> Ed,
> <complexContent>
> ----- > <extension base="TNS1:MapDefinitionType">
> <sequence>
> </sequence>
> </extension>
> </complexContent>
> </complexType>
> wrong.
> in "ScaleMapDefinition" complexType? In other words, I'm talking about
> AND
> <element name="heightInPixels" type="xsd:int"/>
> <element name="weightInPixels" type="xsd:int"/>
> <complexType name="MapDefinitionType">
> <sequence>
> </sequence>
> <complexType/>)
> Fran
Re: Analysing Complex Types derived by extension [message #592543 is a reply to message #54850] |
Ed Merks Messages: 33140 Registered: July 2009 |
Ray,
Ray wrote:
> Hi there,
> definitions.
> or is it a flaw?
> <xs:sequence>
> </xs:sequence>
> </xs:complexType>
> <xs:complexContent>
> <xs:sequence>
> </xs:sequence>
> </xs:extension>
> </xs:complexType>
> <xs:complexContent>
> </xs:extension>
> </xs:complexType>
> Ray
Ed Merks
Re: Analysing Complex Types derived by extension [message #592558 is a reply to message #54904] |
Ray Messages: 9 Registered: July 2009 |
Ed Merks wrote:
> Ray,
declarations.
certainly.
Ray
Re: Analysing Complex Types derived by extension [message #592568 is a reply to message #54930] |
Ray,
For this schema:
<xsd:schema
<xsd:sequence>
</xsd:sequence>
</xsd:complexType>
<xsd:sequence>
</xsd:sequence>
</xsd:extension>
</xsd:complexType>
</xsd:schema>
Ray wrote:
> Ed Merks wrote:
>> Ray,
> better certainly.
> Ray
<html>
<head>
</head>
Ray,<br>
<br>
<small>
Ed Merks
Re: Analysing Complex Types derived by extension [message #595978 is a reply to message #55089] |
Hi all,
<complexContent>
<sequence>
</sequence>
</extension>
</complexContent>
</complexType>
complexType):
Thanks in advance,
Fran
Re: Analysing Complex Types derived by extension [message #595990 is a reply to message #62340] |
Fran,
Fran wrote:
>Hi all,
> <complexContent>
> <sequence>
> </sequence>
> </extension>
> </complexContent>
> </complexType>
>complexType):
>Thanks in advance,
>Fran
Ed Merks
Re: Analysing Complex Types derived by extension [message #595999 is a reply to message #62364] |
Hi Ed,
=20
am I doing wrong?
Fran
=20
Fran,
Fran wrote:=20
Hi all,
to=20
<complexContent>
<sequence>
</sequence>
</extension>
</complexContent>
</complexType>
complexType):
doesn't=20
this=20
Thanks in advance,
Fran
it's a=20
I'm=20
place to=20
When=20
your=20
help!
Ray
=20
=20
<HTML><HEAD>
<STYLE></STYLE>
</HEAD>
this:</FONT></DIV>
</FONT></DIV>
size=3D2> =20
(XSDParticle)=20
oup=20
size=3D2> =20
</FONT><FONT=20
))<BR> {</DIV>
<DIV> =
(XSDParticle)=20
=20
element =3D </DIV>
<DIV> =20
<DIV> </DIV>
<DIV> </DIV>
I try to=20
retrieve</DIV>
particle and=20
the</DIV>
what=20
</DIV>
<BLOCKQUOTE=20
physically=20
logical=20
the=20
wrap=3D"">Hi all,
to=20
<complexContent>
<sequence>
</sequence>
</extension>
</complexContent>
</complexType>
complexType):
doesn't=20
this=20
Thanks in advance,
Fran
el mensaje=20
org</A>...
</PRE>
I'm=20
When=20
your=20
help!
Ray
Re: Analysing Complex Types derived by extension [message #596008 is a reply to message #62388] |
Fran,
Fran wrote:
> Hi Ed,
> am I doing wrong?
> Fran
> Fran,
> Fran wrote:
>>Hi all,
>> <complexContent>
>> <sequence>
>> </sequence>
>> </extension>
>> </complexContent>
>> </complexType>
>>complexType):
>>Thanks in advance,
>>Fran
Ed Merks
Re: Analysing Complex Types derived by extension [message #596022 is a reply to message #62412] |
Hi again Ed,
tag.
is the following:
<complexContent>
<sequence>
</sequence>
</extension>
</complexContent>
</complexType>
<sequence>
</sequence>
</complexType>
Fran
--=20
City University
Fran,
=20
Fran wrote:=20
Hi Ed,
=20
retrieve
am I doing wrong?
Fran
=20
Fran,
Fran wrote:=20
Hi all,
to=20
<complexContent>
<sequence>
</sequence>
</extension>
</complexContent>
</complexType>
complexType):
doesn't=20
this=20
Thanks in advance,
Fran
it's a=20
I'm=20
place to=20
When=20
your=20
help!
