Home » Eclipse Projects » Remote Application Platform (RAP) » [Discussion] RAP 1.4 planning
[Discussion] RAP 1.4 planning [message #542660] Fri, 25 June 2010 14:41 Go to next message
Hi community,
we're currently making plans for RAP 1.4.
There are some architectural improvements that are necessary to be able
to push RAP to new horizons (such as this one: [1]). But apart from
this, the new release should, as always, also bring some new features
and improvements.
Therefore, we'd like to start a discussion about the most wanted plan
items. Of course, our resources are limited and we have to focus on the
most important and technically doable items.
What are the features that you'd like to see in the next release? What
are your pain points? Ideas?
Cheers and thanks for your help,
the RAP Team
[1]
http://eclipsesource.com/blogs/2010/06/11/writing-ipadiphone ipod-applications-with-swt/
Re: [Discussion] RAP 1.4 planning [message #542735 is a reply to message #542660] Fri, 25 June 2010 18:26 Go to previous messageGo to next message
Here are the current top 5 bugs in bugzilla:
Keybindings in RAP: Votes: 14
https://bugs.eclipse.org/bugs/show_bug.cgi?id=282449
[upload] Graduate file upload widget: Votes: 11
https://bugs.eclipse.org/bugs/show_bug.cgi?id=190763
Session kill mechanism on browser close: Votes: 9
https://bugs.eclipse.org/bugs/show_bug.cgi?id=284273
Investigate support for Draw2D: Votes: 9
https://bugs.eclipse.org/bugs/show_bug.cgi?id=285397
Moveable/Draggable Views: Votes: 8
https://bugs.eclipse.org/bugs/show_bug.cgi?id=315680
All Open RAP bugs:
https:// bugs.eclipse.org/bugs/buglist.cgi?query_format=advanced;bug_ status=UNCONFIRMED;bug_status=NEW;bug_status=ASSIGNED;bug_st atus=REOPENED;bug_status=VERIFIED;product=RAP
Cast your votes on existing bugs and come up with some new ideas!
[Updated on: Fri, 25 June 2010 18:32] by Moderator
Report message to a moderator
Re: [Discussion] RAP 1.4 planning [message #542809 is a reply to message #542660] Sat, 26 June 2010 09:53 Go to previous messageGo to next message
The most important ones as I have seen:
1, Browser multi-tab support (The workaround there is not quite pragmatic);
2, Upload widget;
3, Vertical texts on widget;
4, Single source with Draw2d;
Thanks and Best Regards!
Yours: Tingel Christian~
Re: [Discussion] RAP 1.4 planning [message #542995 is a reply to message #542660] Mon, 28 June 2010 07:38 Go to previous messageGo to next message
Improvements for the tree widget would be nice. There are a lot of bugs related to it.
Niels
Re: [Discussion] RAP 1.4 planning [message #543018 is a reply to message #542995] Mon, 28 June 2010 08:41 Go to previous messageGo to next message
Niels Lippke wrote on Mon, 28 June 2010 09:38
Niels
I agree, I think in deed the Tree widget needs some reinplemting there are a lot of minor bugs that makes it look and feel difrent then the Tree Widget in RCP witch is not troublesome but in the end is not the goal of RAP.
I also think 1.4 should look in to updating the API's such as workbench etc. At the moment we work with 3.4 and I think upgrading such elements in the ends also improves the whole RAP experience. I don't know if its feasible to get all the functions but to gain the majority of such functions, makes the code reuse higher.
I also think the Upload widget and the War Deploy wizard will be a great addition to the whole RAP experience (from programmer view and from user view).
I think DrawD2 is an interesting feature but not something we should put every thing on. Upcoming technology like HTML5 don't have a enough penetration in company's just yet. Most company's use IE6 at the moment and I don't see that eny time soon unless Microsoft completely pulls the plug on that just yet. When it happens or if they implement HTML5 support in IE6 (witch still rules most of the browser market) I think DrawD2 will be a great adition.
Vertical text on widgets I think is only possible when we have Draw2d (that's how a.t.m. it works in Eclipse I think).
