Home » Eclipse Projects » Rich Client Platform (RCP) » multiple context menu's in one editor
multiple context menu's in one editor [message #544602] Sun, 04 July 2010 20:07 Go to next message
Henno Vermeulen is currently offline Henno VermeulenFriend
I have one (Form)editor with multiple TableViewers. I would like each TableViewer to have it's own context menu.
My menu's can contain commands such as "insert new row", "delete selection", etc...
I think it's not hard to do this in pure SWT with "low level" selection listeners, but I would like to do it the clean RCP way with commands and structured selections. (Actually I am not sure if I ever need another plugin to contribute commands, but it would be nice to have this possibility).
As described on this blog, I found out how to add a context menu to one TableViewer(s) and register it and it's structured selection with the editor so that plugins can contribute commands. Their handlers can then access the selection using
HandlerUtil.getCurrentSelection(event)
inside their execute method.
But in my case I have multiple TableViewers that should have their own commands and have their own selection. So I have these questions:
1. How can I contribute commands to one specific TableViewer but not to the others? Can I somehow change the
<menuContribution locationURI="popup:some.package.someditor">
to
<menuContribution locationURI="popup:some.package.someditor.someviewer">
2. When I write a handler for a command such as "insert new row" or "delete selected rows" or "call selected person" I will need access to the structured selection of the specific TableViewer and I need access to the WritableList in it's content provider to remove/add the new items. And what do I do when I need access to other data/methods that is only known by my specific editor? What is a clean way to get access to this information in the handler code?
Re: multiple context menu's in one editor [message #544629 is a reply to message #544602] Mon, 05 July 2010 06:34 Go to previous messageGo to next message
Daniel Krügler is currently offline Daniel KrüglerFriend
> selection", etc...
> possibility).
> As described
> http://www.ralfebert.de/blog/eclipsercp/commands_context_men u/, I found
> HandlerUtil.getCurrentSelection(event) inside their execute method.
> to
> <menuContribution locationURI="popup:some.package.someditor.someviewer">?
Yes, in fact the latter assumption is correct. You have to create a
MenuManager for each Table control (or whatever control you need a
context menu for) as described in the Link. You also need to invoke
the call to registerContextMenu, but this time you need the three-
parameter version:
void registerContextMenu(String menuId, MenuManager menuManager,
ISelectionProvider selectionProvider);
For the first parameter you need to provide a unique ID for each
viewer. This i9d needs to be used within the locationURI as you
assumed.
You don't need to invoke
getSite().setSelectionProvider(tableViewer);
because this would not only register one of the viewers as selection
provider.
Use HandlerUtil.getActiveEditor or HandlerUtil.getActivePart and
cast to your concrete Editor class - or even better: Let your editor
implement some specific interface that provides the functionality you
need and cast to the interface.
HTH & Greetings from Bremen,
Daniel Krügler
Re: multiple context menu's in one editor [message #544675 is a reply to message #544629] Mon, 05 July 2010 08:47 Go to previous messageGo to next message
Thank you, this seems to be exactly what I need, I will try it out. By the way, can you provide some tips on how I can find what you told me in the documentation so that I don't need to post?
I also like to keep our business-specific code as much decoupled from Eclipse RCP classes as I can so casting to an interface that provides what I need is a good idea.
Re: multiple context menu's in one editor [message #544708 is a reply to message #544675] Mon, 05 July 2010 10:01 Go to previous messageGo to next message
In fact it is documented in the Eclipse help, but sometimes not very
clear. E.g. by combining the information from
http://help.eclipse.org/galileo/index.jsp?topic=/org.eclipse .platform.doc.isv/reference/extension-points/org_eclipse_ui_ popupMenus.html
and of
http://help.eclipse.org/galileo/index.jsp?topic=/org.eclipse .platform.doc.isv/guide/workbench_cmd_menus.htm
You also find some descriptions in
http://www.eclipse.org/articles/viewArticle/ViewArticle2.htm l
(search for registerContextMenu)
Daniel Krügler
Re: multiple context menu's in one editor [message #544754 is a reply to message #544675] Mon, 05 July 2010 12:35 Go to previous message
Ok it works! Without setting the selection provider on the entire site,
returns null.
But I found out that
HandlerUtil.getActiveMenuSelection(event)
Returns the selection of the ISelectionProvider (TableViewer) I associated with the popup menu.
But how can I properly re-use this command from a button inside my editor? Then the popup menu will not be active. I think I'll just solve this by making a "removeSelectedConcreteObject" method in my editor...
[Updated on: Mon, 05 July 2010 12:45]
Report message to a moderator
Previous Topic:hyperlinkDetectors and hyperlinkDetectorTargets
Next Topic:Adding new icon to Title Bar
Current Time: Wed Dec 07 10:28:17 GMT 2022
Powered by FUDForum. Page generated in 0.02601 seconds