Ray
=20
=20
<HTML><HEAD>
the results=20
all the=20
including an=20
execution of=20
size=3D2> is =
the=20
FONT><FONT=20
face=3DArial=20
bsp;=20
<extension=20
p; =20
<sequence><BR>  =
; =20
=20
sp; =20
</sequence><BR> =20
error until the=20
</FONT></DIV>
size=3D2> =20
(XSDParticle)=20
oup=20
size=3D2> =20
</FONT><FONT=20
size=3D2></FONT>
XSDParticle=20
(XSDParticle)=20
sp; =20
size=3D2> &nbs=
p; =20
/DIV>
input of the=20
size=3D2> =
(you can see=20
following=20
value:</FONT></DIV>
sequence><BR> =20
=20
bsp;=20
</sequence><BR> =
an element=20
what's=20
<DIV> </DIV>
0HB<BR>e-mail:=20
<A=20
</A><BR>T=20
<BLOCKQUOTE=20
particles of=20
XSDWildcard)=20
content is=20
prepared to=20
a=20
<STYLE></STYLE>
this:</FONT></DIV>
</FONT></DIV>
size=3D2> =
(XSDParticle)=20
oup=20
size=3D2> =20
</FONT><FONT=20
size=3D2></FONT>
elementParticle=20
=3D </FONT></DIV>
size=3D2> =20
(XSDParticle)=20
=20
size=3D2> =20
to access to=20
wrong=20
help,</FONT></DIV>
<BLOCKQUOTE=20
physically=20
the=20
that=20
particle=20
contributed=20
to=20
<complexContent>
<sequence>
</sequence>
</extension>
</complexContent>
</complexType>
complexType):
doesn't=20
this=20
Thanks in advance,
Fran
el mensaje=20
org</A>...
</PRE>
I'm=20
When=20
your=20
help!
Ray
</HTML>
Re: Analysing Complex Types derived by extension [message #596033 is a reply to message #62436] |
Fran,
the base type.
Fran wrote:
> Hi again Ed,
> an <extension> tag.
> is the following:
> <complexContent>
> <sequence>
> </sequence>
> </extension>
> </complexContent>
> </complexType>
> <sequence>
> </sequence>
> </complexType>
> Fran
> City University
Ed Merks
Re: Analysing Complex Types derived by extension [message #596044 is a reply to message #62461] |
Ed,
<complexContent>
<sequence>
</sequence>
</extension>
</complexContent>
</complexType>
wrong.
=20
AND
tag, that is:=20
<sequence>
</sequence>
<complexType/>)
Fran
--=20
Fran,
the base type.
Fran wrote:=20
Hi again Ed,
an <extension> tag.
is the following:
<complexContent>
<sequence>
</sequence>
</extension>
</complexContent>
</complexType>
writen:
<sequence>
</sequence>
</complexType>
Fran
--=20
<HTML><HEAD>
<STYLE></STYLE>
</HEAD>
FONT><FONT=20
p; =20
<sequence><BR>  =
; =20
=20
sp; =20
</sequence><BR> =20
reading your=20
obtain the=20
words,=20
size=3D2> &nbs=
p;=20
</FONT></DIV>
=20
AND</FONT></DIV>
size=3D2> &nbs=
p; <element=20
=20
from the=20
size=3D2><BR> =20
<sequence><BR>  =
; =20
=20
size=3D2> =20
help,</FONT></DIV>
el mensaje=20
<A=20
e.org</A>...</DIV>
<BLOCKQUOTE=20
group's=20
get for=20
an=20
detail the=20
works=20
for the=20
the execution=20
<DIV> </DIV>
size=3D2> is =
the=20
FONT><FONT=20
face=3DArial=20
bsp;=20
<extension=20
p; =20
<sequence><BR>  =
; =20
=20
sp; =20
</sequence><BR> =20
<DIV> </DIV>
error until=20
<DIV> </DIV>
</FONT></DIV>
size=3D2> =
(XSDParticle)=20
oup=20
size=3D2> =20
</FONT><FONT=20
XSDParticle=20
size=3D2> =20
(XSDParticle)=20
sp; =20
size=3D2> &nbs=
p; =20
/DIV>
<DIV> </DIV>
the input of=20
size=3D2> =
(you can=20
the following=20
value:</FONT></DIV>
<DIV> </DIV>
sequence><BR> =20
=20
bsp;=20
</sequence><BR> =
<DIV> </DIV>
contains an=20
Re: Analysing Complex Types derived by extension [message #596053 is a reply to message #62485] |
Fran,
recursively.
Fran wrote:
> Ed,
> <complexContent>
> <sequence>
> </sequence>
> </extension>
> </complexContent>
> </complexType>
> wrong.
> AND
> <sequence>
> </sequence>
> <complexType/>)
> Fran
Ed Merks
Current Time: Thu Apr 25 04:33:46 GMT 2024
Powered by FUDForum. Page generated in 0.05483 seconds