For the rest I think getting closer and closer to RCP functionality would be a good approach the problem is (for me) is that I don't know what is available and what is not. I often run in to it but I dont realy keep track. Maybe there should be some documentation on that 2.
With kind regards,
Martijn Cremer
Re: [Discussion] RAP 1.4 planning [message #543021 is a reply to message #542660] Mon, 28 June 2010 08:46 Go to previous messageGo to next message
Vote for:
1. Tree widget.
2. Keybindings.
Also it would be great if menu shortcut will be available. Discussion about this is presented here ( http://www.eclipse.org/forums/index.php?t=msg&goto=50302), but I didn't find an enhancement in BugZilla.
Re: [Discussion] RAP 1.4 planning [message #543044 is a reply to message #543021] Mon, 28 June 2010 09:45 Go to previous messageGo to next message
Yury wrote on Mon, 28 June 2010 10:46
Vote for:
1. Tree widget.
2. Keybindings.
You can always submit your own Enhancement request in BugZilla.
Re: [Discussion] RAP 1.4 planning [message #543060 is a reply to message #543018] Mon, 28 June 2010 10:16 Go to previous messageGo to next message
Hi.
A completely new tree is already in the works.
Should we do Draw2D, it would most likely run on IE6 using VML.
Greetings,
Tim
Re: [Discussion] RAP 1.4 planning [message #543067 is a reply to message #542809] Mon, 28 June 2010 10:28 Go to previous messageGo to next message
thanks for your input.
could you explain in a few words what you would expect from a solution?
> 2, Upload widget;
that's one of the highest voted bugs, we'll likely take care of it.
Can you explain your use case? How would you do this in SWT? Would the
transformation API in the GC help you?
Yes, that's a frequent request, but also a huge effort.
Regards, Ralf
Re: [Discussion] RAP 1.4 planning [message #543068 is a reply to message #542995] Mon, 28 June 2010 10:30 Go to previous messageGo to next message
> related to it.
> Regards, Niels
A new Tree is already in the making. See bug 309519: [Tree] New client
implementation for Tree
https://bugs.eclipse.org/bugs/show_bug.cgi?id=309519
I hope it will be available soon.
Regards, Ralf
Re: [Discussion] RAP 1.4 planning [message #543069 is a reply to message #543018] Mon, 28 June 2010 10:41 Go to previous messageGo to next message
Hi Martijn,
thanks for your thoughts. Regarding your last point, how would the
suggested documentation look like? Our reasoning so far is that
switching the target and looking at the compile errors is much more
efficient than studying a documentation.
Regards, Ralf
>> bugs related to it.
>> Regards, Niels
> goal of RAP.
> view).
> With kind regards,
> Martijn Cremer
Re: [Discussion] RAP 1.4 planning [message #543083 is a reply to message #542660] Mon, 28 June 2010 11:15 Go to previous messageGo to next message
I think theming and animations should be improved. In this area,
competing technologies have a plus.
This includes the development aspect (theming an app is not fun at the
moment because its very time consuming due to server restarts) as well
as the capabilities provided with animations.
Stefan.
Re: [Discussion] RAP 1.4 planning [message #543086 is a reply to message #543069] Mon, 28 June 2010 11:17 Go to previous messageGo to next message
Hi Ralf,
Well first off yeah, switching targets is a good way to find difference. And that's what I do al touch it could be made a bit more user friendly wouldn't hurt.
But that works great when your already working with the code. But when you start a project you plan it think up what you want in it from functionality point of view. At this stage your not working with the code just yet. So it would be nice to have a cheat sheet of what is available what's not.
So I think these options could be interesting:
  1. Quick Target switch, a simple drop down option menu in the Coolbar to switch targets faster. This would remove the Window -> Plugin Develpment -> Target platform interaction from the user end witch would make switching target platforms easier and more likely faster.
  2. The RAP/RCP validator, a simple validator that can be switch on when you create a project. This validator would (probebly at a push of the button you do not want it running constantly) validate the code against a another target (of your liking or set to default outside your normal target).
  3. Support matrix, a simple document that shows a matrix of API calls in the default RAP/RCP environment showing how far they are support (This would be in the Support documentation of RAP and searchable).
