Re: -showsplash option does not work [message #543616 is a reply to message #543589] |
Wed, 30 June 2010 04:20 |
Yesterday I observed a similar issue:
To brand our Eclipse distro, I added a configuration plugin that uses
p2 touchpoints to change the -showsplash option:
instructions.configure=\
removeProgramArg(programArg:-showsplash);\
addProgramArg(programArg:-showsplash);\
addProgramArg(programArg:ch.netcetera.eclipse.configuration) ;
This configuration feature is then installed using p2director.
The eclipse.ini files get updated as I expect it, but the option only
works on win32, win32_64 and linux. Unfortunately, it does not work on
linux_64 and osx_64, despite the fact that p2 does not complain about
the touchpoint or any installation issue at all (plugin is present,
eclipse.ini is updated - it just does not show the splash.bmp from the
plugin stated in eclipse.ini).
Michael
Re: -showsplash option does not work [message #545156 is a reply to message #544853] |
Tue, 06 July 2010 19:33 |
In the case I described, the plugin containing the splash.bmp is
installed extracted (as a direcory under plugins). The issue is that it
works on win32, linux32, but doesn't on linux 64 bit and osx 64 bit.
The plugin and eclipse.ini are identical in all cases.
Any ideas about that?
Michael
FUDForum. Page generated in 0.03260 seconds
