Home » Eclipse Projects » EclipseLink » Foreign key to unique field not primary key problem(ReferencedColumnName elements must be specified in each)
Foreign key to unique field not primary key problem [message #542115] |
Wed, 23 June 2010 22:13 |
Gabriele Muscas Messages: 8 Registered: June 2010 |
Hi all, i have a problem with annotations in a foreign key to unique field not primary key.
With this simple code:
EntityManager em = Persistence.createEntityManagerFactory("TestJpaPU").createEntityManager();
Query query = em.createQuery("SELECT c FROM Contatto c");
List<Contatto> contatti = query.getResultList();
for(Contatto contatto:contatti){
out.println(contatto.getNome());
I get this error:
Quote: | Exception Description: The @JoinColumns on the annotated element [field contatto] from the entity class [class com.testjpa.persistence.Recapito] is incomplete. When the source entity class uses a composite primary key, a @JoinColumn must be specified for each join column using the @JoinColumns. Both the name and the referencedColumnName elements must be specified in each such @JoinColumn.
Am I wrong or annotated classes have some problems?
(Same behavior with toplink and eclipselink)
Thanks!
Gabriele
Here my two tables:
CREATE TABLE contatto
id serial NOT NULL,
tipo_contatto character varying(50) NOT NULL,
nome character varying(100),
CONSTRAINT contatto_pkey PRIMARY KEY (id, tipo_contatto),
CONSTRAINT contatto_id_key UNIQUE (id)
CREATE TABLE recapito
id serial NOT NULL,
recapito character varying(300) NOT NULL,
id_contatto integer NOT NULL,
CONSTRAINT recapito_pkey PRIMARY KEY (id),
CONSTRAINT recapito_id_contatto_fkey FOREIGN KEY (id_contatto)
REFERENCES contatto (id) MATCH SIMPLE
ON UPDATE CASCADE ON DELETE CASCADE
Here my three generated classes:
@Entity
@Table(name = "contatto", catalog = "jpatest", uniqueConstraints = {
@UniqueConstraint(columnNames = {"id"})})
@NamedQueries({
@NamedQuery(name = "Contatto.findAll", query = "SELECT c FROM Contatto c"),
@NamedQuery(name = "Contatto.findById", query = "SELECT c FROM Contatto c WHERE c.contattoPK.id = :id"),
@NamedQuery(name = "Contatto.findByTipoContatto", query = "SELECT c FROM Contatto c WHERE c.contattoPK.tipoContatto = :tipoContatto"),
@NamedQuery(name = "Contatto.findByNome", query = "SELECT c FROM Contatto c WHERE c.nome = :nome")})
public class Contatto implements Serializable {
private static final long serialVersionUID = 1L;
@EmbeddedId
protected ContattoPK contattoPK;
@Column(name = "nome", length = 100)
private String nome;
@OneToMany(cascade = CascadeType.ALL, mappedBy = "contatto")
private List<Recapito> recapitoList;
*Constructor, Getters, Setters, hashCode, equals
@Entity
@Table(name = "recapito", catalog = "jpatest", schema = "jpaschema")
@NamedQueries({
@NamedQuery(name = "Recapito.findAll", query = "SELECT r FROM Recapito r"),
@NamedQuery(name = "Recapito.findById", query = "SELECT r FROM Recapito r WHERE r.id = :id"),
@NamedQuery(name = "Recapito.findByRecapito", query = "SELECT r FROM Recapito r WHERE r.recapito = :recapito")})
public class Recapito implements Serializable {
@Id
@Basic(optional = false)
@Column(name = "id", nullable = false)
private Integer id;
@Column(name = "recapito", nullable = false, length = 450)
private String recapito;
@JoinColumn(name = "id_contatto", referencedColumnName = "id", nullable = false)
@ManyToOne(optional = false)
private Contatto contatto;
@Embeddable
public class ContattoPK implements Serializable {
private int id;
@Column(name = "tipo_contatto", nullable = false, length = 50)
private String tipoContatto;
Re: Foreign key to unique field not primary key problem [message #542442 is a reply to message #542435] |
Thu, 24 June 2010 20:56 |
Hello, meanwhile, thanks for the help. I did not know the DescriptorCustomizer, now I have a lot to learn.
Unfortunately, the db will be used by a legacy application too, so I can not change it.
Now I created the class RecapitoCustomizer:
public class RecapitoCustomizer implements DescriptorCustomizer {
public void customize(ClassDescriptor descriptor) throws Exception {
OneToManyMapping mapping = (OneToManyMapping)descriptor.getMappingForAttributeName("contatto");
ExpressionBuilder builder = new ExpressionBuilder();
Expression expression = builder.getField("CONTATTO.ID").equal(builder.getParameter("RECAPITO.ID_CONTATTO"));
mapping.setSelectionCriteria(expression);
I change my Recapito class in this way:
@Entity
@Customizer(com.testjpa.persistence.customizers.RecapitoCustomizer.class)
@NamedQueries({
@Id
@Column(name = "id", nullable = false, insertable=false, updatable=false)
private Integer id;
And there are no more problems with the old code. I can list my contact.
Now i have some problem when i try to list the address list.
This code:
List<Recapito> recapiti;
recapiti = contatto.getRecapitoList();
for(Recapito recapito:recapiti){
out.println(recapito.getRecapito()+"<br/>");
out.println("<hr/>");
generates this error:
Internal Exception: org.postgresql.util.PSQLException: ERROR: column "tipo_contatto" does not exist
Error Code: 0
Call: SELECT id, recapito, tipo_contatto FROM jpatest.jpaschema.recapito WHERE ((tipo_contatto = ?) AND (id = ?))
bind => [agente, 1]
Query: ReadAllQuery(name="recapitoList" referenceClass=Recapito sql="SELECT id, recapito, tipo_contatto FROM jpatest.jpaschema.recapito WHERE ((tipo_contatto = ?) AND (id = ?))")
As I said, I still have much to learn.
Thanks!
Gabriele.
Current Time: Fri Apr 19 20:31:12 GMT 2024
Powered by FUDForum. Page generated in 0.03438 seconds