The switching target is not a real problem its more when you want to start a project you want to know what's possible and what's impossible just yet. No one can know all the functions of both platforms by hard they can have a good insight but knowing all is I think somting you do not want you want to know were you can look.
My suggestions are rough idea's and I hope they help.
With kind regards,
Martijn Cremer
Ralf Sternberg wrote on Mon, 28 June 2010 12:41
Hi Martijn,
Regards, Ralf
>> bugs related to it.
>> Regards, Niels
> goal of RAP.
> view).
> With kind regards,
> Martijn Cremer
Re: [Discussion] RAP 1.4 planning [message #543236 is a reply to message #543086] Mon, 28 June 2010 18:22 Go to previous messageGo to next message
Thanks Martijn,
we'll discuss the documentation again. Regarding your ideas for tooling
enhancements, I'm afraid that those tasks would withdraw too much
valuable time from real RAP development. But this area is perfectly
suited for contributions from the community!
BTW, there will be per-project targets in Eclipse 3.7. Maybe this
feature helps to avoid some of the target switches and makes single
sourcing easier.
Regards, Ralf
> Hi Ralf,
> wouldn't hurt.
> target). Support matrix, a simple document that shows a matrix of API
> With kind regards,
> Martijn Cremer
>> Hi Martijn,
>> Regards, Ralf
>> >> bugs related to it.
>> >> Regards, Niels
>> there
>> > goal of RAP.
>> workbench
>> great
>> user
>> > view).
>> should put
>> the
>> realy
>> > > With kind regards,
>> > > Martijn Cremer
Re: [Discussion] RAP 1.4 planning [message #543336 is a reply to message #542660] Tue, 29 June 2010 07:19 Go to previous messageGo to next message
I also stumbeled across the missing custom tooltip support. Don't know
wether this is hard work or not, but it would
a) improve single sourcing
b) make applications more conventient
Regards, Niels
Re: [Discussion] RAP 1.4 planning [message #543389 is a reply to message #542660] Tue, 29 June 2010 09:40 Go to previous messageGo to next message
Ralf,
Would the RAP protocol also enable to have a better Event handling? I mean at this moment the Event.doit boolean has no real meaning in Events seeing that the communication back to the interface of the user cant undo such an event. I see that the RAP protocol could fill this little gap.
Re: [Discussion] RAP 1.4 planning [message #543410 is a reply to message #542660] Tue, 29 June 2010 10:52 Go to previous messageGo to next message
Hi RAP Team,
here are my suggestions:
1. New Workbench Code of 3.6 to hide editors per perspective (I know it is
already in 3.5, but why implement 3.5 if
3.6 is already there?)
2. Moveable/Draggable Views
3. More enhancements and fixings on tree (but noticed that this is already
in work)
4. Session kill mechanism on browser close
We currently use the draft from bug 284273, which eliminates alot, but
not all cases.
5. Bug 256133, which sometimes cause probles in our app
6. All other bugs ;-)
That's it, at least for now :-)
Markus
"Ralf Sternberg" <rsternberg@eclipsesource.com> schrieb im Newsbeitrag
news:i02f61$ecf$1@build.eclipse.org...
> Hi community,
> and improvements.
> the RAP Team
> [1]
Re: [Discussion] RAP 1.4 planning [message #543443 is a reply to message #543044] Tue, 29 June 2010 13:12 Go to previous messageGo to next message
There are already bugs for all of these issues, please just vote for them:
309519: [Tree] New client implementation for Tree
282449: Keybindings in RAP
318310: Support for mnemonics
https://bugs.eclipse.org/bugs/show_bug.cgi?id=318310
Ben
>> Vote for:
>> 1. Tree widget.
>> 2. Keybindings.
Benjamin Muskalla | EclipseSource Karlsruhe
http://www.eclipsesource.com | http://twitter.com/eclipsesource
Re: [Discussion] RAP 1.4 planning [message #543444 is a reply to message #543083] Tue, 29 June 2010 13:13 Go to previous messageGo to next message
Would you please open a feature request for this? I'd love to see this
in the next RAP release wrt the new tooling ;)
> Regards,
> Stefan.
