Home » Eclipse Projects » Eclipse 4 » TestCase failures and incomplete UI and functionality for Eclipse 4.0 M6(TestCase failures and incomplete UI and functionality for Eclipse 4.0 M6)
TestCase failures and incomplete UI and functionality for Eclipse 4.0 M6 [message #541265] Sat, 19 June 2010 06:31 Go to next message
ratish  is currently offline ratish Friend
The setup for Eclipse 4.0 M6 (eclipse-SDK-4.0M6-win32.zip) at http://download.eclipse.org/e4/sdk/ shows Test Case failures
When I complete the setup, I see incomplete UI and functionalities. Any idea, when will the next build be available with the fixes
Re: TestCase failures and incomplete UI and functionality for Eclipse 4.0 M6 [message #541530 is a reply to message #541265] Mon, 21 June 2010 13:19 Go to previous messageGo to next message
Paul Webster is currently offline Paul WebsterFriend
We're publishing RC0 today. http://wiki.eclipse.org/E4/Self_Hosting has
the list of known issues that need to be worked on for 4.0
PW
Paul Webster
http://help.eclipse.org/galileo/index.jsp?topic=/org.eclipse .platform.doc.isv/guide/workbench.htm
Re: TestCase failures and incomplete UI and functionality for Eclipse 4.0 M6 [message #541892 is a reply to message #541530] Wed, 23 June 2010 01:36 Go to previous messageGo to next message
Thanks... Will work with RC0
Re: TestCase failures and incomplete UI and functionality for Eclipse 4.0 M6 [message #578072 is a reply to message #541530] Wed, 23 June 2010 01:36 Go to previous message
Previous Topic:TestCase failures and incomplete UI and functionality for Eclipse 4.0 M6
Next Topic:e4 RC0, moved IEclipseContext where?
Current Time: Tue Aug 03 06:43:00 GMT 2021
Powered by FUDForum. Page generated in 0.01856 seconds
