Re: UML 2 GMF and Models Plugins [message #545557 is a reply to message #543597] |
Thu, 08 July 2010 08:34 |
Originally posted by: ralf.ellner.cs.fau.de
Fernando,
> Hi everyone. I'm trying to find the source code with the models of UML
> diagrams inside eclipse modeling version because I have to develop a set
> of plugins with a particular dsl and the elements need to be viewed like
> an UML profile. Any idea where i can find them?. I would like to reuse
> the models and part of the code and obtain ideas from there. Regards!
the plugin 'org.eclipse.uml2.diagram.def' contains the GMF source
models. However, this plugin is not included in the helios release at
the moment.
Best regards, Ralf
Re: UML 2 GMF and Models Plugins [message #552506 is a reply to message #543597] |
Thu, 12 August 2010 12:28 |
Kirsten M. Z. Messages: 132 Registered: July 2010 |
Hi Fernando,
may I ask if you have been successful in generating the "diagram code" and the editors using 'org.eclipse.uml2.diagram.def'?
I spent two day, trying many different versions of Uml2Tools and Eclipse (including Helios and Uml2Tool 0.9.2) without success. I also tried following an old tutorial (GMF cookbook) step by step, but I cannot generate anything!
Maybe, you had more luck?
Kirsten
[Updated on: Thu, 12 August 2010 14:32] Report message to a moderator
FUDForum. Page generated in 0.03107 seconds