Re: [Discussion] RAP 1.4 planning [message #543453 is a reply to message #543389] Tue, 29 June 2010 13:19 Go to previous messageGo to next message
I don't think that the protocol helps with the problems behind the doit
flag. But in general, we support the doit flag as SWT does. Is there any
case where this doesn't work for you? If so, please check again with SWT
and open a bug if we missed it.
> Ralf,
Re: [Discussion] RAP 1.4 planning [message #543454 is a reply to message #543336] Tue, 29 June 2010 13:20 Go to previous messageGo to next message
Hi Niels,
with custom tooltip support, to what are you referring? JFace Tooltips
or better theming possibilities for the tooltips?
Either way, feel free to open feature requests.
Ben
Niels Lippke wrote:
> Regards, Niels
Re: [Discussion] RAP 1.4 planning [message #543460 is a reply to message #543444] Tue, 29 June 2010 13:52 Go to previous messageGo to next message
Sure:
313216: [Animation] animations dont't work with rounded corners
https://bugs.eclipse.org/bugs/show_bug.cgi?id=313216
313217: [Animation] extend hover effect
https://bugs.eclipse.org/bugs/show_bug.cgi?id=313217
314332: [Animations] Support hover in/out for composites
https://bugs.eclipse.org/bugs/show_bug.cgi?id=314332
Looking forward to the new tooling :-)
Stefan.
Re: [Discussion] RAP 1.4 planning [message #543528 is a reply to message #543067] Tue, 29 June 2010 17:06 Go to previous messageGo to next message
Hi, Ralf:
Sorry for my so late response~
I had a comment here before:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=285398
In my case(and probably in some other mates' cases), what we need is just the point.for example:users can start a session with a certain account logged in for some special work, and then open a new tab to start another session with a different account logged in to do some other works~~~
Yes, there is a solution there in the above url, but, I am sorry to say, it requires us to make some modification to the web container of our clients, however, we can not predict what web container will our client use. Jetty, Tomcat, Weblogic...too many options...So, we really wish that the problem could be solved from within the RAP framework itself.
I am sorry to say but I am not quite sure about the meaning of "the transformation API", could you please explain the name of the method?thanks!
According to the use case...Here is an example:
http://www.eettaiwan.com/STATIC/ARTICLE_IMAGES/200811/0811B_ DC4_F3.jpg
In this case, the letters are vertically layouted, and also, every letter there is rotated;
but there is another scene when we need to write East Asian characters there, the total string is required to be layouted vertically but every letter should not be rotated
I hope I expressed myself clearly... Razz
Ralf Sternberg wrote on Mon, 28 June 2010 18:28
> 2, Upload widget;
Regards, Ralf
[Updated on: Tue, 29 June 2010 17:08] by Moderator
Re: [Discussion] RAP 1.4 planning [message #543650 is a reply to message #543044] Wed, 30 June 2010 08:25 Go to previous messageGo to next message
Hi all,
Voted for
285397 Investigate support for Draw2D
309301 Provide a way to have one workspace per user
These 2 enhancementa are blocking for us. Having them implemented would open a new world to our app !
But I also understand they are not easy ones ;)
Mickael Istria - BonitaSoft S.A.
http://www.bonitasoft.com/products/downloads.php
Re: [Discussion] RAP 1.4 planning [message #543677 is a reply to message #543444] Wed, 30 June 2010 09:18 Go to previous messageGo to next message
Here's another suggestion:
318426: [theming] Improve process for defining and testing themes
https://bugs.eclipse.org/bugs/show_bug.cgi?id=318426
Stefan.
Re: [Discussion] RAP 1.4 planning [message #543689 is a reply to message #543454] Wed, 30 June 2010 09:51 Go to previous messageGo to next message
Sorry,
I meant JFace Tooltips and created Bug #318427 as an enhancement request.
Thanks, Niels
"Benjamin Muskalla" <bmuskalla@eclipsesource.com> schrieb im Newsbeitrag
news:i0crup$5eo$4@build.eclipse.org...
