Home » Eclipse Projects » Plugin Development Environment (PDE) » Custom Wizard Page Back Button Not Functional(Plugin Development, Custom Wizard)
Custom Wizard Page Back Button Not Functional [message #542738] Fri, 25 June 2010 18:35 Go to next message
David Hober is currently offline David HoberFriend
Greetings all,
I am working on developing a custom plugin for an organization. Part of the process involves a custom Wizard page.
Here's what I am currently experiencing:
The user goes to create a new project. They select the project type from the project category, and a new project wizard displays. If the user wishes, they can click the "Back" button and select a different project type.
However, clicking the "Back" button does take the user back to the Project selection page, but there is longer a list of project types to select from!
Testing this further, I quickly made a copy of the WizardNewProjectCreationPage class, used my copy as the wizard page to add to my wizard, and sure enough the back button works. I went through and started commenting code out left and right, and the back button still functioned as expected.
My custom WizardPage does extend WizardPage. Everything else is looking great except for this one detail.
At the very least, can someone point me in the direction of which class(es) are responsible for adding this "Back" button to the wizard page, as well as linking this button to the New Project Selection Wizard page?
Thanks :c)
Re: Custom Wizard Page Back Button Not Functional [message #542754 is a reply to message #542738] Fri, 25 June 2010 20:38 Go to previous messageGo to next message
To further aid anyone who feels so kind to help...
Here is some relevant code from my plugin project. The classes are very bare-bones, but they work. Again, I'm able to select my custom project from the New Selection wizard, and I get to my custom wizard (displaying my custom wizard page). However, clicking the back button will take me back to the New Selection wizard page, but no project types are listed.
Excerpt from plugin.xml:
<extension
point="org.eclipse.ui.newWizards">
<category
name="Organization Jobs"
id="Organization">
</category>
<wizard name=" Job"
category="Organization Jobs"
canFinishEarly="false"
class="NewWizard"
id="NewWizard"
project="true">
</wizard>
</extension>
My NewWizard class:
import org.eclipse.core.runtime.CoreException;
import org.eclipse.core.runtime.IConfigurationElement;
import org.eclipse.core.runtime.IExecutableExtension;
import org.eclipse.jface.viewers.IStructuredSelection;
import org.eclipse.jface.wizard.Wizard;
import org.eclipse.ui.INewWizard;
import org.eclipse.ui.IWorkbench;
public class NewWizard extends Wizard
implements INewWizard, IExecutableExtension
public boolean performFinish() {
return false;
public void init(IWorkbench workbench,
IStructuredSelection selection)
public void addPages()
addPage(new NewWizardPage("Test"));
public void setInitializationData(IConfigurationElement
config, String propertyName, Object data)
throws CoreException
My NewWizardPage class:
import org.eclipse.jface.wizard.WizardPage;
import org.eclipse.swt.widgets.Composite;
public class NewWizardPage extends WizardPage
protected NewRRDonnelleySpotJobWizardPage2(String pageName) {
super(pageName);
public void createControl(Composite parent) {
setControl(parent);
Re: Custom Wizard Page Back Button Not Functional [message #543093 is a reply to message #542754] Mon, 28 June 2010 11:38 Go to previous messageGo to next message
Prakash G.R. is currently offline Prakash G.R.Friend
> public class NewWizardPage extends WizardPage {
> @Override
> setControl(parent);
You shouldn't be passing the parent to setControl(). You should be
passing your own control there. Try creating a label or at least an
empty composite and then use it in setControl.
HTH
- Prakash
Platform UI Team, IBM
www.eclipse-tips.com
Re: Custom Wizard Page Back Button Not Functional [message #543108 is a reply to message #543093] Mon, 28 June 2010 12:27 Go to previous messageGo to next message
Prakash,
Thanks! I suspected it was something minor :c)
Re: Custom Wizard Page Back Button Not Functional [message #606188 is a reply to message #542754] Mon, 28 June 2010 11:38 Go to previous messageGo to next message
> @Override
> setControl(parent);
HTH
- Prakash
Re: Custom Wizard Page Back Button Not Functional [message #606193 is a reply to message #543093] Mon, 28 June 2010 12:27 Go to previous message
Prakash,
Previous Topic:Only show menu-contribution in selected view?
Next Topic:Problem launching Eclipse product
Current Time: Tue Apr 16 04:25:48 GMT 2024
Powered by FUDForum. Page generated in 0.33976 seconds
