Home » Eclipse Projects » Eclipse Platform » TextEditor annotations in OverviewRuler from IMarkers
TextEditor annotations in OverviewRuler from IMarkers [message #541654] |
Tue, 22 June 2010 02:05 |
No real name Messages: 1 Registered: June 2010 |
I have a TextEditor. There are markers created by a IncrementalProjectBuilder,
public static final String MARKER_TYPE = "com.salmat.speech.vecomposer.gsleditor.gslProblem";
private void addMarker(IFile file, String message, int lineNumber,
int severity) {
try {
IMarker marker = file.createMarker(MARKER_TYPE);
marker.setAttribute(IMarker.MESSAGE, message.replaceAll("\\s", " "));
marker.setAttribute(IMarker.SEVERITY, severity);
if (lineNumber == -1) {
lineNumber = 1;
marker.setAttribute(IMarker.LINE_NUMBER, lineNumber);
} catch (CoreException e) {
These appear in the VerticalRuler. I think that is because of the following in the plugin.xml
<extension
id="gslProblem"
name="GSL Problem"
point="org.eclipse.core.resources.markers">
<super
type="org.eclipse.core.resources.problemmarker">
</super>
<persistent
value="true">
</persistent>
</extension>
The markers also appear in the "Problems" and "Markers" pane.
I would like them to also appear in the overview ruler. So far I've been very unsuccessful.
In my TextEditor I have got it showing an overview ruler with:
protected boolean isOverviewRulerVisible() {
return true;
And I've hard coded some annotations on it:
protected void editorSaved() {
super.editorSaved();
String ERROR_TYPE = "error.type";
fOverviewRuler.addAnnotationType(ERROR_TYPE);
fOverviewRuler.addHeaderAnnotationType(ERROR_TYPE);
fOverviewRuler.setAnnotationTypeLayer(ERROR_TYPE, 3);
fOverviewRuler.setAnnotationTypeColor(ERROR_TYPE, new Color(Display.getDefault(),new RGB(255,0,0)));
fOverviewRuler.getModel().addAnnotation(new Annotation(ERROR_TYPE,false,"foobar"), new Position(6));
fOverviewRuler.getModel().addAnnotation(new Annotation(ERROR_TYPE,false,"foobar1"), new Position(60));
How do you get the markers to appear "automatically"?
I'm sure I've missed something very simple
thx,
Jamie
Re: TextEditor annotations in OverviewRuler from IMarkers [message #544272 is a reply to message #541654] |
Fri, 02 July 2010 08:21 |
Dani Megert Messages: 3802 Registered: July 2009 |
> int severity) {
> try {
> lineNumber = 1;
> <extension
> id="gslProblem"
> name="GSL Problem"
> <super
> </super>
> <persistent
> value="true">
> </persistent>
> </extension>
> @Override
> return true;
> @Override
> I'm sure I've missed something very simple :)
Take a look at the following extension points:
- org.eclipse.ui.editors.annotationTypes
- org.eclipse.ui.editors.markerAnnotationSpecification
Dani
> thx,
> Jamie
Current Time: Fri Mar 29 05:22:33 GMT 2024
Powered by FUDForum. Page generated in 0.03691 seconds
