Re: how to modify existing plugin [message #542885 is a reply to message #541350] |
Sun, 27 June 2010 06:20 |
Ankur Sharma Messages: 68 Registered: July 2009 |
Member |
On 20/06/2010 16:58, Harald Finster wrote:
> Hello,
> could you please give me advice with regards to the following?
> I would like to modify an existing plugin, more specifically
> the cdo/emf editor plugin org.eclipse.emf.cdo.edit if that
> matters.
> The plugin in question is already part of my eclipse runtime.
> What is the best way to create a "clone", modify it
> and use the new version instead of the original one?
> I already checked out the source code from the CVS.
> I intended to export my plugin-version using
> "export -> create deployable plug-ins and fragments",
> but the wizard did not offer anything in the
> "Available Plugins and Fragments" field.
> I also tried to create a mini-RCP application and to add
> my plugin to the applications dependencies. However,
> the wizard does not seem to be aware of the existence of
> my "cloned" plugin and offers the plugin from the
> runtime only. (I know, that using a separate target
> platform would be better.)
> I would be grateful hints!
> Kind regards
> Harald
The other plug-ins might be picking the old (and original) plug-in due to version binding. Also the
plug-ins may be signed jars and since your plug-in is unsigned it wont be picked up. I am not sure
if there is a workaround for this as this is supposed to be OSGi security mechanism.
However, if you do figure out a way, plz do r'ber to open a bug and submit your modifications as
required by EPL.
Ankur..
Eclipse PDE UI Committer | IBM India Software Lab, Bangalore
+91-99456-94011 | @ankur_sharma | http://blog.ankursharma.org
Re: how to modify existing plugin [message #606179 is a reply to message #541350] |
Member |
> Hello,
> matters.
> Kind regards
> Harald
required by EPL.
Ankur..
FUDForum. Page generated in 0.02058 seconds
