Trouble with proxy authentication with Linux [message #543123] |
Mon, 28 June 2010 13:26 |
Stefan Mising name Messages: 7 Registered: June 2010 Location: Germany |
Dear all,
I am using the latest version (helios) of eclipse for C++ development. I have the same versions on a Windows XP 32Bit system and a 64 Bit OpenSuse Linux.
I do not have direct access to internet, I have to use a proxy with authentication. The Windows XP system has no trouble with that configuration and I can access the update sites without any problem. But the Linux version has made some trouble.
I tried different configurations, started with the same settings as in the Windows case. But I can not access the internet because the authentication is not working. I tried the manual, native an direct settings. For the direct setting I get as expected always a timeout. But for the other cases I always get the message "HTTP Proxy Authentication Required".
This seems as the authentication was not been send to the proxy, although it had been configured.
After some research with google i added following lines to my eclipse.ini:
Quote: |
-Dorg.eclipse.ecf.provider.filetransfer.excludeContributors= org.eclipse.ecf.provider.filetransfer.httpclient
-Dhttp.proxyPort=80
-Dhttp.proxyHost=#Proxyname#
-Dhttp.proxyUser=#username#
-Dhttp.proxyPassword=#password#
-Dhttp.nonProxyHosts=localhost|127.0.0.1
But even this did not work, I got now new entries in the error log:
Quote: |
System property http.proxyHost has been set to #Proxyname# by an external source. This value will be overwritten using the values from the preferences
System property http.proxyPort has been set to 80 by an external source. This value will be overwritten using the values from the preferences
System property http.proxyUser has been set to #username# by an external source. This value will be overwritten using the values from the preferences
System property http.proxyPassword has been set to #Password# by an external source. This value will be overwritten using the values from the preferences
I do not have any idea how to proceed, perhaps anybody had the same problem and solved it. Thank you in advance!
Best regards
Stefan
P.S.: My Eclipse environment:
Quote: |
eclipse.buildId=I20100608-0911
java.version=1.6.0_0
BootLoader constants: OS=linux, ARCH=x86_64, WS=gtk, NL=de_DE
Framework arguments: -product org.eclipse.epp.package.linuxtools.product
Command-line arguments: -os linux -ws gtk -arch x86_64 -product org.eclipse.epp.package.linuxtools.product
FUDForum. Page generated in 0.02911 seconds
