My SWT application doesn't work on Mac [message #540234] |
Tue, 15 June 2010 13:01 |
Alexandra Niculai Messages: 84 Registered: July 2009 |
Member |
I have an SWT application that I created on Windows and it runs fine. It runs also on Ubuntu, but when I try to run it on Mac, it doesn't work. Sometimes, I get to see the the application but it doesn't react at all.
I tried to run it in Eclipse and I always get the following exception:
at org.eclipse.swt.widgets.Display.updateQuitMenu(Display.java:4082)
at org.eclipse.swt.widgets.Shell.setWindowVisible(Shell.java:1632)
at org.eclipse.swt.widgets.Shell.setVisible(Shell.java:1563)
When looking at the source code in Display line 4082, the code there is:
NSMenu mainmenu = application.mainMenu();
NSMenuItem appitem = mainmenu.itemAtIndex(0);
So mainMenu is null.
I tried to add a menubar to the application but the problem persists.
I'm using org.eclipse.swt.cocoa.macosx_3.5.2.v3557f.jar.
Could anyone please help me?
[Updated on: Tue, 15 June 2010 13:03] Report message to a moderator
Re: My SWT application doesn't work [message #541521 is a reply to message #540234] |
Mon, 21 June 2010 13:01 |
Daniel Krügler Messages: 853 Registered: July 2009 |
On 15.06.2010 15:01, Alexandra Niculai wrote:
> Hi
> at org.eclipse.swt.widgets.Display.updateQuitMenu(Display.java: 4082)
> at org.eclipse.swt.widgets.Shell.setWindowVisible(Shell.java:16 32)
Sorry, I have no MacOS, but I have heard from a colleague a similar
problem. I suggest that you search in the bugzilla entries for
such a problem and to vote for it, if existing. If not existing,
please open a new one.
Greetings from Bremen,
Daniel Krügler
FUDForum. Page generated in 0.03365 seconds
