Home » Language IDEs » ServerTools (WTP) » Galileo - Helios migration(Faceted project errors on conversion to Helios)
Galileo - Helios migration [message #543219] Mon, 28 June 2010 17:49 Go to next message
Steve Cohen is currently offline Steve CohenFriend
Member
(crossposted from JDT forum)
I am trying to migrate some workspaces (using jee, maven, etc.)
from Galileo to Helios.
I get all kinds of errors. The most serious appear to be "Faceted Project Problems":
Target runtime Apache Tomcat v6.0 is not defined.
Target runtime J2EE Runtime Library is not defined.
Implementation of project facet jst.java could not be found.
I don't know how to fix these because the familiar Project Properties settings for faceted projects no longer appear in Helios.
What is up with this and is there any documentation on how to port Galileo workspaces to Helios? I can't believe this wasn't thought of.
Re: Galileo - Helios migration [message #543250 is a reply to message #543219] Mon, 28 June 2010 19:50 Go to previous messageGo to next message
Konstantin Komissarchik is currently offline Konstantin KomissarchikFriend
There are no special steps required to port or migrate your workspace from Galileo to Helios. It sounds to me like you have a problem with your Helios install.
First, what did you install? The easiest install path is to get Eclipse IDE for Java EE developers. If you are trying to install from the update site, make sure to install all WST and JST features that you see.
- Konstantin
Re: Galileo - Helios migration [message #543274 is a reply to message #543250] Mon, 28 June 2010 21:51 Go to previous message
Member
I guess I didn't install everything I needed. All appears well now.
Thanks. And sorry for the cross-post. I really thought it wasn't a WTP issue.
Previous Topic:Helios JSDT validation bug?
Next Topic:My JSF libraries won't publish - Gallieo
Current Time: Thu Jul 29 10:26:52 GMT 2021
Powered by FUDForum. Page generated in 0.01870 seconds
