Re: Missing CSpec source required by component type osgi.bundle for local reader [message #542253 is a reply to message #542234] |
Thu, 24 June 2010 11:20 |
Hi Armin,
The local reader assumes that the target is a folder (checked out source typically). Try adding the eclipse installation
to your target platform instead. Alternatively, use the Eclipse p2 repository to resolve it.
You could try pointing the p2 reader to the plugins folder. It will probably succeed for the targets that are jars.
Unpacked bundles will not be found though. So again, best tip is to add the installation to the TP.
- thomas
On 06/24/2010 11:58 AM, Armin wrote:
> I'm trying to import the required plugins from a local eclipse
> installation (3.5.2). Here's the rmap searchPath:
> <searchPath name="local"> <provider readerType="local"
> componentTypes="osgi.bundle,eclipse.feature"
> mutable="true" source="false">
> <uri format="file:///c:/eclipse/plugins/{0}">
> <bc:propertyRef key="buckminster.component" />
> </uri>
> </provider>
> </searchPath>
> The error I'm getting is
> ERROR [0000] : No suitable provider for component
> org.eclipse.gmf.runtime.diagram.core:osgi.bundle/[1.3.0.v201 00113-1121,1.3.0.v20100113-1121]
> was found in resourceMap
> file:/E:/SSDE/trunk/ssde/de.scopeset.vsd.ssde.site/site_loca l.rmap
> was found in searchPath local
> ERROR [0000] : Resolution attempt ended with exception: Provider
> local( file:///c:/eclipse/plugins/org.eclipse.gmf.runtime.diagram.c ore):
> ERROR Provider
> I do have an
> org.eclipse.gmf.runtime.diagram.core_1.3.0.v20100113-1121.ja r in
> C:/eclipse/plugins - so what am I missing here ?
> thx,
> Armin
FUDForum. Page generated in 0.02878 seconds