> Hi Niels,
> with custom tooltip support, to what are you referring? JFace Tooltips or
> Regards,
> Ben
> Niels Lippke wrote:
>> Hi,
>> Regards, Niels
Re: [Discussion] RAP 1.4 planning [message #543815 is a reply to message #542660] Wed, 30 June 2010 16:22 Go to previous messageGo to next message
I really really want RAP have the function of wrapping awt, so that I can use SWT_AWT to wrap the worldwind software into RAP. And I think the field EMBEDDED should be added into org.eclipse.swt.SWT class.
[Updated on: Wed, 30 June 2010 16:23] by Moderator
Re: [Discussion] RAP 1.4 planning [message #544011 is a reply to message #543528] Thu, 01 July 2010 10:32 Go to previous messageGo to next message
>>> pragmatic);
> other works~~~
There are two different issues. First, you don't want to tweak the
servlet container. You're right, another solution would be necessary to
allow tabbed browsing out of the box.
The second is that for your requirement (different logins in different
tabs), you would have to bind the login to the SessionStore, not to the
HttpSession (as you probably do already). This is possible with both
Stefan's and a potential out-of-the-box solution.
> method?thanks!
GC allows you to draw on a Canvas widget. With transformations, text can
also be rotated. See GC#setTransform() in SWT.
I think you should first think about how you could solve your problem
with SWT. If there are just a few vertical texts, images might be an
option. Otherwise GC seems to be the only way to go.
Best regards, Ralf
Re: [Discussion] RAP 1.4 planning [message #548545 is a reply to message #542660] Thu, 22 July 2010 10:12 Go to previous messageGo to next message
would it be possible to add multiline-support for tables? Our customer explicitly mentioned the need for multiline-entries in our RAP-project.
All entries in the different fora resulting in >>there's a workaround for swt but no way with actual rwt<<
(We solved it in a very ugly way with urgent need for improvement)
Thomas
Re: [Discussion] RAP 1.4 planning [message #548548 is a reply to message #548545] Thu, 22 July 2010 10:28 Go to previous messageGo to next message
I would like to see some investigation and progress concerning the StyledText.
Bug 277346 - StyledText is missing
https://bugs.eclipse.org/bugs/show_bug.cgi?id=277346
[Updated on: Thu, 22 July 2010 10:44] by Moderator
Re: [Discussion] RAP 1.4 planning [message #548776 is a reply to message #542660] Thu, 22 July 2010 23:21 Go to previous messageGo to next message
Hi, we have an ERP based on RCP for hotels and we're planning to make it available for smartphones as for browsers.
But it seems that RAP has issues with smartphones as this link http://old.nabble.com/%28multi-%29touch-panels,-iPhone,-iPad -et-cetera-td29215797.html quotes.
We would like to see more improvements regarding this.
[Updated on: Fri, 23 July 2010 00:34] by Moderator
Re: [Discussion] RAP 1.4 planning [message #548816 is a reply to message #548776] Fri, 23 July 2010 07:35 Go to previous messageGo to next message
Jesus Roberto Luna Quiroga wrote on Fri, 23 July 2010 01:21
Jesus,
I think the RAP protocol will make life easier, there is a blog post out there about using RAP on a Iphone ( http://eclipsesource.com/blogs/2010/06/11/writing-ipadiphone ipod-applications-with-swt/) witch shows promise. I don't know if the RAP team actually will focus on the Smartphones or first implement the RAP protocol etc..
Re: [Discussion] RAP 1.4 planning [message #548994 is a reply to message #542660] Fri, 23 July 2010 15:48 Go to previous messageGo to next message
Bug 320742 - Multiline-Support for Tables
https://bugs.eclipse.org/bugs/show_bug.cgi?id=320742
Bug 320745 - RTL (Right-To-Left) support
https://bugs.eclipse.org/bugs/show_bug.cgi?id=320745
[Updated on: Fri, 23 July 2010 15:53] by Moderator
Re: [Discussion] RAP 1.4 planning [message #549077 is a reply to message #542660] Sat, 24 July 2010 03:35 Go to previous messageGo to next message
Hi RAP Team,
How about to be able to run RAP JUnit headlessly ?
https://bugs.eclipse.org/bugs/show_bug.cgi?id=293751
Best Regards,
Setya
> Hi community,
> and improvements.
