Home » Eclipse Projects » Equinox » p2 update mechanism broken after migrating to Helios
p2 update mechanism broken after migrating to Helios [message #544484] Fri, 02 July 2010 19:50 Go to next message
Eric Jain is currently offline Eric JainFriend
After migrating from Eclipse 3.5 to 3.6 the p2-enabled update in our RCP application no longer works.
On start-up there is a warning that "the update checker service is not initialized".
Help > Check for Updates fails with this message:
Could not locate the running profile instance. The eclipse.p2.data.area and eclipse.p2.profile properties may not be set correctly in this application's config.ini file.
Even Help > About > Installation Details fails with:
at org.eclipse.equinox.internal.p2.ui.ProvUIActivator.addProvisioningListener(ProvUIActivator.java:106)
at org.eclipse.equinox.internal.p2.ui.dialogs.InstalledIUGroup.createViewer(InstalledIUGroup.java:75)
at org.eclipse.equinox.internal.p2.ui.dialogs.StructuredIUGroup.createGroupComposite(StructuredIUGroup.java:80)
at org.eclipse.equinox.internal.p2.ui.dialogs.InstalledIUGroup.<init>(InstalledIUGroup.java:51)
at org.eclipse.equinox.p2.ui.InstalledSoftwarePage.createControl(InstalledSoftwarePage.java:95)
at org.eclipse.ui.internal.about.InstallationDialog.tabSelected(InstallationDialog.java:274)
at org.eclipse.ui.internal.about.InstallationDialog.createContents(InstallationDialog.java:245)
at org.eclipse.jface.window.Window.create(Window.java:431)
at org.eclipse.jface.dialogs.Dialog.create(Dialog.java:1089)
at org.eclipse.jface.window.Window.open(Window.java:790)
at org.eclipse.ui.internal.dialogs.AboutDialog$1.run(AboutDialog.java:126)
at org.eclipse.ui.internal.dialogs.AboutDialog.buttonPressed(AboutDialog.java:121)
at ...
and:
at org.eclipse.equinox.internal.p2.ui.model.ProfileElement.getQueryable(ProfileElement.java:55)
at org.eclipse.equinox.internal.p2.ui.QueryProvider.getQueryDescriptor(QueryProvider.java:54)
at org.eclipse.equinox.internal.p2.ui.model.QueriedElement.fetchChildren(QueriedElement.java:102)
at org.eclipse.equinox.internal.p2.ui.model.RemoteQueriedElement.fetchDeferredChildren(RemoteQueriedElement.java:34)
at org.eclipse.ui.progress.DeferredTreeContentManager$1.run(DeferredTreeContentManager.java:235)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:54)
Any ideas? (Cross-posted from the RCP group, where p2 knowledge appears to be more scarce...)
Re: p2 update mechanism broken after migrating to Helios [message #544867 is a reply to message #544484] Mon, 05 July 2010 17:57 Go to previous messageGo to next message
Greg Pugh is currently offline Greg PughFriend
> initialized".
> Quote:
> at
> org.eclipse.equinox.internal.p2.ui.ProvUIActivator.addProvis ioningListener(ProvUIActivator.java:106)
> at
> org.eclipse.equinox.internal.p2.ui.dialogs.InstalledIUGroup. createViewer(InstalledIUGroup.java:75)
> at
> org.eclipse.equinox.internal.p2.ui.dialogs.StructuredIUGroup .createGroupComposite(StructuredIUGroup.java:80)
> at
> org.eclipse.equinox.internal.p2.ui.dialogs.InstalledIUGroup. <init>(InstalledIUGroup.java:51)
> at
> org.eclipse.equinox.p2.ui.InstalledSoftwarePage.createContro l(InstalledSoftwarePage.java:95)
> at
> org.eclipse.ui.internal.about.InstallationDialog.tabSelected (InstallationDialog.java:274)
> at
> org.eclipse.ui.internal.about.InstallationDialog.createConte nts(InstallationDialog.java:245)
> at org.eclipse.ui.internal.dialogs.AboutDialog$1.run(AboutDialo g.java:126)
> at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:70)
> at
> org.eclipse.ui.internal.dialogs.AboutDialog.buttonPressed(Ab outDialog.java:121)
> at ...
