Home » Eclipse Projects » Rich Client Platform (RCP) » IObjectActionDelegate + ISelction filtering
IObjectActionDelegate + ISelction filtering [message #541171] Fri, 18 June 2010 14:11 Go to next message
Sebastian is currently offline SebastianFriend
I'd like to have a context menu entry for a specific class (realized
with IObjectActionDelegate) which is only visible if all selected items
match some criteria. The problem is that it is not sufficient to test
how many items are selected (e.g. with enablesFor) or to test every
single item for itself.
For example the action should be enabled if one of the selected items
fullfill a special requirement. Therefore to test for the amount or an
objectState separatly is not sufficient.
Is there any possibility to get a setEnabled-method for a
IObjectContribution?
Or maybe an ISelction for an Action?
Or is there any other possiblity?
Sebastian
Re: IObjectActionDelegate + ISelction filtering [message #541219 is a reply to message #541171] Fri, 18 June 2010 17:54 Go to previous messageGo to next message
Paul Webster is currently offline Paul WebsterFriend
In general the object contribution filters are applied as an "and".
i.e. every object in the selection must match all criteria. There's
nothing you can do about that.
Even the core expression, objectContribution/enablement, is applied to
each element individually.
If you use commands and org.eclipse.ui.menus to contribute to a popup
menu, you have a lot more flexibility with the visibleWhen clause (<with
variables="activeMenuSelection")
PW
PW
Paul Webster
http://help.eclipse.org/galileo/index.jsp?topic=/org.eclipse .platform.doc.isv/guide/workbench.htm
Re: IObjectActionDelegate + ISelction filtering [message #541478 is a reply to message #541219] Mon, 21 June 2010 10:01 Go to previous messageGo to next message
Daniel Krügler is currently offline Daniel KrüglerFriend
On 18.06.2010 19:54, Paul Webster wrote:
> In general the object contribution filters are applied as an "and". i.e.
> every object in the selection must match all criteria. There's nothing
I believe that would still allow the OP to use a property tester to
check the constraints. If some special item needs some special test,
the only thing the OP needs to be able to *recognice*, which object
is special. So, the test would basically look like:
return ifSpecial(obj) ? checkSpecial(obj) : checkNormal(obj);
Greetings from Bremen,
Daniel Krügler
Re: IObjectActionDelegate + ISelction filtering [message #541528 is a reply to message #541478] Mon, 21 June 2010 13:14 Go to previous messageGo to next message
Yes, but that test will be applied individually to each element in the
selection. If that's what you want, then you're gold.
It's the case where you want "If most of the selection is normal but
there is at least one special case" that won't work, because you can't
tell how your siblings evaluated.
PW
Paul Webster
Re: IObjectActionDelegate + ISelction filtering [message #541542 is a reply to message #541528] Mon, 21 June 2010 13:28 Go to previous message
I agree - I misread what the OP actually wants.
Thx,
- Daniel
Previous Topic:Translations work well in IDE but are missing after export
Next Topic:Re: Exported RCP tutorial crashes when run
Current Time: Sun Oct 01 00:05:33 GMT 2023
Powered by FUDForum. Page generated in 0.02031 seconds