> the RAP Team
> [1]
Re: [Discussion] RAP 1.4 planning [message #549262 is a reply to message #548545] Mon, 26 July 2010 10:13 Go to previous messageGo to next message
Hi Thomas,
we cannot add functionality to RWT that does not exist in SWT.
The workaround for SWT is to draw the texts in the Table all by yourself
using a paint listener. From my point of view, this must be considered
rather a hack than a solution. Maybe this could even become possible
with RAP if we extends the GC support - however, I'd tend to use a
custom widget for RAP since I doubt that this hack would perform well.
Best regards, Ralf
Thomas wrote:
> Regards
> Thomas
Re: [Discussion] RAP 1.4 planning [message #549264 is a reply to message #548816] Mon, 26 July 2010 10:20 Go to previous messageGo to next message
we realize that support for mobile devices is getting more and more
important and decided to work on resolving bugs on those platforms. So
please simply open bugs for problems you experience, preferably
including snippets, screenshots, etc.
Regards, Ralf
> Jesus,
Re: [Discussion] RAP 1.4 planning [message #549349 is a reply to message #542660] Mon, 26 July 2010 13:42 Go to previous messageGo to next message
Hi all,
thanks for your input to our planning for the next release. Meanwhile,
we discussed our plans for 1.4 and would like to let you know about our
progress. Please note that this is only a preliminary plan, we didn't
make the final decision yet.
Here are the overall themes we'd like to address in RAP 1.4:
* Widget improvements and additions
As in every RAP release, we will improve our widget set. A new Tree
implementation is already in CVS. Non-native scrollbars would be another
improvement. There is a great demand for the upload widget, and we'd
like to integrate it into the release.
To support custom widgets better, we'd also like to come up with a small
documented client API for custom widgets.
* Theming & Design
We want to further improve the look and feel of RAP applications by
adding more theming features like shadows and more animations.
Our aging default theme also needs a fresh look.
Those widgets that are not very customizeable by theming, should be
improved. We will also ease the theming of custom widgets.
* Single Sourcing
To support single sourcing, we will update the Eclipse UI APIs to 3.7
and add more Eclipse API to RAP - first and foremost key bindings, as
there is a great demand.
* Support for other client technologies / Mobile
We see that mobile devices are getting more and more important and thus
want to improve RAP on those devices. For a start, we will fix blocking
bugs on iPhone/iPad and on Adroid.
Moreover, we will work towards a well-defined protocol between client
and server that will once allow for exchangeable client implementations.
* Reliability, Scalability and Availability
We want to further improve the performance of RAP by reducing the client
footprint.
We are involved in a research project that evaluates solutions for
transparent failover.
* Integration with other Eclipse projects
In the last release, we worked with EMF and Riena to make RAP usable
with these projects. We want to follow up this effort and will also have
a look at Virgo.
* Tooling
Two Google Summer of Code projects will be integrated into the RAP
tooling: The WAR Export and the Theme Editor.
That's it. You'll miss Draw2D on this list. We recognized that there is
a great interest in this feature and we did look into it try to come up
with an estimation. Draw2D alone would be a huge effort and we currently
cannot afford it to do that with the resources we have for OpenSource
development. GEF would require even more work. We're currently thinking
about a commercial offering for Draw2D/GEF if there's enough interest.
The RAP Team
Re: [Discussion] RAP 1.4 planning [message #549380 is a reply to message #548548] Mon, 26 July 2010 14:08 Go to previous messageGo to next message
Hi Philipp,
> StyledText.
StyledText would be an interesting challenge for us, too. But since
there were hardly any interest in it so far, we decided to keep this
feature off of our plan for 1.4, in favor of more requested features.
Maybe next year...
Best regards, Ralf
Re: [Discussion] RAP 1.4 planning [message #550935 is a reply to message #549349] Wed, 04 August 2010 16:14 Go to previous message
Just wanted to say KUDOS to RAP Team! This is by far the best Ajax framework out there for Eclipse RCP based product!
I am really happy to see, Reliability, Scalability and Availability to be addressed on 1.4.
Previous Topic:changing browser title at runtime
Next Topic:dynamically update widget from differnt project in eclipse
Current Time: Sat Feb 15 07:53:31 GMT 2025
Powered by FUDForum. Page generated in 0.05328 seconds
