qualifier substitution with revision number [message #543521] |
Tue, 29 June 2010 16:43 |
Alex Kravets Messages: 561 Registered: November 2009 |
I've been struggling to make qualifier substitution for revision number work using methods such as embedding credentials into rmap and using svn+ssh protocol. The last one I didn't even try because I cannot use this protocol at my location.
I am using local provider because that's what only works in my setup, using svn provider causes 'Authentication Cancelled' exception to be thrown. Are there any ways I can make revision for qualifier work? I remember Thomas mentioned that there could be possibility to use qualifier.replacement.*=generator:lastRevision using local providers, is that still planned? The other solution I see is to call an ant script that would do the replacement, but may be I don't see some other solution for this?
thanks for your help,
Alex
[Updated on: Tue, 29 June 2010 16:44] Report message to a moderator
FUDForum. Page generated in 0.02533 seconds
