Re: [CDO] xbcmodel [message #542690 is a reply to message #542617] |
Fri, 25 June 2010 15:52 |
Thanks for the infos. According to Ed you don't seem to be using feature
maps. But this makes me suspicious (last line):
<eStructuralFeatures xsi:type="ecore:EAttribute" name="timestamp"
lowerBound="1"
eType="ecore:EDataType http://www.eclipse.org/emf/2003/XMLType#//DateTime"/>
Before we continue to discuss the problem I would like you to retest it
with CDO 3.0 as published with Helios or from CVS HEAD because CDO 2.0
is out of maintenance starting today.
Cheers
/Eike
Am 25.06.2010 14:55, schrieb cippalippa:
> first of all, I would give thanks for your quickly reply, this is the
> log produced by Eclipse.
> org.eclipse.net4j.util.transaction.TransactionException: Rollback in
> DBStore: org.eclipse.net4j.util.ImplementationError: Unrecognized
> CDOType: FEATURE_MAP_ENTRY
> at org.eclipse.emf.cdo.server.internal.db.mapping.AbstractMappi
> ngStrategy.createValueMapping(AbstractMappingStrategy.java:4 51)
> at org.eclipse.emf.cdo.server.internal.db.mapping.horizontal.Ab
> stractListTableMapping.initTable(AbstractListTableMapping.ja va:117)
> stractListTableMapping. <init>(AbstractListTableMapping.java:95)
> at org.eclipse.emf.cdo.server.internal.db.mapping.horizontal.Au
> ditListTableMapping. <init>(AuditListTableMapping.java:42)
> at org.eclipse.emf.cdo.server.internal.db.mapping.horizontal.Ho
> rizontalAuditMappingStrategy.doCreateListMapping(HorizontalA
> uditMappingStrategy.java:35)
> ngStrategy.createListMapping(AbstractMappingStrategy.java:45 7)
> stractHorizontalClassMapping.createListMappings(AbstractHori
> zontalClassMapping.java:133)
> stractHorizontalClassMapping.initFeatures(AbstractHorizontal
> ClassMapping.java:106)
> <init>(AbstractHorizontalClassMapping.java:74)
> rizontalAuditClassMapping. <init>(HorizontalAuditClassMapping.java:63)
> rizontalAuditMappingStrategy.doCreateClassMapping(Horizontal
> AuditMappingStrategy.java:29)
> ngStrategy.createClassMapping(AbstractMappingStrategy.java:3 55)
> ngStrategy.mapClasses(AbstractMappingStrategy.java:325)
> ngStrategy.mapPackageInfos(AbstractMappingStrategy.java:314)
> ngStrategy.mapPackageUnits(AbstractMappingStrategy.java:336)
> ngStrategy.createMapping(AbstractMappingStrategy.java:297)
> at org.eclipse.emf.cdo.server.internal.db.DBStoreAccessor.write
> PackageUnits(DBStoreAccessor.java:496)
> at org.eclipse.emf.cdo.spi.server.StoreAccessor.write(StoreAcce
> ssor.java:129)
> at org.eclipse.emf.cdo.server.internal.db.DBStoreAccessor.acces
> s$4(DBStoreAccessor.java:1)
> at org.eclipse.emf.cdo.server.internal.db.DBStoreAccessor$1.run
> Loop(DBStoreAccessor.java:80)
> Loop(DBStoreAccessor.java:1)
> at org.eclipse.net4j.util.om.monitor.ProgressDistributor.run(Pr
> ogressDistributor.java:96)
> (DBStoreAccessor.java:294)
> at org.eclipse.emf.cdo.internal.server.TransactionCommitContext
> Impl.write(TransactionCommitContextImpl.java:269)
> at org.eclipse.emf.cdo.internal.server.protocol.CommitTransacti
> onIndication$1.runLoop(CommitTransactionIndication.java:73)
> onIndication$1.runLoop(CommitTransactionIndication.java:1)
> onIndication.indicatingCommit(CommitTransactionIndication.ja va:325)
> onIndication.indicating(CommitTransactionIndication.java:198 )
> onIndication.indicating(CommitTransactionIndication.java:140 )
> at org.eclipse.net4j.signal.IndicationWithMonitoring.indicating
> (IndicationWithMonitoring.java:84)
> at org.eclipse.net4j.signal.IndicationWithResponse.doExtendedIn
> put(IndicationWithResponse.java:90)
> at org.eclipse.net4j.signal.Signal.doInput(Signal.java:312)
> at org.eclipse.net4j.signal.IndicationWithResponse.execute(Indi
> cationWithResponse.java:63)
> at org.eclipse.net4j.signal.IndicationWithMonitoring.execute(In
> dicationWithMonitoring.java:63)
> at org.eclipse.net4j.signal.Signal.runSync(Signal.java:239)
> at org.eclipse.net4j.signal.Signal.run(Signal.java:147)
> at java.util.concurrent.ThreadPoolExecutor$Worker.runTask(Unkno
> wn Source)
> at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
> at java.lang.Thread.run(Unknown Source)
> at org.eclipse.emf.internal.cdo.transaction.CDOSingleTransactio
> nStrategyImpl.commit(CDOSingleTransactionStrategyImpl.java:6 3)
> at org.eclipse.emf.internal.cdo.transaction.CDOTransactionImpl.
> commit(CDOTransactionImpl.java:598)
> commit(CDOTransactionImpl.java:612)
> at org.eclipse.emf.cdo.internal.ui.actions.CommitTransactionAct
> ion.doRun(CommitTransactionAction.java:38)
> at org.eclipse.net4j.util.ui.actions.LongRunningAction$1.run(Lo
> ngRunningAction.java:185)
> at org.eclipse.core.internal.jobs.Worker.run(Worker.java:55)
Cheers
/Eike
http://www.esc-net.de
FUDForum. Page generated in 0.03905 seconds
