Home » Archived » Riena » Unit testing "ordinary" IController implementations(What's the best way to unit test controller classes that don't extend SubModuleController?)
| Re: Unit testing "ordinary" IController implementations [message #543971 is a reply to message #543850] |
Thu, 01 July 2010 04:52   |
For those who care: Here's the infrastructure code (read: hack) I use to test my AbstractWindowController.
All my window controllers extend AbstractTestableWindowController, while all corresponding unit tests inherit from AbstractControllerTest.
Please note that this only a work-around for current shortcomings in Riena itself. Here's my wish-list to make this unnecessary in the future:
* AbstractWindowController.getRidget(...) should behave similar to NavigationNodeController<ISubModuleNode>.getRidget(...) when invoked from within a unit test; that is: generate the (mock) ridgets automatically at the time they're first requested.
* There should be an equivalent to AbstractSubModuleControllerTest that people could use to unit test their AbstractWindowController sub-classes.
* All relevant Riena classes should always check for null when calling getUIControl() on their ridgets (e.g. EmbeddedTitleBarRidget.dispose() or DefaultActionManager.activate() currently fail to do so).
package lu.kreios.mtg.client.controllers;
import java.lang.reflect.Modifier;
import org.eclipse.core.runtime.Assert;
import org.eclipse.riena.core.RienaStatus;
import org.eclipse.riena.internal.ui.ridgets.swt.ShellRidget;
import org.eclipse.riena.ui.ridgets.ClassRidgetMapper;
import org.eclipse.riena.ui.ridgets.IActionRidget;
import org.eclipse.riena.ui.ridgets.IRidget;
import org.eclipse.riena.ui.ridgets.IWindowRidget;
import org.eclipse.riena.ui.ridgets.controller.AbstractWindowController;
@SuppressWarnings("restriction")
public class AbstractTestableWindowController extends AbstractWindowController {
public static final String WINDOW_RIDGET = "windowRidget"; //$NON-NLS-1$
public AbstractTestableWindowController() {
// This becomes necessary due to the fact the EmbeddedTitleBarRidget fails
// to check for getUIControl() returning null when called in the scope of
// its dispose() method.
ClassRidgetMapper.getInstance().addMapping(IWindowRidget.class, ShellRidget.class);
public void addDefaultAction(IRidget focusRidget, IActionRidget action) {
// This becomes necessary due to the fact the DefaultActionManager fails
// its activate() method. We'll ignore this for now, since there's no
// chance of any unit test hitting the ENTER key after all.
@SuppressWarnings("unchecked")
public <R extends IRidget> R getRidget(Class<R> ridgetClazz, String id) {
R ridget = (R) getRidget(id);
if (ridget != null) {
return ridget;
if (RienaStatus.isTest()) {
try {
if (ridgetClazz.isInterface()
|| Modifier.isAbstract(ridgetClazz.getModifiers())) {
Class<R> mappedRidgetClazz = (Class<R>) ClassRidgetMapper
.getInstance().getRidgetClass(ridgetClazz);
if (mappedRidgetClazz != null) {
ridget = mappedRidgetClazz.newInstance();
Assert.isNotNull(
ridget,
"Could not find a corresponding implementation for " + ridgetClazz.getName() + " in " + ClassRidgetMapper.class.getName()); //$NON-NLS-1$ //$NON-NLS-2$
} else {
ridget = ridgetClazz.newInstance();
} catch (InstantiationException e) {
throw new RuntimeException(e);
} catch (IllegalAccessException e) {
addRidget(id, ridget);
return ridget;
public void setWindowRidget(IWindowRidget windowRidget) {
super.setWindowRidget(windowRidget);
public IWindowRidget getWindowRidget() {
return getRidget(IWindowRidget.class, WINDOW_RIDGET);
package lu.kreios.mtg.client.helpers;
import org.eclipse.core.databinding.observable.Realm;
import org.eclipse.jface.databinding.swt.SWTObservables;
import org.eclipse.riena.core.util.ReflectionUtils;
import org.eclipse.riena.internal.core.test.RienaTestCase;
import org.eclipse.riena.internal.core.test.collect.NonUITestCase;
import org.eclipse.riena.navigation.ui.controllers.SubModuleController;
import org.eclipse.riena.ui.ridgets.controller.IController;
import org.eclipse.riena.ui.ridgets.swt.uibinding.SwtControlRidgetMapper;
* Abstract class for testing controllers that do NOT themselves extend {@link SubModuleController}.
* In any other case, please consider using the standard {@link AbstractControllerTest} class from
* Riena itself.
@NonUITestCase
public abstract class AbstractControllerTest<C extends IController> extends RienaTestCase {
private C controller;
protected void setUp() throws Exception {
super.setUp();
System.getProperties().put(RienaStatus.RIENA_TEST_SYSTEM_PROPERTY, "true"); //$NON-NLS-1$
// only used to get the initial mappings
SwtControlRidgetMapper.getInstance();
Display display = Display.getDefault();
Realm realm = SWTObservables.getRealm(display);
assertNotNull(realm);
ReflectionUtils.invokeHidden(realm, "setDefault", realm); //$NON-NLS-1$
controller = createController();
controller.configureRidgets();
controller.afterBind();
protected void tearDown() throws Exception {
System.getProperties().put(RienaStatus.RIENA_TEST_SYSTEM_PROPERTY, "false"); //$NON-NLS-1$
super.tearDown();
protected C getController() {
return controller;
protected abstract C createController();
[Updated on: Thu, 01 July 2010 10:30] by Moderator
| Re: Unit testing "ordinary" IController implementations [message #544251 is a reply to message #543971] |
Fri, 02 July 2010 03:21  |
Hi Christian,
why dont you open a bug in Riena, create a patch for a general solution to test AbstractWindowControllers and attach
that patch to the bug......
Thats open source and you are right in the middle of it :-)
christian
Am 01.07.10 10:52, schrieb Christian Kesselheim:
> All my window controller extend AbstractTestableWindowController, while
> Riena itself. Here's my wish-list to make this workaround unnecessary in
> the future:
> people could use to unit test their AbstractWindowController.
> import org.eclipse.riena.ui.ridgets.controller.AbstractWindowContro ller;
> of // its dispose() method.
> ClassRidgetMapper.getInstance().addMapping(IWindowRidget.cla ss,
> ShellRidget.class);
> @Override
> of // its activate() method. We'll ignore this for now, since there's no
> return ridget;
> try {
> Assert.isNotNull(
> ridget,
> } else {
> return ridget;
> @Override
> @Override
> import org.eclipse.riena.navigation.ui.controllers.SubModuleControl ler;
> import org.eclipse.riena.ui.ridgets.swt.uibinding.SwtControlRidgetM apper;
> import org.eclipse.swt.widgets.Display;
> AbstractControllerTest} class from * Riena itself.
> @NonUITestCase
> @Override
> super.setUp();
> System.getProperties().put(RienaStatus.RIENA_TEST_SYSTEM_PRO PERTY,
> @Override
> super.tearDown();
> return controller;
| Re: Unit testing "ordinary" IController implementations [message #586197 is a reply to message #543971] |
Hi Christian,
christian
> the future:
> ShellRidget.class);
> @Override
> return ridget;
> try {
> Assert.isNotNull(
> ridget,
> } else {
> return ridget;
> @Override
> @Override
> @NonUITestCase
> @Override
> super.setUp();
> @Override
> super.tearDown();
> return controller;
Current Time: Sun Nov 02 11:58:39 EST 2025
Powered by FUDForum. Page generated in 0.04662 seconds