> and:
> at
> org.eclipse.equinox.internal.p2.ui.model.ProfileElement.getQ ueryable(ProfileElement.java:55)
> at
> org.eclipse.equinox.internal.p2.ui.QueryProvider.getQueryDes criptor(QueryProvider.java:54)
> at
> org.eclipse.equinox.internal.p2.ui.model.QueriedElement.fetc hChildren(QueriedElement.java:102)
> at
> org.eclipse.equinox.internal.p2.ui.model.RemoteQueriedElemen t.fetchDeferredChildren(RemoteQueriedElement.java:34)
> at
> org.eclipse.ui.progress.DeferredTreeContentManager$1.run(Def erredTreeContentManager.java:235)
I found that configuring start levels for some plugins in the .product
file seemed to solve this. Something like:
<configurations>
<plugin id="<my product>" autoStart="false" startLevel="5" />
<plugin id="org.eclipse.core.runtime" autoStart="true"
startLevel="4" />
<plugin id="org.eclipse.equinox.common" autoStart="true"
startLevel="2" />
<plugin id="org.eclipse.equinox.ds" autoStart="true"
startLevel="2" />
<plugin id="org.eclipse.equinox.simpleconfigurator"
autoStart="true" startLevel="1" />
</configurations>
Re: p2 update mechanism broken after migrating to Helios [message #545167 is a reply to message #544867] Tue, 06 July 2010 21:40 Go to previous messageGo to next message
Greg Pugh wrote on Mon, 05 July 2010 13:57
<configurations>
startLevel="4" />
startLevel="2" />
startLevel="2" />
</configurations>
I have all of these except org.eclipse.equinox.ds. Does anyone know if this bundle is a new requirement for the p2 update mechanism in 3.6?
[Updated on: Wed, 07 July 2010 18:41]
Report message to a moderator
Re: p2 update mechanism broken after migrating to Helios [message #545437 is a reply to message #545167] Wed, 07 July 2010 17:56 Go to previous messageGo to next message
Andrew Niefer is currently offline Andrew NieferFriend
Yes org.eclipse.equinox.ds is required by p2. There is not an explicit
dependency in the manifests so it won't get included by a "add required".
p2 really requires something to start all the required services, this is
done using ds, but if ds wasn't there things would work if someone else
started the services. This is why the dependency isn't explicit.
>> <configurations>
>> startLevel="4" />
>> startLevel="2" />
>> startLevel="2" />
>> </configurations>
> I have all off these except org.eclipse.equinox.ds. Does anyone know if
Re: p2 update mechanism broken after migrating to Helios [message #545479 is a reply to message #544867] Wed, 07 July 2010 23:29 Go to previous messageGo to next message
Eugene Ostroukhov is currently offline Eugene OstroukhovFriend
Thanks a lot. Worked like a charm.
Re: p2 update mechanism broken after migrating to Helios [message #549536 is a reply to message #545437] Tue, 27 July 2010 06:49 Go to previous messageGo to next message
Tobias Hoppenthaler is currently offline Tobias HoppenthalerFriend
I did all things suggested (i.e. adding ds, added startlevels in the .product file), but for me it did not work, My exported product still shows the same symptoms: telling me that it is not configured for update and giving me the same messages in the log. What could I possibly do wrong? I deleted the built files before I built again, to make sure that nothing of the old stuff would stay. PLEASE HELP!!!
Tobias
-- Tobias
Re: p2 update mechanism broken after migrating to Helios [message #551881 is a reply to message #545437] Mon, 09 August 2010 23:47 Go to previous messageGo to next message
Andrew Niefer wrote on Wed, 07 July 2010 13:56
When I add org.eclipse.equinox.ds to my product or launch config I get a bunch of missing dependency errors for various org.eclipse.equinox.internal.util.* packages ("event", "hash", "pool"...). Anyone else encountered that?
Re: p2 update mechanism broken after migrating to Helios [message #554285 is a reply to message #544484] Fri, 20 August 2010 21:46 Go to previous messageGo to next message
No real name is currently offline No real nameFriend
I had to run the "Product Configuration" wizard after making those start level changes to create so that the changes would actually be reflected in a product definition.
Re: p2 update mechanism broken after migrating to Helios [message #799579 is a reply to message #551881] Thu, 16 February 2012 03:31 Go to previous message
Alex Chen is currently offline Alex ChenFriend
put below line in config.ini, I've fixed the issue same with you.
osgi.bundles=org.eclipse.equinox.common@2:start,org.eclipse.update.configurator@3:start,org.eclipse.core.runtime@start,org.eclipse.equinox.ds@start
[Updated on: Thu, 16 February 2012 03:35]
Previous Topic:SWT and Equinox product export problems
Next Topic:"dropins" folder in RCP application
Current Time: Mon Jan 20 03:54:26 GMT 2025
Powered by FUDForum. Page generated in 0.05554 seconds
