| Failed to create lesson 5 [message #542730] |
Fri, 25 June 2010 14:09  |
I am new in RTSC and I tried to built lesson 5, but I am getting the following error:
C:\ProgramFiles\RTSC\examples\lesson5>xdc test
making package.mak (because of package.bld) ...
generating interfaces for package lesson5 (because package/package.xdc.inc is older than package.xdc) ...
configuring prog.x64P from package/cfg/prog_x64P.cfg ...
cl64P prog.c ...
cl64P package/cfg/prog_x64P.c ...
lnk64P prog.x64P ...
running prog.x64P ...
Hello World
configuring prog.x86GW from package/cfg/prog_x86GW.cfg ...
Warning: xdc.cfg.INCOMPATIBLE_TARGET_VERSION: current target 'gnu.targets.Mingw'
[1,0,3.4,5] is not compatible with targets used to build the following packages
; package gnu.targets.rts86GW [in C:/ProgramFiles/RTSC/Texas Instruments/xdctool
s_3_20_00_41/packages/gnu/targets/rts86GW/] was built using 'gnu.targets.Mingw'
[1,0,4.4,0]
cl86GW prog.c ...
cl86GW package/cfg/prog_x86GW.c ...
lnk86GW prog.x86GW ...
C:\ProgramFiles\RTSC\Texas Instruments\xdctools_3_20_00_41\packages\gnu\targets\
rts86GW\lib\gnu.targets.rts86GW.a86GW(xdc_init.o86GW):xdc_in it.cpp:(.eh_frame+0x
11): undefined reference to `__gxx_personality_v0'
collect2: ld returned 1 exit status
gmake.exe: *** [prog.x86GW] Error 1
Can you please help me to find the problem?
| Re: Failed to create lesson 5 [message #542766 is a reply to message #542730] |
Fri, 25 June 2010 19:15   |
On 6/25/2010 11:09 AM, mans.0987@gmail.com wrote:
> Hello,
> following error:
[snip]
> 'gnu.targets.Mingw'
> packages
> Instruments/xdctool
> 'gnu.targets.Mingw'
> [1,0,4.4,0]
This warning indicates that the package gnu.targets.rts86GW was built
using the 4.4.0 version of mingw gcc but you are using version 3.4.5.
Theere is a good chance that this package's pre-built libraries are
incompatible with your toolchain.
> cl86GW prog.c ...
This is a gcc linker error that results from trying to mix objects built
using different incompatible versions of gcc object files.
You can either upgrade your Mingw compiler to 4.4 or rebuild the
gnu.targets.rts86GW package using your existing compiler.
To rebuild the rts86GW package see
http://rtsc.eclipse.org/docs-tip/Working_with_xdc.runtime It may seem
strange that we document rebuilding xdc.runtime when you want to rebuild
gnu.targets.rts86GW, but the gnu.targets.rts86GW package exists simply
to build the source contained in xdc.runtime. This is how we can
support _any_ C compiler while at the same time providing pre-built
libraries that work for (at least some) users.
> Regards
FUDForum. Page generated in 0.47809 seconds
