Re: [Acceleo 3] properties files [message #541733 is a reply to message #541719] |
Tue, 22 June 2010 11:07   |
--------------030007010206010802060407
Without knowing what you did or how "it failed", I can't give you much
more help than what already is in the online help :
- your properties file must be in a source folder (say it is in package
"com.serli" and it is named "test.properties")
- you have to return its qualified name in the list of Strings returned
by the method "getProperties" of the generated Java launcher for your
mtl. With this example, the String you have to return would be
"com.serli.test"
If these don't help, I'll need more information as to what you did, what
you're trying to do, how you don't manage to do it.
Laurent Goubet
Obeo
evariste.konkole@serli.com wrote:
> I'm trying to use properties file with Acceleo3.0. I followed the help
> guide but i was not able to make it work.
> Please, someone can give me more details about it?
name="laurent_goubet.vcf"
filename="laurent_goubet.vcf"
bjoyLjENCmVuZDp2Y2FyZA0KDQo=
--------------030007010206010802060407--
Re: [Acceleo 3] properties files [message #541924 is a reply to message #541749] |
Wed, 23 June 2010 07:51  |
--------------040806050202010509030600
The "propertiesFiles" field is deprecated and no longer in use. You
should return the String yourself from your implementation of
getProperties :
public List<String> getProperties() {
List<String> properties = super.getProperties(); <= 'super' doesn't do
anything other than creating an empty list, so this is not mandatory
properties.add("com.serli.default");
return properties;
However, a call to "getProperty" should never return a invalid result
such as you have there : a "not found" property should simply return
null. Which build of Acceleo are you using?
.... Come to think of it ... if the "propertiesFiles" field of your
generated java launcher is _not_ deprecated then you are using an older
version of Acceleo, one where the properties files weren't properly handled.
Laurent Goubet
Obeo
> what i've done is:
> - i add default.properties file in package com.serli. this file contains
> a key name 'path'
> - then i modify getProperties method by adding this line
> propertiesFiles.add("com.serli.default"); - finally, in my module i use
> getProperty('path') to get the value of the key. I obtain this result
> mailto:org.eclipse.emf.ecore.impl.DynamicEObjectImpl@14d5067 (eClass:
> mailto:org.eclipse.emf.ecore.impl.EClassImpl@d9a624 (name:
> Invalid_Class) (instanceClassName: null) (abstract: false, interface:
> false))
--------------040806050202010509030600--
FUDForum. Page generated in 0.02572 seconds
