Home » Archived » M2M (model-to-model transformation) » AML - Error when creating weaver model in AML Eclipse bundle(Error: "You can't use the plug-in without weaving panel extension")
AML - Error when creating weaver model in AML Eclipse bundle [message #541876] Tue, 22 June 2010 21:11 Go to next message
Izaak van Niekerk is currently offline Izaak van NiekerkFriend
Member
I'm getting the error "You can't use the plug-in without weaving panel extension" when I try and create a Weaving Model in the Eclipse bundle for AML.
Do I need this extension? How do I go about installing this extension?
Re: AML - Error when creating weaver model in AML Eclipse bundle [message #542402 is a reply to message #541876] Thu, 24 June 2010 17:08 Go to previous messageGo to next message
Kelly Garces is currently offline Kelly GarcesFriend
Member
Hi Izaak,
I suggest you to take a look to the AML demo, it will give you a quickly
view about how AML works:
http://www.eclipse.org/m2m/atl/usecases/ModelAdaptation/AMLE dited_1024x720.htm
Otherwise, to visualize the mapping (weaving) models genererated by AML,
you should have a parallel version of Eclipse with AMW installed.
Because AMW currently works on ATL 2.0, and AML on ATL 3.0. It is
necessary to have two Eclipses running on.
Kelly Garces - Phd. student
AtlanMod & AsCoLa research teams
École des Mines de Nantes
4, rue Alfred Kastler
44307 Nantes Cedex 3 - France
Re: AML - Error when creating weaver model in AML Eclipse bundle [message #542404 is a reply to message #542402] Thu, 24 June 2010 17:50 Go to previous message
Member
I will go through the demo. Thank you Kelly!
Previous Topic:call a rule ATL
Next Topic:how to use enumerations literal in Atl Program
Current Time: Wed Dec 04 02:04:20 GMT 2024
Powered by FUDForum. Page generated in 0.07951 seconds
